数据分析高级教程(三)
Python爱好者 发表于 2020/12/29 01:26:00 2020/12/29
【摘要】 工作流单元测试 1、工作流定义配置上传 [hadoop@hdp-node-01  wf-oozie]$ hadoop fs -put hive2-etl /user/hadoop/oozie/myapps/[hadoop@hdp-node-01  wf-oozie]$ hadoop fs -put hive2-dw /user/hadoop/oozi...
640?wx_fmt=gif
工作流单元测试
1、工作流定义配置上传
[hadoop@hdp-node-01  wf-oozie]$ hadoop fs -put hive2-dw /user/hadoop/oozie/myapps/
[hadoop@hdp-node-01  wf-oozie]$ ll
total 12
drwxrwxr-x. 2 hadoop hadoop  4096 Nov 23 16:32 hive2-dw
drwxrwxr-x. 2 hadoop  hadoop 4096 Nov 23 16:32 hive2-etl
drwxrwxr-x. 3 hadoop  hadoop 4096 Nov 23 11:24 weblog
[hadoop@hdp-node-01  wf-oozie]$ export OOZIE_URL=http://localhost:11000/oozie
2、工作流单元提交启动
oozie job -D inpath=/weblog/input -D outpath=/weblog/outpre-config weblog/job.properties  -run
启动etl的hive工作流
oozie job -config hive2-etl/job.properties  -run
启动pvs统计的hive工作流
oozie job -config hive2-dw/job.properties  -run
3、工作流coordinator配置(片段)
多个工作流job用coordinator组织协调:
[hadoop@hdp-node-01  hive2-etl]$ ll
total 28
-rw-rw-r--. 1 hadoop  hadoop  265 Nov 13 16:39  config-default.xml
-rw-rw-r--. 1 hadoop  hadoop  512 Nov 26 16:43  coordinator.xml
-rw-rw-r--. 1 hadoop  hadoop  382 Nov 26 16:49 job.properties
drwxrwxr-x. 2 hadoop  hadoop 4096 Nov 27 11:26 lib
-rw-rw-r--. 1 hadoop  hadoop 1910 Nov 23 17:49 script.q
-rw-rw-r--. 1 hadoop  hadoop  687 Nov 23 16:32 workflow.xml
l  config-default.xml
<configuration>
<property>
<name>jobTracker</name>
<value>hdp-node-01:8032</value>
</property>
<property>
<name>nameNode</name>
<value>hdfs://hdp-node-01:9000</value>
</property>
<property>
<name>queueName</name>
<value>default</value>
</property>
</configuration>
l  job.properties
user.name=hadoop
oozie.use.system.libpath=true
oozie.libpath=hdfs://hdp-node-01:9000/user/hadoop/share/lib
oozie.wf.application.path=hdfs://hdp-node-01:9000/user/hadoop/oozie/myapps/hive2-etl/
l  workflow.xml
<workflow-app  xmlns="uri:oozie:workflow:0.5" name="hive2-wf">
<start  to="hive2-node"/>
<action  name="hive2-node">
<hive2  xmlns="uri:oozie:hive2-action:0.1">
<job-tracker>${jobTracker}</job-tracker>
<name-node>${nameNode}</name-node>
<configuration>
<property>
<name>mapred.job.queue.name</name>
<value>${queueName}</value>
</property>
</configuration>
<jdbc-url>jdbc:hive2://hdp-node-01:10000</jdbc-url>
<script>script.q</script>
<param>input=/weblog/outpre2</param>
</hive2>
<ok  to="end"/>
<error  to="fail"/>
</action>
<kill  name="fail">
<message>Hive2  (Beeline) action failed, error message[${wf:errorMessage(wf:lastErrorNode())}]</message>
</kill>
<end  name="end"/>
</workflow-app>
l  coordinator.xml
<coordinator-app  name="cron-coord" frequency="${coord:minutes(5)}"  start="${start}" end="${end}"  timezone="Asia/Shanghai"  xmlns="uri:oozie:coordinator:0.2">
<action>
<workflow>
<app-path>${workflowAppUri}</app-path>
<configuration>
<property>
<value>${jobTracker}</value>
</property>
<property>
<value>${nameNode}</value>
</property>
<property>
</property>
</configuration>
</workflow>
</action>
</coordinator-app>
模块开发——数据展示
在企业的数据分析系统中,前端展现工具有很多,
l 独立部署专门系统的方式:以BusinessObjects(BO,Crystal Report),Heperion(Brio),Cognos等国外产品为代表的,它们的服务器是单独部署的,与应用程序之间通过某种协议沟通信息
l 有WEB程序展现方式:通过独立的或者嵌入式的java web系统来读取报表统计结果,以网页的形式对结果进行展现,如,100%纯Java的润乾报表
本日志分析项目采用自己开发web程序展现的方式
u Web展现程序采用的技术框架:
Jquery + Echarts + springmvc + spring + mybatis + mysql
u 展现的流程:
1.        使用ssh从mysql中读取要展现的数据
2.        使用json格式将读取到的数据返回给页面
3.        在页面上用echarts对json解析并形成图标
Web程序工程结构
采用maven管理工程,引入SSH框架依赖及jquery+echarts的js库
640?wx_fmt=png
Web程序的实现代码
采用典型的MVC架构实现
页面
HTML + JQUERY + ECHARTS
Controller
SpringMVC
Service
Service
DAO
Mybatis
数据库
Mysql
代码详情见项目工程
代码示例:ChartServiceImpl
@Service("chartService")
public class ChartServiceImpl implements IChartService {
                @Autowired
                IEchartsDao  iEchartsDao;
                public  EchartsData getChartsData() {
