2021-03-08:在一个数组中,任何一个前面的数a,和任何一个后面的数b,如果(a,b)是降序的,就称为逆序对。返回逆序对个
福大大架构师每日一题 发表于 2021/03/08 22:50:59 2021/03/08
【摘要】 2021-03-08:在一个数组中,任何一个前面的数a,和任何一个后面的数b,如果(a,b)是降序的,就称为逆序对。返回逆序对个数。福哥答案2021-03-08:1.归并排序,从右往左,相等拷右。有代码。2.归并排序模板。有代码。代码用golang编写,代码如下:package mainimport "fmt"func main() { if true { arr := ...
福哥答案2021-03-08:
2.归并排序模板。有代码。
代码用golang编写,代码如下:
package main
import "fmt"
func main() {
    if true {
        arr := []int{3, 1, 7, 0, 2}
        ret := reverPairNumber1(arr)
        fmt.Println("1.从右往左,相等拷右:", ret)
    if true {
        ret := reverPairNumber2(arr)
        fmt.Println("2.归并排序模板:", ret)
func reverPairNumber1(arr []int) int {
    arrLen := len(arr)
    if arrLen <= 1 {
        return 0
    return process1(arr, 0, arrLen-1)
func process1(arr []int, L int, R int) int {
    curLen := R - L + 1
    if curLen <= 1 {
        return 0
    //求中点
    M := L + (R-L)>>1
    return process1(arr, L, M) + process1(arr, M+1, R) + merge1(arr, L, M, R)
func merge1(arr []int, L int, M int, R int) int {
    //辅助数组
    help := make([]int, R-L+1)
    i := R - L + 1 - 1
    p1 := M
    p2 := R
    res := 0
    //谁小拷谁,相等拷右
    for p1 >= L && p2 >= M+1 {
        if arr[p1] > arr[p2] {
            res += p2 - M
            help[i] = arr[p1]
            p1--
            help[i] = arr[p2]
            p2--
        i--
    for p1 >= L {
        help[i] = arr[p1]
        p1--
        i--
    for p2 >= M+1 {
        help[i] = arr[p2]
        p2--
        i--
    //辅助数组拷贝到原数组
    copy(arr[L:R+1], help)
    return res
func reverPairNumber2(arr []int) int {
    arrLen := len(arr)
    if arrLen <= 1 {
        return 0
    return process2(arr, 0, arrLen-1)
func process2(arr []int, L int, R int) int {
    curLen := R - L + 1
    if curLen <= 1 {
        return 0
    //求中点
    M := L + (R-L)>>1
    return process2(arr, L, M) + process2(arr, M+1, R) + merge2(arr, L, M, R)
func merge2(arr []int, L int, M int, R int) int {
    //新增的代码
    ans := 0
    windowR := M + 1
    for i := L; i <= M; i++ {
        for windowR <= R && arr[i] > arr[windowR] {
            windowR++
        ans += windowR - M - 1
    //辅助数组
    i := 0
    p1 := L
    p2 := M + 1
    //谁小拷贝谁
    for p1 <= M && p2 <= R {
        if arr[p1] <= arr[p2] {
            help[i] = arr[p1]
            p1++
            help[i] = arr[p2]
            p2++
        i++
    for p1 <= M {
        help[i] = arr[p1]
        p1++
        i++
    for p2 <= R {
        help[i] = arr[p2]
        p2++
        i++
    //辅助数组拷贝到原数组
    return ans
执行结果如下:
左神java代码
剑指 Offer 51. 数组中的逆序对
评论
