sysbench 安装
snowofsummer 发表于 2020/12/24 10:20:10 2020/12/24
【摘要】 1,软件包安装yum -y install  make automake libtool pkgconfig libaio-devel vim-common  mysql-devel2,查看mysql信息[root@tdsql1 sysbench-master]# mysql_configUsage: /usr/bin/mysql_config [OPTIONS]Options: ...
1,软件包安装
2,查看mysql信息
Options:
        --cflags         [-I/usr/include/mysql]
        --include        [-I/usr/include/mysql]
        --libs           [-L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto]
        --libs_r         [-L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto]
        --plugindir      [/usr/lib64/mysql/plugin]
        --socket         [/var/lib/mysql/mysql.sock]
        --port           [0]
        --version        [5.5.60]
        --libmysqld-libs [-L/usr/lib64/mysql -lmysqld]
        --variable=VAR   VAR is one of:
                pkgincludedir [/usr/include/mysql]
                pkglibdir     [/usr/lib64/mysql]
3,配置和安装sysbench
[root@tdsql1 sysbench-master]# ./autogen.sh
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy
autoreconf: running: /usr/bin/autoconf
autoreconf: running: /usr/bin/autoheader
autoreconf: running: automake --add-missing --copy --no-force
autoreconf: Leaving directory `.'
[root@tdsql1 sysbench-master]# ./configure
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking whether gcc -std=gnu99 and cc understand -c and -o together... yes
checking for a sed that does not truncate output... /usr/bin/sed
checking for C compiler vendor... gnu
checking for gcc architecture flag...
checking for x86 cpuid 0 output... 14:756e6547:6c65746e:49656e69
checking for x86 cpuid 1 output... 406f1:2010800:fffa3203:f8bfbff
checking whether C compiler accepts -march=core2... yes
checking for gcc architecture flag... -march=core2
checking for ar... ar
checking the archiver (ar) interface... ar
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc -std=gnu99... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc -std=gnu99 object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc -std=gnu99 supports -fno-rtti -fno-exceptions... no
checking for gcc -std=gnu99 option to produce PIC... -fPIC -DPIC
checking if gcc -std=gnu99 PIC flag -fPIC -DPIC works... yes
checking if gcc -std=gnu99 static flag -static works... no
checking if gcc -std=gnu99 supports -c -o file.o... yes
checking if gcc -std=gnu99 supports -c -o file.o... (cached) yes
checking whether the gcc -std=gnu99 linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for pkg-config... yes
checking for xxd... yes
checking for C compiler vendor... (cached) gnu
checking whether to compile with MySQL support... yes
checking whether to compile with Drizzle support... no
checking whether to compile with libattachsql support... no
checking whether to compile with Oracle support... no
checking whether to compile with PostgreSQL support... no
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking whether to build with system or bundled LuaJIT... bundled
checking whether to build with system or bundled Concurrency Kit... bundled
checking whether SHM_HUGETLB is declared... yes
checking whether O_SYNC is declared... yes
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for sqrt in -lm... yes
checking for mysql_config... /usr/bin/mysql_config
checking MySQL C flags... -I/usr/include/mysql
checking MySQL linker flags... -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto
checking for ld used by GCC... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... done
checking libaio.h usability... yes
checking libaio.h presence... yes
checking for libaio.h... yes
checking for io_queue_init in -laio... yes
checking if io_getevents() has an old interface... no
checking for malloc in -lumem... no
checking for malloc in -lmtmalloc... no
checking for ANSI C header files... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking sys/aio.h usability... no
checking sys/aio.h presence... no
checking for sys/aio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking thread.h usability... no
checking thread.h presence... no
checking for thread.h... no
checking for unistd.h... (cached) yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking for off_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking for thread local storage (TLS) class... __thread
