JS逆向:猿人学爬虫比赛第一题详细题解
悦来客栈的老板 发表于 2020/12/29 22:51:30 2020/12/29
【摘要】 实战地址 http://match.yuanrenxue.com/match/1 1 抓包分析 ** 打开上面的地址并按下F12,有个debug,选中debug这一行, 右键 never pause here,直接就过了。 再点击 第二页,接口有个m参数: |后面有点像时间戳,查看页面源代码,发现这里: 有好几个** script **标签,关键代码...
实战地址
抓包分析
再点击 第二页,接口有个m参数:
有好几个** script **标签,关键代码扣出来后整理一波:
var timestamp = Date.parse(new Date());
var m = oo0O0(timestamp.toString()) + window.f;
var list = { "page": window.page, "m": m + '丨' + timestamp / 1000
由 | 字符拼接,后面是时间戳,那不是这里还是哪里?
那就看** oo0O0** 这个函数,抠出来:
function oo0O0(mw) { window.b = ''; for (var i = 0, len = window.a.length; i < len; i++) { console.log(window.a[i]); window.b += String[document.e + document.g](window.a[i][document.f + document.h]() - i - window.c) } var U = ['W5r5W6VdIHZcT8kU', 'WQ8CWRaxWQirAW==']; var J = function(o, E) { o = o - 0x0; var N = U[o]; if (J['bSSGte'] === undefined) { var Y = function(w) { var m = 'abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789+/=' , T = String(w)['replace'](/=+$/, ''); var A = ''; for (var C = 0x0, b, W, l = 0x0; W = T['charAt'](l++); ~W && (b = C % 0x4 ? b * 0x40 + W : W, C++ % 0x4) ? A += String['fromCharCode'](0xff & b >> (-0x2 * C & 0x6)) : 0x0) { W = m['indexOf'](W) } return A }; var t = function(w, m) { var T = [], A = 0x0, C, b = '', W = ''; w = Y(w); for (var R = 0x0, v = w['length']; R < v; R++) { W += '%' + ('00' + w['charCodeAt'](R)['toString'](0x10))['slice'](-0x2) } w = decodeURIComponent(W); var l; for (l = 0x0; l < 0x100; l++) { T[l] = l } for (l = 0x0; l < 0x100; l++) { A = (A + T[l] + m['charCodeAt'](l % m['length'])) % 0x100, C = T[l], T[l] = T[A], T[A] = C } l = 0x0, A = 0x0; for (var L = 0x0; L < w['length']; L++) { l = (l + 0x1) % 0x100, A = (A + T[l]) % 0x100, C = T[l], T[l] = T[A], T[A] = C, b += String['fromCharCode'](w['charCodeAt'](L) ^ T[(T[l] + T[A]) % 0x100]) } return b }; J['luAabU'] = t, J['qlVPZg'] = {}, J['bSSGte'] = !![] } var H = J['qlVPZg'][o]; return H === undefined ? (J['TUDBIJ'] === undefined && (J['TUDBIJ'] = !![]), N = J['luAabU'](N, E), J['qlVPZg'][o] = N) : N = H, N }; eval(atob(window['b'])[J('0x0', ']dQW')](J('0x1', 'GTu!'), '\x27' + mw + '\x27')); return ''
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
注意返回值是一个空字符串,所以这行代码:
m的值就是 window.f,函数里面有个eval,看看是干嘛的,控制台输入:
atob(window['b'])
base64解码后是一段代码:
var hexcase = 0;
var b64pad = "";
var chrsz = 16;
function hex_md5(a) { return binl2hex(core_md5(str2binl(a), a.length * chrsz))
function b64_md5(a) { return binl2b64(core_md5(str2binl(a), a.length * chrsz))
function str_md5(a) { return binl2str(core_md5(str2binl(a), a.length * chrsz))
function hex_hmac_md5(a, b) { return binl2hex(core_hmac_md5(a, b))
function b64_hmac_md5(a, b) { return binl2b64(core_hmac_md5(a, b))
function str_hmac_md5(a, b) { return binl2str(core_hmac_md5(a, b))
function md5_vm_test() { return hex_md5("abc") == "900150983cd24fb0d6963f7d28e17f72"
