python 实现数据库中数据添加、查询与更新的示例代码(下)
泽宇-Li 发表于 2020/12/08 08:00:20 2020/12/08
【摘要】 二、数据批量查询select_data.py123456789101112131415161718192021222324 import pymysqlimport pandas as pdimport numpy as np  def get_tags():  # 连接数据库,地址,端口,用户名,密码,数据库名称,数据格式  conn = pymysql.connect(host='xxx...
二、数据批量查询
select_data.py
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
import pymysql
import pandas as pd
import numpy as np
def get_tags():
  conn = pymysql.connect(host='xxx.xxx.xxx.xxx',port=3307,user='root',passwd='123456',db='xxxx',charset='utf8')
  cur = conn.cursor()
  # 表cf_users中获取所有用户id
  sql = 'select id from cf_tags where id between 204 and 298'
  # 将user_id列转成列表输出
  df = pd.read_sql(sql,con=conn)
  # 先使用array()将DataFrame转换一下
  df1 = np.array(df)
  # 再将转换后的数据用tolist()转成列表
  df2 = df1.tolist()
  # cur.execute(sql)
  # data = cur.fetchone()
  # print(df)
  # print(df1)
  # print(df2)
  return df2
  conn.close()
三、批量更新数据
select_data.py
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
import pymysql
import pandas as pd
import numpy as np
def get_tags():
  cur = conn.cursor()
  # 将user_id列转成列表输出
  df1 = np.array(df)
  df2 = df1.tolist()
  # cur.execute(sql)
  # print(df)
  # print(df1)
  # print(df2)
  return df2
  conn.close()