                                List<Integer> xAxiesList  = iEchartsDao.getXAxiesList("");
                                List<Integer>  pointsDataList = iEchartsDao.getPointsDataList("");
                                EchartsData data = new  EchartsData();
                                ToolBox toolBox =  EchartsOptionUtil.getToolBox();
                                Serie serie =  EchartsOptionUtil.getSerie(pointsDataList);
                                ArrayList<Serie> series  = new ArrayList<Serie>();
                                series.add(serie);
                                List<XAxi> xAxis =  EchartsOptionUtil.getXAxis(xAxiesList);
                                List<YAxi> yAxis = EchartsOptionUtil.getYAxis();
                                HashMap<String, String>  title = new HashMap<String, String>();
                                title.put("text",  "pvs");
                                title.put("subtext",  "超级pvs");
                                HashMap<String, String>  tooltip = new HashMap<String, String>();
                                tooltip.put("trigger",  "axis");
                                HashMap<String,  String[]> legend = new HashMap<String, String[]>();
                                legend.put("data",  new String[]{"pv统计"});
                                data.setTitle(title);
                                data.setTooltip(tooltip);
                                data.setLegend(legend);
                                data.setToolbox(toolBox);
                                data.setCalculable(true);
                                data.setxAxis(xAxis);
                                data.setyAxis(yAxis);
                                data.setSeries(series);
                                return data;
                public  List<HashMap<String, Integer>> getGaiKuangList(String date)  throws ParseException{
                                HashMap<String, Integer>  gaiKuangToday = iEchartsDao.getGaiKuang(date);
                                SimpleDateFormat sf = new  SimpleDateFormat("MMdd");
                                Date parse = sf.parse(date);
                                Calendar calendar =  Calendar.getInstance();
                                calendar.setTime(parse);
                                calendar.add(Calendar.DAY_OF_MONTH,  -1);
                                Date before =  calendar.getTime();
                                String beforeString =  sf.format(before);
                                System.out.println(beforeString);
                                HashMap<String, Integer>  gaiKuangBefore = iEchartsDao.getGaiKuang(beforeString);
                                ArrayList<HashMap<String,  Integer>> gaiKuangList = new ArrayList<HashMap<String,  Integer>>();
                                gaiKuangList.add(gaiKuangToday);
                                gaiKuangList.add(gaiKuangBefore);
                                return gaiKuangList;
                public  static void main(String[] args) {
                                ChartServiceImpl  chartServiceImpl = new ChartServiceImpl();
                                EchartsData chartsData =  chartServiceImpl.getChartsData();
                                Gson gson = new Gson();
                                String json =  gson.toJson(chartsData);
                                System.out.println(json);
Web程序的展现效果
网站概况
640?wx_fmt=png
640?wx_fmt=png
640?wx_fmt=png
流量分析
640?wx_fmt=png
640?wx_fmt=png
来源分析
640?wx_fmt=png
640?wx_fmt=png
访客分析
640?wx_fmt=png
OVER,整个数据项目实战到此结束!
640?wx_fmt=jpeg
听说有气质的人都会关注这个公众号!
640?wx_fmt=jpeg
文章来源: blog.csdn.net,作者:敲代码的灰太狼,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/tongtongjing1765/article/details/100581626
