Ubuntu 挂载Windows ntfs分区报错的解决方法
悲恋花丶无心之人 发表于 2021/02/02 23:07:43 2021/02/02
【摘要】 目录 一、错误 二、解决方法 一、错误 1.博主在挂载windows系统D盘时报错,/dev/sda1指的是D盘,挂载的目录是/mnt/D: sudo mount -t ntfs /dev/sda1 /mnt/D -o iocharset=utf8,umask=0 错误为 The disk contains an unclean file system (0...
目录
一、错误
二、解决方法
一、错误
错误为
  1. The disk contains an unclean file system (0, 0).
  2. Metadata kept in Windows cache, refused to mount.
  3. Failed to mount '/dev/sda1': 不允许的操作
  4. The NTFS partition is in an unsafe state. Please resume and shutdown
  5. Windows fully (no hibernation or fast restarting), or mount the volume
  6. read-only with the 'ro' mount option.
二、解决方法
1.终端输入如下指令修复
sudo ntfsfix /dev/sda1
2.如下显示
  1. Mounting volume... The disk contains an unclean file system (0, 0).
  3. FAILED
  4. Attempting to correct errors...
  5. Processing $MFT and $MFTMirr...
  6. Reading $MFT... OK
  7. Reading $MFTMirr... OK
  8. Comparing $MFTMirr to $MFT... OK
  9. Processing of $MFT and $MFTMirr completed successfully.
  10. Setting required flags on partition... OK
  11. Going to empty the journal ($LogFile)... OK
  12. Checking the alternate boot sector... OK
  13. NTFS volume version is 3.1.
  14. NTFS partition /dev/sda1 was processed successfully.
3.再次运行挂载命令则可以成功挂载!!
文章来源: nickhuang1996.blog.csdn.net,作者:悲恋花丶无心之人,版权归原作者所有,如需转载,请联系作者。
原文链接:nickhuang1996.blog.csdn.net/article/details/90296868
