GaussDB(DWS)与OGG对接
古月磊 发表于 2020/12/30 15:38:47 2020/12/30
【摘要】 GaussDB(DWS)与OGG对接指导
1      概述:
OGG即oracle goldengate是一款oracle公司的ETL工具,下文介绍一下ogg和GaussDB(DWS)的对接和配置方法。
前提:
1、已安装好oracle
2、GaussDB(DWS)已发布成功,并在ecs机器上安装完成客户端,可正常连接使用。
2      Ogg安装配置:
2.1      Oracle端:
解压ogg_for_pg_12.2.0.1.1.zip,提取ggs_Linux_x64_PostgreSQL_64bit.tar到 oracle服务器,目录/home/oracle/ogg
新建for_pg目录:mkdir for_pg
解压:tar –xvf  ggs_Linux_x64_PostgreSQL_64bit.tar  -C  /ogg
配置环境变量:
vim ~/.bashrc
添加
export LD_LIBRARY_PATH=/home/oracle/ogg/for_pg/lib:$LD_LIBRARY_PATH
export PATH=/home/oracle/ogg/for_pg:$PATH
刷新使之生效, source ~/.bashrc
配置Oracle数据库
#启用归档
sys@ORCL>alter database archivelog;
#Forcing logging
sys@ORCL>alter database force logging;
#添加最小附加日志
sys@ORCL>alter database add supplemental log data;
#查看结果
sys@ORCL>select LOG_MODE,FORCE_LOGGING,SUPPLEMENTAL_LOG_DATA_MIN from v$database;
 LOG_MODE                 FORCE_LOG SUPPLEMENTAL_LOG_DATA_MI
ARCHIVELOG               YES       YES
#创建goldengate用户
sys@ORCL>create user oracle identified by oracle;
sys@ORCL>grant dba to oracle;
sys@ORCL>create user ogg identified by ogg;
sys@ORCL>grant dba to ogg;
#创建测试表
登录ogg 用户sqlplus ogg/ogg
 SQL>create table ggtest (col1 number, col2 varchar2(20));
 Table created.
 SQL >alter table ggtest add constraint pk_ggtest primary key(col1);
 Table altered.
#配置ogg参数文件
oracle@SIA1000092630:~/ogg/for_pg> ./ggsci
#配置mgr
GGSCI (SIA1000092630) 1> edit params mgr
 PORT 7809
AUTOSTART ER *
AUTORESTART EXTRACT *,RETRIES 100,WAITMINUTES 2
PURGEOLDEXTRACTS ./dirdat/*,USECHECKPOINTS,MINKEEPDAYS 3
LAGREPORTHOURS 1
LAGINFOMINUTES 30
LAGCRITICALMINUTES 45
SYSLOG ERROR,WARN
#启动mgr
GGSCI (SIA1000092630) 2> start mgr
MGR is already running.
GGSCI (SIA1000092630) 3> info all
 Program     Status      Group       Lag           Time Since Chkpt
 MANAGER     RUNNING
#配置抽取进程参数
GGSCI (SIA1000092630) 4> edit params ext_emp
 EXTRACT EXT_EMP
DYNAMICRESOLUTION
SETENV (NLS_LANG="AMERICAN_AMERICA.WE8MSWIN1252")
SETENV (ORACLE_HOME="/home/oracle/app/oracle/product/11.2.0/dbhome_1")
SETENV (ORACLE_SID="oracle")
USERID oracle,PASSWORD oracle
DISCARDFILE ./dirrpt/ext_emp.dsc,APPEND,MEGABYTES 1024
EXTTRAIL ./dirdat/zx
table ogg.ggtest;
#配置投递进程参数
GGSCI (SIA1000092630) 5> edit params dp_tab
 EXTRACT DP_TAB
PASSTHRU
RMTHOST 10.119.29.232 ,MGRPORT 7809 , COMPRESS
RMTTRAIL ./dirdat/zx
table ogg.ggtest;
#配置投递进程参数
GGSCI (SIA1000092630) 6> edit params defgen
 defsfile ./dirdef/defgen.def
userid oracle, password oracle
table ogg.ggtest;
#增加抽取进程和传输进程
#增加抽取进程和传输进程
GGSCI (SIA1000092630) 7> add extract ext_emp,tranlog,begin now
GGSCI (SIA1000092630) 8> add exttrail ./dirdat/zx, extract ext_emp, megabytes
GGSCI (SIA1000092630) 9> add extract dp_tab, exttrailsource ./dirdat/zx
GGSCI (SIA1000092630) 10> add rmttrail ./dirdat/zx, extract dp_tab, megabytes 200
GGSCI (SIA1000092630) 11> info all
 MANAGER     RUNNING
EXTRACT     STOPPED     DP_TAB      00:00:00      00:00:04
EXTRACT     STOPPED     EXT_EMP     00:00:00      00:00:03
 #添加表的附加日志
GGSCI (SIA1000092630) 12> dblogin userid oracle password oracle
Successfully logged into database.
