Linux下代码行查询,显示文件树,搜索文件
IM_STONE 发表于 2020/12/28 22:58:06 2020/12/28
【摘要】 自己刚学习Linux时,写的一个小工具; 1,查询写了多少行C/C++代码; 2,搜索文件的绝对路径; 3,显示文件树。 /*************************** * *链栈stack.c * ************************/ //元素节点 typedef struct Node { char *str; struct N...
1,查询写了多少行C/C++代码;
2,搜索文件的绝对路径;
3,显示文件树。
 *链栈stack.c
//元素节点
typedef struct Node
{ char *str; struct Node *next; struct Node *fron;
}Node;
//栈的头节点
typedef struct Snode
{ Node *next; Node *end;
}Snode,*stack;
//创建一个节点
Node *Buynode(char *val)
{ int len = strlen(val); Node *p = (Node*)malloc(sizeof(Node)); assert(p != NULL); p->next = NULL; p->fron=NULL; p->str = (char*)malloc(sizeof(char)*(len+1)); strcpy(p->str, val); return p;
//初始化一个栈
void Init(stack a)
{ a->next = NULL; a->end = NULL;
//入栈
void push(stack a, char *val)
{ Node*p = Buynode(val); if(a->next == NULL) { a->next = p; a->end = p; } else { a->end->next = p; a->end = p; } }
//查找倒数第二个节点
Node*search(stack a)
{ if(a->next==NULL || a->next->next==NULL) { return NULL; } else { Node*p=a->next; for(;p->next->next != NULL; p=p->next) { ; } return p; } }
//出栈
void pop(stack a)
{ if(a->next == NULL) { printf("栈已空\n"); a->end = NULL; return ; } if(a->next->next==NULL) { free(a->end); a->next->next=NULL; a->end = NULL; return; } Node*p = a->end; Node*q = a->next; for(;q->next->next != NULL; q=q->next) { ; } q->next = NULL; free(p); a->end = q; /* if(a->next == NULL) { printf("栈已空!\n"); return; } Node *p = a->end; a->end = search(a); free(p); */
void Destroystack(stack a)
{ Node*p; while( a->next != NULL ) { p = a->next; a->next=a->next->next; free(p); } a->end = NULL; a->next = NULL;
//显示一个栈
void show(stack a)
{ Node*p = a->next; for(; p != NULL; p=p->next) { printf("%s/",p->str); } }
Snode b;
stack a=&b;
//遍历文件夹,查找同名文件
void Searchpath( char *dir,  char *buff)
{ push(a,dir); DIR *dp; struct stat statbuff; struct dirent *entry; if( (dp=opendir(dir))==NULL ) { pop(a);//必不可少 return ; } chdir(dir); while( (entry = readdir(dp)) != NULL ) { lstat(entry->d_name, &statbuff); if(S_ISDIR(statbuff.st_mode)) { if((strcmp(".",entry->d_name))==0  || strcmp("..",entry->d_name)==0 ) { continue; } if(strcmp(entry->d_name, buff)==0) { show(a); printf("%s\n",buff); } //  printf("%s\n",entry->d_name); Searchpath(entry->d_name, buff); } else { if(strcmp(entry->d_name, buff)==0) { show(a); printf("%s\n",entry->d_name); } //  printf("%s\n",entry->d_name); } } pop(a); chdir(".."); closedir(dp); }
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
*codeline query tool
*version 3.0  done
#include<unistd.h>
#include<stdio.h>
#include<assert.h>
#include<stdlib.h>
#include<string.h>
#include<dirent.h>
#include<sys/stat.h>
#include<fcntl.h>
#include<time.h>
#include"stack.c"
static int codecount=0;
static int i=0;
static int codecount2=0;
//以最后2或3或4位来判断文件是否是要查找的.c .h .cpp文件
int mystrcmp(char*str)
{ int len=strlen(str); if(len<3) { return -1; } if((*(str+len-1)=='h') && (*(str+len-2)=='.')) { return 0; } else if((*(str+len-1)=='c') && (*(str+len-2)=='.')) { return 0; } /* 此段代码为测试C#用;
  else if((*(str+len-1)=='s') && (*(str+len-2)=='c')&& (*(str+len-3)=='.')) { return 0; }
*/ else if((len>6) && (*(str+len-1)=='p') && (*(str+len-2)=='p') && (*(str+len-3)=='c') && (*(str+len-4)=='.')) { return 0; } return -1;
//遍历文件夹,输出目录树
void myprintdir(char *dir, int depth)
{ int in; char c; DIR *dp; char *buff; struct dirent *entry; struct stat statbuff; if((dp = opendir(dir) )== NULL) { printf("cannot open directory:%s\n",dir); return; } chdir(dir); while((entry = readdir(dp)) != NULL) { lstat(entry->d_name, &statbuff); if(S_ISDIR(statbuff.st_mode))//判断是否为目录 { if(strcmp(".",entry->d_name)==0 || //排除掉.和.. strcmp("..",entry->d_name)==0  ) { continue; } printf("%*s%s/\n",depth," ", entry->d_name); myprintdir(entry->d_name,depth+6); } else { printf("%*s%s\n",depth," ",entry->d_name); } } chdir(".."); closedir(dp);
