Python+OpenCV检测灯光亮点
不脱发的程序猿 发表于 2020/12/31 01:18:41 2020/12/31
【摘要】 本篇博文分享一篇寻找图像中灯光亮点(图像中最亮点)的教程,例如,检测图像中五个灯光的亮点并标记,项目效果如下所示: 第1步:导入并打开原图像,实现代码如下所示: # import the necessary packagesfrom imutils import contoursfrom skimage import measureimport numpy as ...
  1. # import the necessary packages
  2. from imutils import contours
  3. from skimage import measure
  4. import numpy as np
  5. import argparse
  6. import imutils
  7. import cv2
  8. # construct the argument parse and parse the arguments
  9. ap = argparse.ArgumentParser()
  10. ap.add_argument("-i", "--image", required=True,
  11. help="path to the image file")
  12. args = vars(ap.parse_args())
第2步:开始检测图像中最亮的区域,首先需要从磁盘加载图像,然后将其转换为灰度图并进行平滑滤波,以减少高频噪声,实现代码如下所示:
  1. #load the image, convert it to grayscale, and blur it
  2. image = cv2.imread(args["image"])
  3. gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
  4. blurred = cv2.GaussianBlur(gray, (11, 11), 0)
导入亮灯图像,过滤后效果如下所示:
第3步:阈值化处理,为了显示模糊图像中最亮的区域,将像素值p >= 200,设置为255(白色),像素值< 200,设置为0(黑色),实现代码如下所示:
  1. # threshold the image to reveal light regions in the
  2. # blurred image
  3. thresh = cv2.threshold(blurred, 200, 255, cv2.THRESH_BINARY)[1]
效果如下所示:
 第4步:此时可看到图像中存在噪声(小斑点),所以需要通过腐蚀和膨胀操作来清除,实现代码如下所示:
  1. # perform a series of erosions and dilations to remove
  2. # any small blobs of noise from the thresholded image
  3. thresh = cv2.erode(thresh, None, iterations=2)
  4. thresh = cv2.dilate(thresh, None, iterations=4)
此时“干净”的图像如下所示:
第5步:本项目的关键步骤是对上图中的每个区域进行标记,即使在应用了腐蚀和膨胀后,仍然想要过滤掉剩余的小块儿区域。一个很好的方法是执行连接组件分析,实现代码如下所示:
  1. # perform a connected component analysis on the thresholded
  2. # image, then initialize a mask to store only the "large"
  3. # components
  4. labels = measure.label(thresh, neighbors=8, background=0)
  5. mask = np.zeros(thresh.shape, dtype="uint8")
  6. # loop over the unique components
  7. for label in np.unique(labels):
  8. # if this is the background label, ignore it
  9. if label == 0:
  10. continue
  11. # otherwise, construct the label mask and count the
  12. # number of pixels
  13. labelMask = np.zeros(thresh.shape, dtype="uint8")
  14. labelMask[labels == label] = 255
  15. numPixels = cv2.countNonZero(labelMask)
  16. # if the number of pixels in the component is sufficiently
  17. # large, then add it to our mask of "large blobs"
  18. if numPixels > 300:
  19. mask = cv2.add(mask, labelMask)
上述代码中,第4行使用scikit-image库执行实际的连接组件分析。measure.lable返回的label和阈值图像有相同的大小,唯一的区别就是label存储的为阈值图像每一斑点对应的正整数。
然后在第5行初始化一个掩膜来存储大的斑点。
第7行开始循环遍历每个label中的正整数标签,如果标签为零,则表示正在检测背景并可以安全的忽略它(9,10行)。否则,为当前区域构建一个掩码。
下面提供了一个GIF动画,它可视化地构建了每个标签的labelMask。使用这个动画来帮助你了解如何访问和显示每个单独的组件:
第15行对labelMask中的非零像素进行计数。如果numPixels超过了一个预先定义的阈值(在本例中,总数为300像素),那么认为这个斑点“足够大”,并将其添加到掩膜中。输出掩模如下图所示:
第6步:此时图像中所有小的斑点都被过滤掉了,只有大的斑点被保留了下来。最后一步是在的图像上绘制标记的斑点,实现代码如下所示:
  1. # find the contours in the mask, then sort them from left to
  2. # right
  3. cnts = cv2.findContours(mask.copy(), cv2.RETR_EXTERNAL,
  4. cv2.CHAIN_APPROX_SIMPLE)
  5. cnts = imutils.grab_contours(cnts)
  6. cnts = contours.sort_contours(cnts)[0]
  7. # loop over the contours
  8. for (i, c) in enumerate(cnts):
  9. # draw the bright spot on the image
  10. (x, y, w, h) = cv2.boundingRect(c)
  11. ((cX, cY), radius) = cv2.minEnclosingCircle(c)
  12. cv2.circle(image, (int(cX), int(cY)), int(radius),
  13. (0, 0, 255), 3)
  14. cv2.putText(image, "#{}".format(i + 1), (x, y - 15),
  15. cv2.FONT_HERSHEY_SIMPLEX, 0.45, (0, 0, 255), 2)
  16. # show the output image
  17. cv2.imshow("Image", image)
  18. cv2.waitKey(0)
 最后运行程序,可实现灯光亮点的检测和标记,每个灯泡都被独特地标上了圆圈,圆圈围绕着每个单独的明亮区域,效果如下所示:
本文来源于:Detecting multiple bright spots in an image with Python and OpenCV
文章来源: handsome-man.blog.csdn.net,作者:不脱发的程序猿,版权归原作者所有,如需转载,请联系作者。
原文链接:handsome-man.blog.csdn.net/article/details/109261232
