解决log4j.xml问题http//jakarta.apache.org/log4j/ uri is not register
DevFeng 发表于 2021/02/03 10:28:13 2021/02/03
【摘要】     在Eclipse中,配置log4j.xml出现“http //jakarta.apache.org/log4j/ uri is not registered”的错误信息。原始的log4j.xml配置文件:<?xml version="1.0" encoding="GB2312" ?><!DOCTYPE log4j:configuration SYSTEM "log4j.dtd"><l...
原始的log4j.xml配置文件:
  1. <?xml version="1.0" encoding="GB2312" ?>
  2. <!DOCTYPE log4j:configuration SYSTEM "log4j.dtd">
  3. <log4j:configuration xmlns:log4j="http://jakarta.apache.org/log4j/" debug="true">
     解决方法,具体修改如下所示。
<!DOCTYPE log4j:configuration SYSTEM "http://logging.apache.org/log4j/1.2/apidocs/org/apache/log4j/xml/doc-files/log4j.dtd">
<log4j:configuration debug="true">