GGSCI (SIA1000092630) 12> add trandata ogg.ggtest
#生成定义文件
./defgen paramfile ./dirprm/defgen.prm
2.2      PostgreSQL端:
通过ecs机器登录DWS数据库,创建用于同步的数据库、用户和Schema,并创建测试表
postgres=# create database fs;
postgres=# create user fs superuser password 'XXXXXXXX';
postgres=# \c fs
Non-SSL connection (SSL connection is recommended when requiring high-security)
You are now connected to database "fs" as user "luole".
fs=#
fs=# create schema fs;
fs=# create table ggtest(col1 integer not null,col2 varchar(20),constraint pk_ggtest primary key (col1));
安装ogg
tar -xvf ggs_Linux_x64_PostgreSQL_64bit.tar -C for_pg/
配置odbc数据源,goldengate 使用ODBC连接Postgres Database
touch odbc.ini
vim odbc.ini
[ODBC Data Sources]
GG_Postgres=DataDirect 6.1 PostgreSQL Wire Protocol
[ODBC]
IANAAppCodePage=106
InstallDir=/home/oracle/ogg/for_pg
[GG_Postgres]
Driver=/home/oracle/ogg/for_pg/lib/GGpsql25.so
Description=DataDirect 6.1 PostgreSQL Wire Protocol
Database=fs
HostName=127.0.0.1
Servername=127.0.0.1
PortNumber=61052
Port=61052
LogonID=fs
User=fs
Password=Gauss@123
配置环境变量
vim ~/.bashrc
添加
export ODBCINI=/home/oracle/ogg/for_pg/odbc.ini
刷新生效,source ~./bashrc
配置Ogg
./ggsci
GGSCI (SIA1000091994) 1> create subdirs
#配置mgr进程
GGSCI (SIA1000091994) 1> edit params mgr
 PORT 7809
#启动mgr进程
GGSCI (SIA1000091994) 2> start mgr
#把源端生成的定义文件取到目标端
scp oraclehost:$PWD/defgen.def dirdef
此处oraclehost指代oracle服务器ip
#配置复制进程参数
GGSCI (SIA1000091994) 1> edit params rep1
 REPLICAT rep1
SOURCEDEFS ./dirdef/defgen.def
SOURCECHARSET utf-8
SETENV(PGCLIENTENCODING = "UTF8" )
SETENV(ODBCINI="/home/oracle/ogg/for_pg/odbc.ini" )
SETENV(NLS_LANG="AMERICAN_AMERICA.AL32UTF8")
TARGETDB GG_Postgres,userid fs ,password Gauss@123
DISCARDFILE ./dirrpt/rep1.dsc
map ogg.ggtest ,target fs.ggtest;
#添加复制进程
GGSCI (SIA1000091994) 2> add replicat rep1, exttrail ./dirdat/zx,nodbcheckpoint
#测试连接PostgreSQL数据库
GGSCI (SIA1000091994) 3> dblogin sourcedb gg_postgres userid fs
Password:
 2017-07-23 01:13:27  INFO    OGG-03036  Database character set identified as US-ASCII. Locale: en_US.
 2017-07-23 01:13:27  INFO    OGG-03037  Session character set identified as UTF-8.
#如果连接不成功,检查pg_hba.conf配置文件
启动源端和目标端的进程
#Oracle端
GGSCI (SIA1000092630) 1> start *
#PostgreSQL端
GGSCI (SIA1000091994 as fs@gg_postgres) 4> start *
最后可以进行实际测试了,在oracle执行DML语句,在GaussDB(DWS)端查看数据变化
