[oracle] 查询历史会话、历史执行计划
dber 发表于 2021/01/29 13:38:24 2021/01/29
【摘要】 1.查询历史连接信息select *from dba_hist_active_sess_history awhere a.SAMPLE_TIME BETWEENTO_DATE('2020-10-04 12:00:00', 'YYYY-MM-DD HH24:MI:SS') ANDTO_DATE('2020-10-04 13:00:00', 'YYYY-MM-DD HH24:MI:SS')sel...
1.查询历史连接信息
select *
select *
from v$active_session_history D
WHERE d.SAMPLE_TIME BETWEEN
2.查询历史sql信息
select * from v$sqlarea where sql_text like '%%';
3.查询历史执行计划
select * from v$sql_plan;
如果缓存内查询不到,可以查询DBA_HIST_SQL_PLAN表
select * from DBA_HIST_SQL_PLAN;
