数据结构 线性表 顺序表
悦来客栈的老板 发表于 2020/12/30 01:50:34 2020/12/30
【摘要】 #include <stdio.h>#include <stdlib.h> #define LIST_INIT_SIZE 100#define LISTLNCREMENT 10#define OK 1#define ERROR 0#define OVERFLOW -2 typedef int ElemType; typedef struct{ Elem...
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #define LIST_INIT_SIZE 100
  4. #define LISTLNCREMENT 10
  5. #define OK 1
  6. #define ERROR 0
  7. #define OVERFLOW -2
  8. typedef int ElemType;
  9. typedef struct
  10. {
  11. ElemType *elem;
  12. int length;
  13. int listsize;
  14. }SqList;
  15. int InitList_Sq(SqList &L)
  16. {
  17. L.elem = (ElemType *) malloc(LIST_INIT_SIZE * sizeof(ElemType));
  18. if (!L.elem)
  19. {
  20. exit(OVERFLOW);
  21. }
  22. L.length = 0;
  23. L.listsize = LIST_INIT_SIZE;
  24. return OK;
  25. }
  26. void Create_Sq(SqList &L, int n)
  27. {
  28. int i;
  29. for (i=0; i<n; i++)
  30. {
  31. scanf("%d",&L.elem[i]);
  32. }
  33. L.length = n;
  34. }
  35. void Display_Sq(SqList L)
  36. {
  37. int i;
  38. for (i=0; i<L.length ; i++)
  39. {
  40. printf("%d ",L.elem[i]);
  41. }
  42. printf("\n");
  43. }
  44. int ListInsert_Sq(SqList &L, int i, ElemType e)
  45. {
  46. ElemType *newbase,*p,*q;
  47. if (i<1 || i>L.length+1)
  48. {
  49. return ERROR;
  50. }
  51. if (L.length >= L.listsize)
  52. {
  53. newbase = (ElemType *)realloc(L.elem ,(L.listsize + LISTLNCREMENT) * sizeof(LISTLNCREMENT));
  54. if (!newbase)
  55. {
  56. exit(OVERFLOW);
  57. }
  58. L.elem = newbase;
  59. L.listsize += LISTLNCREMENT;
  60. }
  61. q = &(L.elem [i-1]);
  62. for (p=&(L.elem[L.length-1]);p>=q;--p)
  63. {
  64. *(p+1) = *p;
  65. }
  66. *q = e;
  67. ++L.length ;
  68. return OK;
  69. }
  70. int ListDel_Sq(SqList &L, int i, ElemType &e)
  71. {
  72. ElemType *p,*q;
  73. if (i<1 || i>L.length+1)
  74. {
  75. return ERROR;
  76. }
  77. p = &(L.elem [i-1]);
  78. e = *p;
  79. q = L.elem + L.length - 1;
  80. for (++p;p<=q;++p)
  81. {
  82. *(p-1) = *p;
  83. }
  84. --L.length ;
  85. return OK;
  86. }
  87. int compare(ElemType i, ElemType j)
  88. {
  89. return (i==j);
  90. }
  91. int LocateElem_Sq(SqList L, ElemType e, int (*compare)(ElemType, ElemType))
  92. {
  93. ElemType *p;
  94. int i = 1;
  95. p = L.elem;
  96. while (i <= L.length && !(*compare)(*p++,e))
  97. {
  98. ++i;
  99. }
  100. if (i<=L.length)
  101. {
  102. return i;
  103. }
  104. else
  105. {
  106. return 0;
  107. }
  108. }
  109. int main()
  110. {
  111. SqList L;
  112. if (!InitList_Sq(L))
  113. {
  114. printf("链表初始化失败!\n");
  115. }
  116. else
  117. {
  118. int i,n,e;
  119. printf("请输入链表的长度:");
  120. scanf("%d",&n);
  121. printf("请输入 %d 个数据: ",n);
  122. Create_Sq(L,n);
  123. printf("您输入的链表是: ");
  124. Display_Sq(L);
  125. printf("请输入您要插入元素的位置(1~%d):",n);
  126. scanf("%d",&i);
  127. printf("请输入您要插入的元素:");
  128. scanf("%d",&e);
  129. ListInsert_Sq(L,i,e);
  130. printf("插入元素 %d 后的链表是:",e);
  131. Display_Sq(L);
  132. printf("请输入您要删除元素的位置(1~%d):",L.length);
  133. scanf("%d",&i);
  134. ListDel_Sq(L,i,e);
  135. printf("您删除的元素是: %d\n",e);
  136. printf("删除元素后的链表是:");
  137. Display_Sq(L);
  138. printf("请输入您要查找的元素:");
  139. scanf("%d",&e);
  140. i = LocateElem_Sq(L,e,compare);
  141. if (!i)
  142. {
  143. printf("链表中不存在该元素!\n");
  144. }
  145. else
  146. {
  147. printf("%d 位于链表的第 %d 个位置!\n",e,i);
  148. }
  149. }
  150. return 0;
  151. }
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/17078305