} //显示出每个c/c++代码的详细信息
//文件的大小,文件的权限,文件的修改日期
void Mydetaildir(char *dir)
{ int codeline=0; int i=0; int readnu; char buff[1024]; memset(buff,0,1024); int in; DIR *dp; struct stat statbuff; struct dirent *entry; if( (dp=opendir(dir))==NULL ) { printf("%s cannot open !\n",dir); return; } chdir(dir);//进入目录类似shell里的cd while( (entry=readdir(dp)) != NULL ) { lstat(entry->d_name, &statbuff); if(S_ISDIR(statbuff.st_mode)) { if(strcmp(".",entry->d_name)==0 || strcmp("..",entry->d_name)==0) { continue; } Mydetaildir(entry->d_name); } if(S_ISREG(statbuff.st_mode))//判断是否为文件 { if(mystrcmp(entry->d_name)==0) { in=open(entry->d_name,O_RDONLY); if(in == -1) { printf("%s open error!",entry->d_name); } while( (readnu= read(in,buff,1024)) )//读到buff里; { for(i=0; i<readnu; ++i) { if( buff[i]=='\n') { codeline++; } } } printf("%-s---codeline: %d\n",entry->d_name,codeline); codecount2+=codeline; codeline = 0; close(in); } } } chdir(".."); closedir(dp);
//遍历文件夹,统计总的代码行;
void myreaddir(char *dir)
{ int i=0; int in; int readnu = 0; char buff[1024]; memset(buff, 0 , 1024); DIR *dp; struct dirent *entry; struct stat statbuff; if((dp = opendir(dir) )== NULL) { printf("%s:open error\n",dir); return; } chdir(dir);//进入指定目录 while((entry = readdir(dp))!= NULL) { lstat(entry->d_name,&statbuff);//通过文件名获取文件信息 if(S_ISDIR(statbuff.st_mode)) { if(strcmp(entry->d_name,".")==0 || strcmp(entry->d_name,"..")==0) { continue; } //  printf("%s/\n",entry->d_name); myreaddir(entry->d_name); } if(S_ISREG(statbuff.st_mode)) { if(mystrcmp(entry->d_name)==0) { //   printf("file name==%s  ",entry->d_name); in=open(entry->d_name ,O_RDONLY); if(in == -1) { printf("%s open error!\n",entry->d_name); return ; } while(readnu=read(in, buff , 1024) ) { for(i=0; i<readnu; ++i)//i一定要小于readnu,而不是1024; { if(buff[i]=='\n') { codecount++; } } } close(in); } } } chdir(".."); closedir(dp);
//主菜单
void menu()
{ int flg = 1; int choice = 9; while(flg) { printf("\n"); printf("\033[;31m ------------------------------\n"); printf("| 1----查询我的C/C++代码行 |\n");  //done printf("| 2----查询每个.h .c .cpp的行数|\n");//done printf("| 3----查询文件树 |\n");//done printf("| 4----查询文件的绝对路径 |\n"); printf("| 0----退出 |\n"); printf(" ----------------------------\033[0m "); printf("\n\n\n"); printf("请输入您的选择:"); scanf("%d",&choice); switch(choice) { case 0://退出 { printf("\033[;32m感谢您的使用!!bye bye!!\033[0m\n"); printf("\n"); exit(0); break; } case 1://查询C C++代码行; { char mydir[100]; printf("请输入您的文件夹路径:"); scanf("%s",mydir); myreaddir(mydir); printf("\033[;31m 代码总行数:%d\033[0m",codecount); codecount = 0; break; } case 3://查询文件树; { char mydir[100]; printf("请输入您的文件夹路径:"); scanf("%s",mydir); myprintdir(mydir,0); break; } case 2://查询每个.c.h.cpp文件的详细信息; { char mydir[100]; printf("请输入您的文件夹路径:"); scanf("%s",mydir); Mydetaildir(mydir); printf("\033[;32m此文件夹下共有代码:%d  行\033[0m\n", codecount2); break; } case 4://查询文件的绝对路径 { Node*p; char buff[20]; printf("请输入您要查询的文件夹名:"); scanf("%s",buff); Searchpath("/",buff); a->next=NULL; a->end=NULL; show(a); break; } default: { printf("\033[;31m输入有误! 请重新输入!!\033[0m"); menu(); break; } } }
int main()
{ Init(a); printf("\n\n"); printf("\033[;32m欢迎进入Codeline Query Tool !\033[0m\n"); menu(); exit(0);
} //Bot
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
不足之处,请多指教;
文章来源: blog.csdn.net,作者:IM-STONE,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/doubleintfloat/article/details/52433700
