ADB for mysql 【INSERT [IGNORE] INTO table_name】迁移 DWS 改写方法
瘸子那条好腿 发表于 2020/12/08 15:28:44 2020/12/08
【摘要】 INSERT INTOINSERT INTO用于向表中插入数据,遇到主键重复时会自动忽略当前写入数据,不做更新,作用等同于INSERT IGNORE INTO。语法 INSERT [IGNORE] INTO table_name [( column_name [, …] )] [VALUES] [(value_list[, …])] [query];参数IGNORE:可选参数,若系统中已...
INSERT INTO
语法
参数
  • IGNORE:可选参数,若系统中已有相同主键的记录,新记录不会被写入。
  • column_name:可选参数,列名。
  • query:通过定义查询,将一行或多行数据插入表中。
DWS改写方法
CREATE TABLE PRODUCTS
PRODUCT_ID INTEGER,
PRODUCT_NAME VARCHAR2(60),
CATEGORY VARCHAR2(60)
INSERT INTO PRODUCTS VALUES (1600, 'PLAY GYM', 'TOYS');
INSERT INTO PRODUCTS VALUES (1601, '**ZE', 'TOYS');
INSERT INTO PRODUCTS VALUES (1602, 'HARRY POTTER', 'DVD');
CREATE TABLE NEWPRODUCTS
PRODUCT_ID INTEGER,
INSERT INTO NEWPRODUCTS VALUES (1601, '**ZE', 'TOYS');
INSERT INTO NEWPRODUCTS VALUES (1603, 'HARRY POTTER', 'TOYS');
INSERT INTO NEWPRODUCTS VALUES (1604, 'WAIT INTERFACE', 'BOOKS');
--方法1  MERGE  INTO
CREATE OR REPLACE PROCEDURE INSERT_DATA
AS
BEGIN
MERGE INTO PRODUCTS P
USING NEWPRODUCTS NP
ON (P.PRODUCT_ID = NP.PRODUCT_ID)
WHEN NOT MATCHED THEN
  INSERT VALUES (NP.PRODUCT_ID, NP.PRODUCT_NAME, NP.CATEGORY);
END;
--调用此存储过程。
CALL INSERT_DATA();
--方法2  NOT EXISTS
AS
BEGIN
SELECT * FROM NEWPRODUCTS NP
WHERE NOT EXISTS (SELECT 1 FROM PRODUCTS MP WHERE NP.PRODUCT_ID = MP.PRODUCT_ID);
END;
--调用此存储过程。
CALL INSERT_DATA();
