数据结构 栈的应用 进制转换
悦来客栈的老板 发表于 2020/12/30 01:06:31 2020/12/30
【摘要】 #include <stdio.h>#include <stdlib.h> #define STACT_INIT_SIZE 100#define STACTINCREMENT 10#define OK 1#define ERROR 0#define OVERFLOW -2 typedef int SElemType; typedef struct...
  1. #include <stdio.h>
  2. #include <stdlib.h>
  3. #define STACT_INIT_SIZE 100
  4. #define STACTINCREMENT 10
  5. #define OK 1
  6. #define ERROR 0
  7. #define OVERFLOW -2
  8. typedef int SElemType;
  9. typedef struct
  10. {
  11. SElemType *base;
  12. SElemType *top;
  13. int stacksize;
  14. }SqStack;
  15. SqStack S;
  16. int InitStack(SqStack &S)
  17. {
  18. S.base = (SElemType *)malloc(STACT_INIT_SIZE * sizeof(SElemType));
  19. if (!S.base)
  20. {
  21. exit(OVERFLOW);
  22. }
  23. S.top = S.base ;
  24. S.stacksize = STACT_INIT_SIZE;
  25. return OK;
  26. }
  27. int Push(SqStack &S, SElemType e)
  28. {
  29. if (S.top - S.base >= S.stacksize)
  30. {
  31. S.base = (SElemType*)realloc(S.base , (S.stacksize + STACTINCREMENT) * sizeof(SElemType));
  32. if (!S.base)
  33. {
  34. exit(OVERFLOW);
  35. }
  36. S.top = S.base + S.stacksize ;
  37. S.stacksize += STACTINCREMENT;
  38. }
  39. *S.top++ = e;
  40. return OK;
  41. }
  42. int Pop(SqStack &S, SElemType &e)
  43. {
  44. if (S.base == S.top)
  45. {
  46. return ERROR;
  47. }
  48. e = *--S.top;
  49. return OK;
  50. }
  51. int StackEmpty(SqStack S)
  52. {
  53. if (S.top == S.base )
  54. {
  55. return 1;
  56. }
  57. return 0;
  58. }
  59. void conversion(int n)
  60. {
  61. int e;
  62. while (n != 0)
  63. {
  64. Push(S,n%8);
  65. n = n/8;
  66. }
  67. while (!StackEmpty(S))
  68. {
  69. Pop(S,e);
  70. printf("%d",e);
  71. }
  72. printf("\n");
  73. }
  74. int main()
  75. {
  76. int n;
  77. printf("请输入一个非负的十进制整数:");
  78. scanf("%d",&n);
  79. printf("十进制数 %d 转换为八进制是:",n);
  80. conversion(n);
  81. return 0;
  82. }
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/17249101
