k8s二进制部署(三)
ming-1 发表于 2021/01/28 22:28:23 2021/01/28
【摘要】 安装Master节点组件##创建所需目录mkdir -p /opt/kubernetes_master/{bin,cfg,ssl,log}##下载解压kubernetes文件https://github.com/kubernetes/kubernetes/blob/master/CHANGELOG/CHANGELOG-1.18.mdtar -zxvf kubernetes-server-li...
安装Master节点组件
##创建所需目录
##下载解压kubernetes文件
tar -zxvf kubernetes-server-linux-amd64.tar.gz
##移动文件至kubernetes_master目录
cd kubernetes/server/bin/
cp kube-apiserver kube-scheduler kube-controller-manager /opt/kubernetes_master/bin
##签发证书
cd /opt/k8s/k8s-cert
cat > ca-config.json << EOF
  "signing": {
    "default": {
      "expiry": "87600h"
    "profiles": {
      "kubernetes": {
         "expiry": "87600h",
         "usages": [
            "signing",
            "key encipherment",
            "server auth",
            "client auth"
EOF
cat > ca-csr.json << EOF
    "CN": "kubernetes",
    "key": {
        "algo": "rsa",
        "size": 2048
    "names": [
            "C": "CN",
            "L": "Beijing",
            "ST": "Beijing",
            "O": "k8s",
            "OU": "System"
EOF
##通过gencert -initca来初始化,然后使用cfssljson命令保存
cfssl gencert -initca ca-csr.json | cfssljson -bare ca -
##生成apiserver证书请求文件(ip地址为可以多设置几个以备扩展使用)
cat > apiserver-csr.json << EOF
    "CN": "kubernetes",
    "hosts": [
            "10.0.0.1",
      "127.0.0.1",
      "10.107.141.50",
      "10.107.141.53",
      "10.107.141.54",
      "10.107.141.55",
      "kubernetes",
      "kubernetes.default",
      "kubernetes.default.svc",
      "kubernetes.default.svc.cluster",
      "kubernetes.default.svc.cluster.local"
    "key": {
        "algo": "rsa",
        "size": 2048
    "names": [
            "C": "CN",
            "L": "BeiJing",
            "ST": "BeiJing",
            "O": "k8s",
            "OU": "System"
EOF
##生成apiserver证书
cfssl gencert -ca=ca.pem -ca-key=ca-key.pem -config=ca-config.json -profile=kubernetes apiserver-csr.json | cfssljson -bare apiserver
##移动文件至工作目录
cp ca.pem apiserver.pem apiserver-key.pem ca-key.pem /opt/kubernetes_master/ssl/
##生成kube-apiserver.conf,kube-controller-manager.conf,kube-scheduler.conf配置文件
cd /opt/kubernetes_master/cfg/
##生成对应的systemd文件
cat > /usr/lib/systemd/system/kube-apiserver.service << EOF
[Unit]
Description=Kubernetes API Server
Documentation=https://github.com/kubernetes/kubernetes
[Service]
EnvironmentFile=/opt/kubernetes_master/cfg/kube-apiserver.conf
ExecStart=/opt/kubernetes_master/bin/kube-apiserver \$KUBE_APISERVER_OPTS
Restart=on-failure
[Install]
WantedBy=multi-user.target
EOF
cat > /usr/lib/systemd/system/kube-controller-manager.service << EOF
[Unit]
Description=Kubernetes Controller Manager
[Service]
EnvironmentFile=/opt/kubernetes_master/cfg/kube-controller-manager.conf
ExecStart=/opt/kubernetes_master/bin/kube-controller-manager \$KUBE_CONTROLLER_MANAGER_OPTS
Restart=on-failure
[Install]
EOF
cat > /usr/lib/systemd/system/kube-scheduler.service << EOF
[Unit]
Description=Kubernetes Scheduler
[Service]
EnvironmentFile=/opt/kubernetes_master/cfg/kube-scheduler.conf
ExecStart=/opt/kubernetes_master/bin/kube-scheduler \$KUBE_SCHEDULER_OPTS
Restart=on-failure
[Install]
EOF
