resnet算法实现
Nikolas 发表于 2020/12/28 15:18:21 2020/12/28
【摘要】 使用tensorflow2实现resnet算法
## 1.导入依赖包
```python
from tensorflow import keras
import tensorflow as tf
import numpy as np
import pandas as pd
import os
from sklearn.model_selection import train_test_split
from tensorflow.keras.layers import Conv2D, BatchNormalization, Activation
from tensorflow.keras import Model
## 2.导入数据集
```python
train = pd.read_csv('./data/fashion_train.csv')
test = pd.read_csv('./data/fashion_test.csv')
print(train.shape, test.shape)
## 3.数据预处理
```python
input_shape = (28, 28, 1)
x = np.array(train.iloc[:, 1:])
y = keras.utils.to_categorical(np.array(train.iloc[:, 0]))
x_train, x_val, y_train, y_val = train_test_split(x, y, test_size=0.2)
print(x_train.shape, y_train.shape)
x_test = np.array(test.iloc[:, 0:])
x_train = x_train.reshape(x_train.shape[0], 28, 28, 1)
x_val = x_val.reshape(x_val.shape[0], 28, 28, 1)
x_test = x_test.reshape(x_test.shape[0], 28, 28, 1)
x_train = x_train.astype('float32')
x_val = x_val.astype('float32')
x_test = x_test.astype('float32')
x_train /= 255
x_val /= 255
x_test /= 255
batch_size = 64
classes = 10
epochs = 5
## 4.建立模型
```python
class ResnetBlock(Model):
    def __init__(self, filters, strides=1, residual_path=False):
        super(ResnetBlock, self).__init__()
        self.filters = filters
        self.strides = strides
        self.residual_path = residual_path
        self.c1 = Conv2D(filters, (3, 3), strides=strides, padding='same', use_bias=False)
        self.b1 = BatchNormalization()
        self.a1 = Activation('relu')
        self.c2 = Conv2D(filters, (3, 3), strides=1, padding='same', use_bias=False)
        self.b2 = BatchNormalization()
        if residual_path:
            self.down_c1 = Conv2D(filters, (1, 1), strides=strides, padding='same', use_bias=False)
            self.down_b1 = BatchNormalization()
        self.a2 = Activation('relu')
    def call(self, inputs):
        residual = inputs
        x = self.c1(inputs)
        x = self.b1(x)
        x = self.a1(x)
        x = self.c2(x)
        y = self.b2(x)
        if self.residual_path:
            residual = self.down_c1(inputs)
            residual = self.down_b1(residual)
        out = self.a2(y + residual)
        return out
block_list = [2, 2, 2, 2]
initial_filters = 64
num_blocks = len(block_list)
block_list = block_list
out_filters = initial_filters
blocks = tf.keras.models.Sequential()
for block_id in range(len(block_list)):
    for layer_id in range(block_list[block_id]):
        if block_id != 0 and layer_id == 0:
            block = ResnetBlock(out_filters, strides=2, residual_path=True)
        else:
            block = ResnetBlock(out_filters, residual_path=False)
        blocks.add(block)
    out_filters *= 2
model = tf.keras.models.Sequential([
    Conv2D(64, (3, 3), strides=1, padding='same', use_bias=False)
    , BatchNormalization()
    , Activation('relu')
    , blocks
    , tf.keras.layers.GlobalAveragePooling2D()
    , tf.keras.layers.Dense(10, activation='softmax', kernel_regularizer=tf.keras.regularizers.l2())
## 5.定义优化器、损失函数和评价指标
```python
model.compile(optimizer='adam'
              , loss='categorical_crossentropy'
              , metrics=['accuracy'])
## 6.断点续训
```python
save_path = './checkpoint/inception.ckpt'
if os.path.exists(save_path + '.index'):
    print('model loading')
    model.load_weights(save_path)
cp_callback = keras.callbacks.ModelCheckpoint(filepath=save_path
                                              , save_weights_only=True
                                              , save_best_only=True)
callback = tf.keras.callbacks.EarlyStopping(monitor='loss', patience=3)
## 7.训练模型
```python
history = model.fit(x_train, y_train
                    , batch_size=batch_size
                    , epochs=epochs
                    , verbose=1
                    , validation_data=(x_val, y_val)
                    , callbacks=[cp_callback, callback])
## 8.预测结果
```python
result = model.predict(x_test)
pred = tf.argmax(result, axis=1)
df = pd.DataFrame(pred, columns=['label'])
df.to_csv(path_or_buf='Submission.csv', index_label='image_id')
## 9.模型损失和准确率可视化
```python
print(history.history.keys())
plt.plot(history.epoch, history.history.get('loss'), label='loss')
plt.plot(history.epoch, history.history.get('val_loss'), label='val_loss')
plt.legend()
plt.show()
plt.plot(history.epoch, history.history.get('accuracy'), label='acc')
plt.plot(history.epoch, history.history.get('val_accuracy'), label='val_acc')
plt.legend()
plt.show()
