think python学习心得-(6)利用words.txt来进行填字游戏
ChillRay 发表于 2020/12/30 00:33:25 2020/12/30
【摘要】 练习9-1 fin = open('C://words.txt')for line in fin: word = line.strip() if len(word) >20: print word words.txt被保存在了C盘根目录下。 练习9-2 统计字母表中含有e的单词占有的百分比 fin = open('C://words.txt')count...
练习9-1
  1. fin = open('C://words.txt')
  2. for line in fin:
  3. word = line.strip()
  4. if len(word) >20:
  5. print word
练习9-2
统计字母表中含有e的单词占有的百分比
  2. counter1 = 0
  3. counter2 = 0
  4. def has_no_e(wo):
  5. for i in range(len(wo)):
  6. if wo[i-1]=='e':
  7. return True
  8. for line in fin:
  9. word = line.strip()
  10. flag = has_no_e(word)
  11. counter1=counter1+1
  12. if flag == True:
  13. counter2=counter2+1
  14. counter1=float(counter1)
  15. counter2=float(counter2)
  16. print 100-counter2/counter1*100
利用下标循环实现输入文字中是否存在禁用字母的鉴别
  1. def avoids(word,forbiden):
  2. for i in range(len(forbiden)):
  3. for j in range(len(word)):
  4. if word[j-1]==forbiden[i-1]:
  5. return False
  6. return True
  7. print 'Plesase input forbiden alphabet:'
  8. ban=raw_input('>')
  9. print 'Please input desired word:'
  10. test=raw_input('>>')
  11. print avoids(test,ban)
检测是否是由可用字符组成的
  1. def use_only(word,avaliable):
  2. for i in range(len(word)):
  3. flag=0
  4. for j in range(len(avaliable)):
  5. if word[i-1]==avaliable[j-1]:
  6. flag =1
  7. if flag==0:
  8. return False
  9. return True
  10. print 'Plesase input avaliable alphabet:'
  11. ban=raw_input('>')
  12. print 'Please input desired word:'
  13. test=raw_input('>>')
  14. print use_only(test,ban)
练习9-5
检测alphebat是否被全部使用
  1. def uses_all(word,avaliable):
  2. counter=0
  3. for i in range(len(avaliable)):
  4. flag=0
  5. for j in range(len(word)):
  6. if word[j-1]==avaliable[i-1]:
  7. flag =1
  8. if flag==0:
  9. return False
  10. else:
  11. counter=counter+1
  12. if counter == len(avaliable):
  13. return True
  14. else:
  15. return False
  16. print 'Plesase input avaliable alphabet:'
  17. ban=raw_input('>')
  18. print 'Please input desired word:'
  19. test=raw_input('>>')
  20. print uses_all(test,ban)
  1. def is_abecedarian():
  2. fin = open ('C://words.txt')
  3. counter=0
  4. for line in fin:
  5. flag = 0
  6. for i in range(len(line)-1):
  7. if line[i]<=line[i+1]:
  8. flag=flag+1
  9. if flag==len(line)-2:
  10. counter=counter+1
  11. return counter
  12. print 'The number of abecedarian words in directionary is'
  13. print is_abecedarian()
QNMD车迷天下。。。。不做了
文章来源: zclhit.blog.csdn.net,作者:zclhit_,版权归原作者所有,如需转载,请联系作者。
原文链接:zclhit.blog.csdn.net/article/details/51038066