function core_md5(p, k) { p[k >> 5] |= 128 << ((k) % 32); p[(((k + 64) >>> 9) << 4) + 14] = k; var o = 1732584193; var n = -271733879; var m = -1732584194; var l = 271733878; for (var g = 0; g < p.length; g += 16) { var j = o; var h = n; var f = m; var e = l; o = md5_ff(o, n, m, l, p[g + 0], 7, -680976936); l = md5_ff(l, o, n, m, p[g + 1], 12, -389564586); m = md5_ff(m, l, o, n, p[g + 2], 17, 606105819); n = md5_ff(n, m, l, o, p[g + 3], 22, -1044525330); o = md5_ff(o, n, m, l, p[g + 4], 7, -176418897); l = md5_ff(l, o, n, m, p[g + 5], 12, 1200080426); m = md5_ff(m, l, o, n, p[g + 6], 17, -1473231341); n = md5_ff(n, m, l, o, p[g + 7], 22, -45705983); o = md5_ff(o, n, m, l, p[g + 8], 7, 1770035416); l = md5_ff(l, o, n, m, p[g + 9], 12, -1958414417); m = md5_ff(m, l, o, n, p[g + 10], 17, -42063); n = md5_ff(n, m, l, o, p[g + 11], 22, -1990404162); o = md5_ff(o, n, m, l, p[g + 12], 7, 1804660682); l = md5_ff(l, o, n, m, p[g + 13], 12, -40341101); m = md5_ff(m, l, o, n, p[g + 14], 17, -1502002290); n = md5_ff(n, m, l, o, p[g + 15], 22, 1236535329); o = md5_gg(o, n, m, l, p[g + 1], 5, -165796510); l = md5_gg(l, o, n, m, p[g + 6], 9, -1069501632); m = md5_gg(m, l, o, n, p[g + 11], 14, 643717713); n = md5_gg(n, m, l, o, p[g + 0], 20, -373897302); o = md5_gg(o, n, m, l, p[g + 5], 5, -701558691); l = md5_gg(l, o, n, m, p[g + 10], 9, 38016083); m = md5_gg(m, l, o, n, p[g + 15], 14, -660478335); n = md5_gg(n, m, l, o, p[g + 4], 20, -405537848); o = md5_gg(o, n, m, l, p[g + 9], 5, 568446438); l = md5_gg(l, o, n, m, p[g + 14], 9, -1019803690); m = md5_gg(m, l, o, n, p[g + 3], 14, -187363961); n = md5_gg(n, m, l, o, p[g + 8], 20, 1163531501); o = md5_gg(o, n, m, l, p[g + 13], 5, -1444681467); l = md5_gg(l, o, n, m, p[g + 2], 9, -51403784); m = md5_gg(m, l, o, n, p[g + 7], 14, 1735328473); n = md5_gg(n, m, l, o, p[g + 12], 20, -1921207734); o = md5_hh(o, n, m, l, p[g + 5], 4, -378558); l = md5_hh(l, o, n, m, p[g + 8], 11, -2022574463); m = md5_hh(m, l, o, n, p[g + 11], 16, 1839030562); n = md5_hh(n, m, l, o, p[g + 14], 23, -35309556); o = md5_hh(o, n, m, l, p[g + 1], 4, -1530992060); l = md5_hh(l, o, n, m, p[g + 4], 11, 1272893353); m = md5_hh(m, l, o, n, p[g + 7], 16, -155497632); n = md5_hh(n, m, l, o, p[g + 10], 23, -1094730640); o = md5_hh(o, n, m, l, p[g + 13], 4, 681279174); l = md5_hh(l, o, n, m, p[g + 0], 11, -358537222); m = md5_hh(m, l, o, n, p[g + 3], 16, -722881979); n = md5_hh(n, m, l, o, p[g + 6], 23, 76029189); o = md5_hh(o, n, m, l, p[g + 9], 4, -640364487); l = md5_hh(l, o, n, m, p[g + 12], 11, -421815835); m = md5_hh(m, l, o, n, p[g + 15], 16, 530742520); n = md5_hh(n, m, l, o, p[g + 2], 23, -995338651); o = md5_ii(o, n, m, l, p[g + 0], 6, -198630844); l = md5_ii(l, o, n, m, p[g + 7], 10, 11261161415); m = md5_ii(m, l, o, n, p[g + 14], 15, -1416354905); n = md5_ii(n, m, l, o, p[g + 5], 21, -57434055); o = md5_ii(o, n, m, l, p[g + 12], 6, 1700485571); l = md5_ii(l, o, n, m, p[g + 3], 10, -1894446606); m = md5_ii(m, l, o, n, p[g + 10], 15, -1051523); n = md5_ii(n, m, l, o, p[g + 1], 21, -2054922799); o = md5_ii(o, n, m, l, p[g + 8], 