GaussDB(DWS)中Oracle不兼容语法修改集
古月磊 发表于 2021/03/11 10:18:03 2021/03/11
【摘要】 Oracle特殊语法在DWS中的实现。
1、递归语法
  • 单表递归
 Oracle:
create table tb_recursive(id int,parent_id int);
insert into tb_recursive values(0,'');
insert into tb_recursive values(1,0);
insert into tb_recursive values(11,1);
insert into tb_recursive values(12,1);
insert into tb_recursive values(111,11);
insert into tb_recursive values(2,0);
insert into tb_recursive values(21,2);
insert into tb_recursive values(22,2);
insert into tb_recursive values(222,22);
insert into tb_recursive values(211,21);
insert into tb_recursive values(212,21);
select id,parent_id,level lvl from tb_recursive connect by prior id=parent_id start with parent_id is null order by id;
 Gauss:
with recursive r1 as (
select id,parent_id,1 as lvl
from tb_recursive
where parent_id is null
union all
select t.id,t.parent_id,t1.lvl+1 as lvl
from tb_recursive t,r1 t1
where t.parent_id=t1.id)
select id,parent_id,lvl from r1 order by id;
 Oracle:
select id,parent_id,level lvl from tb_recursive connect by id=prior parent_id start with parent_id is null order by id;
 Gauss:
from tb_recursive
union all
where t.id=t1.parent_id)
  • sys_connect_by_path
Oracle:
select id,parent_id,sys_connect_by_path(id,' > ') path,level lvl from tb_recursive connect by prior id= parent_id start with parent_id is null order by id;
Gauss:
select id,parent_id,' > '||id path,1 as lvl
from tb_recursive
union all
select t.id,t.parent_id,t1.path||' > '||t.id path,t1.lvl+1 as lvl
select id,parent_id,path,lvl from r1 order by id;
    • order siblings by
    Oracle:
    select id,parent_id,level lvl from tb_recursive connect by prior id=parent_id start with parent_id is null order siblings by id;
    Gauss:
    select id,parent_id,1 as lvl,lpad(id,4,0)||lpad(ctid||xc_node_id::text,20,0) sortno
    from tb_recursive
    union all
    select t.id,t.parent_id,t1.lvl+1 as lvl,t1.sortno||lpad(t.id,4,0)||lpad(ctid||xc_node_id::text,20,0) sortno
    select id,parent_id,lvl from r1 order by sortno;
      • connect_by_root
      Oracle:
      select id,parent_id,connect_by_root(parent_id) as rid,level lvl from tb_recursive connect by prior id=parent_id start with parent_id =2 order by id;
      Gauss:
      select id,parent_id,parent_id rid,1 as lvl
      from tb_recursive
      where parent_id =2
      union all
      select t.id,t.parent_id,t1.rid,t1.lvl+1 as lvl
      select id,parent_id,rid,lvl from r1 order by id;
        • connect by前有where
        Oracle:
        select id,parent_id,level lvl from tb_recursive where parent_id = 1 connect by prior id=parent_id start with parent_id is null order by id;
        Gauss:
        from tb_recursive
        union all
        select id,parent_id,lvl from r1 where parent_id =1 order by id;
        2、Rownum
        • select list中
        Oracle:
        select id,parent_id,rownum from tb_recursive order by 3;
        Gauss:
        select id,parent_id,row_number() over() from tb_recursive order by 3;
          • where条件中
          Oracle:
          select id,parent_id from tb_recursive where rownum =1 order by id;
          Gauss:
          select id,parent_id from tb_recursive order by id limit 1;
            • sql语句中有order by
            Oracle:
            select id from (select id,parent_id from tb_recursive order by id desc) where rownum =1;
            Gauss:
            select id from tb_recursive order by id desc limit 1;
              • sql语句中有count
              Oracle:
              select count(1) from (select id,parent_id from tb_recursive where id = 1) where rownum =1;
              Gauss:
              select count(1) from (select id,parent_id from tb_recursive where id = 1 limit 1);
                • sql语句中有max/min
                Oracle:
                select max(id) from tb_recursive where parent_id=21 and rownum =1;
                select min(id) from tb_recursive where parent_id=21 and rownum =1;
                Gauss:
                select id from tb_recursive where parent_id=21 order by id limit 1;
                3、Max/Min...keep语法
                • 单表max,dense_rank last
                Oracle:
                select max(id) keep (dense_rank last order by parent_id) from tb_recursive;
                Gauss:
                select id from tb_recursive order by parent_id desc,id desc limit 1;
                • 单表max,dense_rank first
                Oracle:
                select max(id) keep (dense_rank first order by parent_id) from tb_recursive;
                Gauss:
                select id from tb_recursive order by parent_id asc,id desc limit 1;
                  • 单表min,dense_rank last
                  Oracle:
                  select min(id) keep (dense_rank last order by parent_id) from tb_recursive;
                  Gauss:
                  select id from tb_recursive order by parent_id desc,id asc limit 1;
                  • 单表min,dense_rank first
                  Oracle:
                  select min(id) keep (dense_rank first order by parent_id) from tb_recursive;
                  Gauss:
                  select id from tb_recursive order by parent_id asc,id asc limit 1;
                  4、pivot语法
                   测试表及数据:
                  drop table if exists tb_test;
                  create table tb_test(a int,b int);
                  insert into tb_test values(1,1),(1,1),(1,2),(1,3),(1,4),(2,1),(2,2),(2,3),(2,2),(2,4),(2,5),(2,6);
                  Oracle:
                  select * from
                  (select a,b,count(*) cnt from tb_test group by a,b) t
                  pivot (sum(cnt) for a in (1 c,2 d,3 e,4 f));
                  Gauss:
                  select b,sum(case a when 1 then cnt end) C,
                  sum(case a when 2 then cnt end) D,
                  sum(case a when 3 then cnt end) E,
                  sum(case a when 4 then cnt end) F
                  from (select a,b,count(*) cnt from tb_test group by a,b)
                  group by b;
