数据结构 线性表 顺序表的交集
悦来客栈的老板 发表于 2020/12/29 23:15:25 2020/12/29
【摘要】 #include <stdio.h>#include <stdlib.h> #define LIST_INIT_SIZE 100#define LISTLNCREMENT 10#define OK 1#define ERROR 0#define OVERFLOW -2 typedef int ElemType; typedef struct{ Elem...
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #define LIST_INIT_SIZE 100
  4. #define LISTLNCREMENT 10
  5. #define OK 1
  6. #define ERROR 0
  7. #define OVERFLOW -2
  8. typedef int ElemType;
  9. typedef struct
  10. {
  11. ElemType *elem;
  12. int length;
  13. int listsize;
  14. }SqList;
  15. int InitList_Sq(SqList &L)
  16. {
  17. L.elem = (ElemType *) malloc(LIST_INIT_SIZE * sizeof(ElemType));
  18. if (!L.elem)
  19. {
  20. exit(OVERFLOW);
  21. }
  22. L.length = 0;
  23. L.listsize = LIST_INIT_SIZE;
  24. return OK;
  25. }
  26. void Create_Sq(SqList &L, int n)
  27. {
  28. int i;
  29. for (i=0; i<n; i++)
  30. {
  31. scanf("%d",&L.elem[i]);
  32. }
  33. L.length = n;
  34. }
  35. void Display_Sq(SqList L)
  36. {
  37. int i;
  38. for (i=0; i<L.length ; i++)
  39. {
  40. printf("%d ",L.elem[i]);
  41. }
  42. printf("\n");
  43. }
  44. int Find(SqList L, ElemType e)
  45. {
  46. int i = 0;
  47. while (i<L.length)
  48. {
  49. if (L.elem[i] == e)
  50. {
  51. break;
  52. }
  53. ++i;
  54. }
  55. if (i == L.length)
  56. {
  57. return 0;
  58. }
  59. return 1;
  60. }
  61. int ListDel_Sq(SqList &L, int i, ElemType &e)
  62. {
  63. ElemType *p,*q;
  64. if (i<1 || i>L.length+1)
  65. {
  66. return ERROR;
  67. }
  68. p = &(L.elem [i-1]);
  69. e = *p;
  70. q = L.elem + L.length - 1;
  71. for (++p;p<=q;++p)
  72. {
  73. *(p-1) = *p;
  74. }
  75. --L.length ;
  76. return OK;
  77. }
  78. int GetData(SqList L,int i)
  79. {
  80. if (i<0 || i>L.length)
  81. {
  82. return ERROR;
  83. }
  84. else
  85. return L.elem[i-1];
  86. }
  87. void SameinList_Sq(SqList &La, SqList Lb)
  88. {
  89. int i = 1,e;
  90. while (i<=La.length)
  91. {
  92. e = GetData(La,i);
  93. if (!Find(Lb,e))
  94. {
  95. ListDel_Sq(La,i,e);
  96. }
  97. else
  98. {
  99. i++;
  100. }
  101. }
  102. }
  103. int main()
  104. {
  105. int n;
  106. SqList La,Lb;
  107. InitList_Sq(La);
  108. InitList_Sq(Lb);
  109. printf("请输入链表La的长度: ");
  110. scanf("%d",&n);
  111. printf("请输入 %d 个数据: ",n);
  112. Create_Sq(La,n);
  113. printf("请输入链表Lb的长度: ");
  114. scanf("%d",&n);
  115. printf("请输入 %d 个数据: ",n);
  116. Create_Sq(Lb,n);
  117. SameinList_Sq(La,Lb);
  118. if (La.length == 0)
  119. {
  120. printf("两个链表没有相同的元素!\n");
  121. }
  122. else
  123. {
  124. printf("两个链表相同的元素是: ");
  125. Display_Sq(La);
  126. }
  127. return 0;
  128. }
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/17078381