6, 1873313359); l = md5_ii(l, o, n, m, p[g + 15], 10, -30611744); m = md5_ii(m, l, o, n, p[g + 6], 15, -1560198380); n = md5_ii(n, m, l, o, p[g + 13], 21, 1309151649); o = md5_ii(o, n, m, l, p[g + 4], 6, -145523070); l = md5_ii(l, o, n, m, p[g + 11], 10, -1120210379); m = md5_ii(m, l, o, n, p[g + 2], 15, 718787259); n = md5_ii(n, m, l, o, p[g + 9], 21, -343485551); o = safe_add(o, j); n = safe_add(n, h); m = safe_add(m, f); l = safe_add(l, e) } return Array(o, n, m, l)
function md5_cmn(h, e, d, c, g, f) { return safe_add(bit_rol(safe_add(safe_add(e, h), safe_add(c, f)), g), d)
function md5_ff(g, f, k, j, e, i, h) { return md5_cmn((f & k) | ((~f) & j), g, f, e, i, h)
function md5_gg(g, f, k, j, e, i, h) { return md5_cmn((f & j) | (k & (~j)), g, f, e, i, h)
function md5_hh(g, f, k, j, e, i, h) { return md5_cmn(f ^ k ^ j, g, f, e, i, h)
function md5_ii(g, f, k, j, e, i, h) { return md5_cmn(k ^ (f | (~j)), g, f, e, i, h)
function core_hmac_md5(c, f) { var e = str2binl(c); if (e.length > 16) { e = core_md5(e, c.length * chrsz) } var a = Array(16) , d = Array(16); for (var b = 0; b < 16; b++) { a[b] = e[b] ^ 909522486; d[b] = e[b] ^ 1549556828 } var g = core_md5(a.concat(str2binl(f)), 512 + f.length * chrsz); return core_md5(d.concat(g), 512 + 128)
function safe_add(a, d) { var c = (a & 65535) + (d & 65535); var b = (a >> 16) + (d >> 16) + (c >> 16); return (b << 16) | (c & 65535)
function bit_rol(a, b) { return (a << b) | (a >>> (32 - b))
function str2binl(d) { var c = Array(); var a = (1 << chrsz) - 1; for (var b = 0; b < d.length * chrsz; b += chrsz) { c[b >> 5] |= (d.charCodeAt(b / chrsz) & a) << (b % 32) } return c
function binl2str(c) { var d = ""; var a = (1 << chrsz) - 1; for (var b = 0; b < c.length * 32; b += chrsz) { d += String.fromCharCode((c[b >> 5] >>> (b % 32)) & a) } return d
function binl2hex(c) { var b = hexcase ? "0123456789ABCDEF" : "0123456789abcdef"; var d = ""; for (var a = 0; a < c.length * 4; a++) { d += b.charAt((c[a >> 2] >> ((a % 4) * 8 + 4)) & 15) + b.charAt((c[a >> 2] >> ((a % 4) * 8)) & 15) } return d
function binl2b64(d) { var c = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/"; var f = ""; for (var b = 0; b < d.length * 4; b += 3) { var e = (((d[b >> 2] >> 8 * (b % 4)) & 255) << 16) | (((d[b + 1 >> 2] >> 8 * ((b + 1) % 4)) & 255) << 8) | ((d[b + 2 >> 2] >> 8 * ((b + 2) % 4)) & 255); for (var a = 0; a < 4; a++) { if (b * 8 + a * 6 > d.length * 32) { f += b64pad } else { f += c.charAt((e >> 6 * (3 - a)) & 63) } } } return f
;window.f = hex_md5(mwqqppz)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
噢,window.f 原来在这里赋值的。把变量U和J分别在控制台运行下,再看下面的两个值:
原来就是把 **hex_md5 **的参数替换成 oo0O0 函数的参数。
逻辑清晰了,就是改造代码了。
改造代码,运行结果
将上面的代码最后一行:
变成:
var timestamp=Date.parse(new Date());
f = hex_md5(timestamp.toString()) + "|" + timestamp/1000;;
console.log(f)
保存为js文件,运行,得到结果:
基本没啥难度吧。
欢迎关注本人微信公众号共同探讨:
文章来源: blog.csdn.net,作者:悦来客栈的老板,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq523176585/article/details/109404442
