数据结构 线性表 顺序表的归并 无序版
悦来客栈的老板 发表于 2020/12/30 01:52:50 2020/12/30
【摘要】 #include <stdio.h>#include <stdlib.h> #define LIST_INIT_SIZE 100#define LISTLNCREMENT 10#define OK 1#define ERROR 0#define OVERFLOW -2 typedef int ElemType; typedef struct{ Elem...
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #define LIST_INIT_SIZE 100
  4. #define LISTLNCREMENT 10
  5. #define OK 1
  6. #define ERROR 0
  7. #define OVERFLOW -2
  8. typedef int ElemType;
  9. typedef struct
  10. {
  11. ElemType *elem;
  12. int length;
  13. int listsize;
  14. }SqList;
  15. int InitList_Sq(SqList &L)
  16. {
  17. L.elem = (ElemType *) malloc(LIST_INIT_SIZE * sizeof(ElemType));
  18. if (!L.elem)
  19. {
  20. exit(OVERFLOW);
  21. }
  22. L.length = 0;
  23. L.listsize = LIST_INIT_SIZE;
  24. return OK;
  25. }
  26. void Create_Sq(SqList &L, int n)
  27. {
  28. int i;
  29. for (i=0; i<n; i++)
  30. {
  31. scanf("%d",&L.elem[i]);
  32. }
  33. L.length = n;
  34. }
  35. void Display_Sq(SqList L)
  36. {
  37. int i;
  38. for (i=0; i<L.length ; i++)
  39. {
  40. printf("%d ",L.elem[i]);
  41. }
  42. printf("\n");
  43. }
  44. int Find(SqList L, ElemType e)
  45. {
  46. int i = 0;
  47. while (i<L.length)
  48. {
  49. if (L.elem[i] == e)
  50. {
  51. break;
  52. }
  53. ++i;
  54. }
  55. if (i == L.length)
  56. {
  57. return 0;
  58. }
  59. return 1;
  60. }
  61. int ListInsert_Sq(SqList &L, int i, ElemType e)
  62. {
  63. ElemType *newbase,*p,*q;
  64. if (i<1 || i>L.length+1)
  65. {
  66. return ERROR;
  67. }
  68. if (L.length >= L.listsize)
  69. {
  70. newbase = (ElemType *)realloc(L.elem ,(L.listsize + LISTLNCREMENT) * sizeof(LISTLNCREMENT));
  71. if (!newbase)
  72. {
  73. exit(OVERFLOW);
  74. }
  75. L.elem = newbase;
  76. L.listsize += LISTLNCREMENT;
  77. }
  78. q = &(L.elem [i-1]);
  79. for (p=&(L.elem[L.length-1]);p>=q;--p)
  80. {
  81. *(p+1) = *p;
  82. }
  83. *q = e;
  84. ++L.length ;
  85. return OK;
  86. }
  87. int GetData(SqList L,int i)
  88. {
  89. if (i<1 || i>L.length+1)
  90. {
  91. return ERROR;
  92. }
  93. else
  94. return L.elem[i-1];
  95. }
  96. void MergeList_Sq(SqList &La, SqList Lb)
  97. {
  98. int i,e;
  99. int n = La.length + 1 ;
  100. int m = Lb.length ;
  101. for (i=1; i<=m; i++)
  102. {
  103. e = GetData(Lb,i);
  104. if (!Find(La,Lb.elem[i-1]))
  105. {
  106. ListInsert_Sq(La,n,e);
  107. ++n;
  108. }
  109. }
  110. }
  111. int main()
  112. {
  113. int n;
  114. SqList La,Lb;
  115. InitList_Sq(La);
  116. InitList_Sq(Lb);
  117. printf("请输入链表La的长度: ");
  118. scanf("%d",&n);
  119. printf("请输入 %d 个数据: ",n);
  120. Create_Sq(La,n);
  121. printf("请输入链表Lb的长度: ");
  122. scanf("%d",&n);
  123. printf("请输入 %d 个数据: ",n);
  124. Create_Sq(Lb,n);
  125. MergeList_Sq(La,Lb);
  126. printf("两个链表归并后的链表是: ");
  127. Display_Sq(La);
  128. return 0;
  129. }
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/17078379
