Mybatis配置文件
百里长疯 发表于 2020/12/27 23:15:33 2020/12/27
【摘要】 Mybatis配置文件 conf.xml配置 conf.xml配置 <?xml version="1.0" encoding="UTF-8" ?> <!DOCTYPE configuration PUBLIC "-//mybatis.org//DTD Config 3.0//EN" "http://mybatis.org/dtd/myb...
Mybatis配置文件
conf.xml配置
<!DOCTYPE configuration PUBLIC "-//mybatis.org//DTD Config 3.0//EN" "http://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration> <!--引入文件数据库配置--> <properties resource="dbcp.properties"/> <settings> <!-- 开启日志,并指定使用的具体日志 --> <setting name="logImpl" value="LOG4J"/> <!-- 开启延迟加载 --> <setting name="lazyLoadingEnabled" value="true"/> <!-- 关闭立即加载 --> <setting name="aggressiveLazyLoading" value="false"/> <!-- 开启二级缓存 --> <setting name="cacheEnabled" value="true"/> </settings> <typeHandlers> <typeHandler handler="converter.BooleanAndIntConvert" javaType="Boolean" jdbcType="INTEGER"/> </typeHandlers> <environments default="development"> <environment id="development"> <transactionManager type="JDBC"/> <dataSource type="POOLED"> <property name="driver" value="${driver}"/> <property name="url" value="${url}"/> <property name="username" value="${username}"/> <property name="password" value="${password}"/> </dataSource> </environment> </environments> <mappers> <!--加载映射文件--> <mapper resource="resources/personMapper.xml"/> <mapper resource="resources/studentMapper.xml"/> <mapper resource="Dao/studentDao.xml"></mapper> <mapper resource="Dao/studentDaoHash.xml"></mapper> <mapper resource="Dao/dongTaiSQL.xml"></mapper> </mappers>
</configuration>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
这是我的码云地址
文章来源: blog.csdn.net,作者:East Horse,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_44613138/article/details/105123853