checking for __attribute__((format))... yes
checking for __attribute__((unused))... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking size of size_t... 8
checking size of bool... 1
checking for sys/param.h... yes
checking for getpagesize... yes
checking for working mmap... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... yes
checking for library containing clock_gettime... none required
checking for alarm... yes
checking for clock_gettime... yes
checking for directio... no
checking for fdatasync... yes
checking for gettimeofday... yes
checking for isatty... yes
checking for memalign... yes
checking for memset... yes
checking for posix_memalign... yes
checking for pthread_yield... yes
checking for setvbuf... yes
checking for sqrt... yes
checking for strdup... yes
checking for thr_setconcurrency... no
checking for valloc... yes
checking for pthread_once... yes
which: no git in (/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/data/home/tdsql/jdk1.8.0_51/bin:/data/home/tdsql/hadoop-3.2.1/bin:/data/home/tdsql/hadoop-3.2.1/sbin:/root/bin)
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating third_party/luajit/Makefile
config.status: creating third_party/concurrency_kit/Makefile
config.status: creating src/Makefile
config.status: creating src/drivers/Makefile
config.status: creating src/drivers/mysql/Makefile
config.status: creating src/drivers/drizzle/Makefile
config.status: creating src/drivers/oracle/Makefile
config.status: creating src/drivers/pgsql/Makefile
config.status: creating src/drivers/attachsql/Makefile
config.status: creating src/tests/Makefile
config.status: creating src/tests/cpu/Makefile
config.status: creating src/tests/fileio/Makefile
config.status: creating src/tests/memory/Makefile
config.status: creating src/tests/threads/Makefile
config.status: creating src/tests/mutex/Makefile
config.status: creating src/lua/Makefile
config.status: creating src/lua/internal/Makefile
config.status: creating tests/Makefile
config.status: creating tests/include/config.sh
config.status: creating snap/snapcraft.yaml
config.status: creating config/config.h
config.status: config/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
sysbench version   : 1.1.0
CC                 : gcc -std=gnu99
CFLAGS             : -O2 -ggdb3  -march=core2 -W -Wall -Wextra -Wpointer-arith -Wbad-function-cast   -Wstrict-prototypes -Wnested-externs -Wno-inline -Wno-format-zero-length   -funroll-loops  -Wundef -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wredundant-decls -Wcast-align        -pthread
CPPFLAGS           : -D_GNU_SOURCE   -I$(top_srcdir)/src -I$(abs_top_builddir)/third_party/luajit/inc -I$(abs_top_builddir)/third_party/concurrency_kit/include
LDFLAGS            : -L/usr/local/lib
LIBS               : -laio -lm
EXTRA_LDFLAGS      :
prefix             : /usr/local
bindir             : ${prefix}/bin
libexecdir         : ${prefix}/libexec
mandir             : ${prefix}/share/man
datadir            : ${prefix}/share
MySQL support      : yes
Drizzle support    : no
AttachSQL support  : no
Oracle support     : no
PostgreSQL support : no
LuaJIT             : bundled
LUAJIT_CFLAGS      : -I$(abs_top_builddir)/third_party/luajit/inc
LUAJIT_LIBS        : $(abs_top_builddir)/third_party/luajit/lib/libluajit-5.1.a -ldl
LUAJIT_LDFLAGS     : -rdynamic
Concurrency Kit    : bundled
CK_CFLAGS          : -I$(abs_top_builddir)/third_party/concurrency_kit/include
CK_LIBS            : $(abs_top_builddir)/third_party/concurrency_kit/lib/libck.a
configure flags    :
[root@tdsql1 sysbench-master]# make && make install
Making all in third_party/luajit
make[1]: Entering directory `/root/sysbench-master/third_party/luajit'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/root/sysbench-master/third_party/luajit'
make[1]: Entering directory `/root/sysbench-master'
make[2]: Entering directory `/root/sysbench-master'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/root/sysbench-master'
make[1]: Leaving directory `/root/sysbench-master'
[root@tdsql1 sysbench-master]# sysbench --version
sysbench 1.1.0
