HTC 5G Hub Router Review
ltemodem 发表于 2020/12/08 15:55:59 2020/12/08
【摘要】 HTC 5G Hub Router Review
HTC 5G Hub is an innovative device that combines the functions of a 5G WiFi router, a Android Tablet, and a multimedia speaker. The built-in high-capacity battery makes it easy to take HTC 5G Hub on the road and surf the Internet wherever you have a reliable 4G / 5G signal.
Supports the popular European 5G standard n78
The HTC 5G router supports the 5G n78 standard, which occupies the frequency range of 3300–3800 MHz. The maximum speed of the HTC 5G Hub Internet connection in the fifth generation networks reaches 2.63 Gbps per reception, which is significantly higher than the available 4G speeds.
HTC 5G Hub
When working in 4G networks, the 5G router supports the LTE Band 3 and LTE Band 7 standards, which are used by all domestic operators. A wide range of operating frequencies allows HTC 5G Hub to operate not only in Asia, but also in other European countries.
The router is equipped with a slot for a Nano-SIM card and is not tied to a specific operator. The HTC 5G Hub can be freely used in the networks in Europe and Asia.
HTC 5G Hub
Android platform and LCD touchscreen with enhanced color reproduction
The router-hub runs on the Android 9 Pie operating system, which makes HTC 5G Hub similar to tablet computers and smart home devices. The high performance of the device is ensured by the use of an octa-core Qualcomm Snapdragon 855 processor and a modern 5G Snapdragon X50 5G modem.
HTC 5G Hub is equipped with a 5-inch high-definition touchscreen (1280x720), which allows you to not only configure the router, but also display graphics, play videos and launch various Android applications. Built-in dual speakers (90dB) play music, radio or other audio in high quality. The manufacturer declared support for broadcasting 4K video to an external screen (for example, your TV) and optimization for online games. VPN can be used to connect to a secure corporate environment.
HTC 5G Hub
The high-speed WiFi module supports 802.11a/b/g/n/ac standards (2.4 and 5 GHz frequencies), as well as the rather rare 802.11ad standard (60 GHz frequencies). The Internet Center is designed for simultaneous operation with 20 wireless devices. Also, the router is equipped with a Bluetooth 5.0 module for connecting a wireless headset.
A gigabit LAN port is available for wired connection to devices (computer, Smart TV, game console, etc.). The multifunctional USB Type-C port can be used to charge the battery, transfer data, connect an external storage or display (DisplayPort support).
HTC 5G Hub
Autonomous operation of the router is ensured by the built-in 7660 mAh battery. Thus, HTC 5G Hub owners can freely take the device with them on the road and use it as a mobile router. According to the manufacturer, one battery charge should be enough for the whole day of intensive use of the router.
Controlling HTC 5G Hub with your voice
The advanced features of the 5G hub include a motion sensor and support for voice commands. When used with add-on software and an external display, the HTC 5G Hub can function as a game console, including cloud PC gaming.
HTC 5G Hub
Due to its portability and light weight, HTC's 5G router is perfect for home, office, car, or on vacation. The body of the HTC 5G Hub is made of soft-touch plastic. The ergonomics of the device are thought out to the smallest detail.
The HTC 5G Hub expands the capabilities of your mobile router by introducing a hub device that can replace your tablet PC, wireless speaker and voice assistant. In addition to creating a wireless network with access to the mobile Internet, HTC 5G Hub can be used as an independent gadget that does not require the connection of peripheral devices.
HTC 5G Hub Router Specifications
Frequency ranges LTE FDD: Band 1/3/7/8/32 (2100/1800/2600/900/1500 MHz)
LTE TDD: Band 38/40 (2600/2300 MHz)
5G TDD: Band n78 (3500 MHz)
Maximum speed of mobile connection reception up to 2.63 Gbps, transmission up to 287 Mbps
SIM format Nano-SIM
WiFi frequency bands 2.4GHz, 5GHz, 60GHz
WiFi standards 802.11a / b / g / n / ac / ad
Maximum number of WiFi client devices 20 (802.11ad AP supports 4 devices)
Bluetooth standard Bluetooth 5.0
Chipset Qualcomm Snapdragon 855 (Snapdragon X50 5G Modem)
RAM 4 GB
Built-in memory 32 GB
operating system Android 9.0
Connectors 1 x LAN
1 x USB Type-C (with DisplayPort support)
1 x MicroSD
1 x Nano-SIM
Ethernet 10/100/1000 Mbps
LCD screen 5-inch touch (capacitive) screen with 1280x720 resolution
Additional features stereo speakers (90 dB), motion sensor, Google Assistant support
Power (adapter) 12V, 2.5A
Battery 7660mAh, built-in
The size 128 x 100 x 43 mm
The weight 340 g
Equipment router, power adapter, USB cable, manual
HTC 5G Hub:  https://www.4gltemall.com/htc-5g-hub.html
