数据结构 线性表 顺序表合并
悦来客栈的老板 发表于 2020/12/29 23:56:17 2020/12/29
【摘要】 #include <stdio.h>#include <stdlib.h> #define LIST_INIT_SIZE 100#define LISTLNCREMENT 10#define OK 1#define ERROR 0#define OVERFLOW -2 typedef int ElemType; typedef struct{ Elem...
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #define LIST_INIT_SIZE 100
  4. #define LISTLNCREMENT 10
  5. #define OK 1
  6. #define ERROR 0
  7. #define OVERFLOW -2
  8. typedef int ElemType;
  9. typedef struct
  10. {
  11. ElemType *elem;
  12. int length;
  13. int listsize;
  14. }SqList;
  15. int InitList_Sq(SqList &L)
  16. {
  17. L.elem = (ElemType *) malloc(LIST_INIT_SIZE * sizeof(ElemType));
  18. if (!L.elem)
  19. {
  20. exit(OVERFLOW);
  21. }
  22. L.length = 0;
  23. L.listsize = LIST_INIT_SIZE;
  24. return OK;
  25. }
  26. void Create_Sq(SqList &L, int n)
  27. {
  28. int i;
  29. for (i=0; i<n; i++)
  30. {
  31. scanf("%d",&L.elem[i]);
  32. }
  33. L.length = n;
  34. }
  35. void Display_Sq(SqList L)
  36. {
  37. int i;
  38. for (i=0; i<L.length ; i++)
  39. {
  40. printf("%d ",L.elem[i]);
  41. }
  42. printf("\n");
  43. }
  44. int ListInsert_Sq(SqList &L, int i, ElemType e)
  45. {
  46. ElemType *newbase,*p,*q;
  47. if (i<1 || i>L.length+1)
  48. {
  49. return ERROR;
  50. }
  51. if (L.length >= L.listsize)
  52. {
  53. newbase = (ElemType *)realloc(L.elem ,(L.listsize + LISTLNCREMENT) * sizeof(LISTLNCREMENT));
  54. if (!newbase)
  55. {
  56. exit(OVERFLOW);
  57. }
  58. L.elem = newbase;
  59. L.listsize += LISTLNCREMENT;
  60. }
  61. q = &(L.elem [i-1]);
  62. for (p=&(L.elem[L.length-1]);p>=q;--p)
  63. {
  64. *(p+1) = *p;
  65. }
  66. *q = e;
  67. ++L.length ;
  68. return OK;
  69. }
  70. int equal(ElemType i, ElemType j)
  71. {
  72. return (i==j);
  73. }
  74. int LocateElem_Sq(SqList L, ElemType e, int (*compare)(ElemType, ElemType))
  75. {
  76. ElemType *p;
  77. int i = 1;
  78. p = L.elem;
  79. while (i <= L.length && !(*compare)(*p++,e))
  80. {
  81. ++i;
  82. }
  83. if (i<=L.length)
  84. {
  85. return i;
  86. }
  87. else
  88. {
  89. return 0;
  90. }
  91. }
  92. void GetElem(SqList L,int i, ElemType &e)
  93. {
  94. e = L.elem[i-1];
  95. }
  96. void Listunion(SqList &La, SqList Lb)
  97. {
  98. int i,e;
  99. int la_len = La.length ;
  100. int lb_len = Lb.length ;
  101. for (i=1; i<=lb_len; i++)
  102. {
  103. GetElem(Lb,i,e);
  104. if (!LocateElem_Sq(La,e,equal))
  105. {
  106. ListInsert_Sq(La,++la_len, e);
  107. }
  108. }
  109. }
  110. int main()
  111. {
  112. int n;
  113. SqList La,Lb;
  114. InitList_Sq(La);
  115. InitList_Sq(Lb);
  116. printf("请输入链表La的长度: ");
  117. scanf("%d",&n);
  118. printf("请输入 %d 个数据: ",n);
  119. Create_Sq(La,n);
  120. printf("请输入链表Lb的长度: ");
  121. scanf("%d",&n);
  122. printf("请输入 %d 个数据: ",n);
  123. Create_Sq(Lb,n);
  124. printf("合并后的两个链表是:");
  125. Listunion(La,Lb);
  126. Display_Sq(La);
  127. return 0;
  128. }
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/17078387
