【Windows】重磅!Windows发布新命令行终端工具 - Windows Terminal(GitHub上万星!)
王博Kings 发表于 2020/12/29 23:01:28 2020/12/29
【摘要】   项目网址: https://github.com/microsoft/Terminal 项目宣传视频: https://weibo.com/tv/v/Ht6LevF0M?fid=1034:4369374836899465  注意安装时: This repository uses git submodules for some of its dependenci...
项目网址:
项目宣传视频:
 注意安装时:
This repository uses git submodules for some of its dependencies. To make sure submodules are restored or updated, be sure to run the following prior to building:
git submodule update --init --recursive
OpenConsole.sln may be built from within Visual Studio or from the command-line using MSBuild. To build from the command line:
nuget restore OpenConsole.sln
msbuild OpenConsole.sln
 支持x86、x64和arm64,最低要求Windows 10 Build 18382版本。
文章来源: kings.blog.csdn.net,作者:人工智能博士,版权归原作者所有,如需转载,请联系作者。
原文链接:kings.blog.csdn.net/article/details/89928317
