目标:测试两个40g网卡对接 能否冲到40g的流量
【摘要】 测试报告目标:测试两个40g网卡对接 能否冲到40g的流量物理环境:服务器A5.5.5.1------------40网卡--------5.5.5.2服务器B------172.31.1.228(可以上外网)---公司网络的2960 服务器A硬件配置:CPU:Intel(R) Core(TM) i5-3470 CPU @ 3.20GH...
测试报告
物理环境:
服务器A
硬件配置:
CPU:Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
内存:8G (DDR3 1600 4G*2)
硬盘:128G SSD
主板信息:HP Z220 SFF Workstation
网卡:40G网卡 (Skyhawk)
软件环境:DEBIAN 8.6 升级到下面版本
root@debian:/home/andy# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 8.8 (jessie)
Release: 8.8
Codename: jessie
服务器B
硬件配置:
内存:8G (DDR3 1600 2G*4)
硬盘:128G SSD
网卡:40G网卡 (Skyhawk)
软件环境:debian8.4升级到下面版本
Release: 8.8
Codename: jessie
直接在服务器上show出来的
root@debian:/home/andy# inxi -Fx
System: Host: debian Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4) Console: tty 8
Distro: Debian GNU/Linux 8
Machine: System: Hewlett-Packard product: HP Z220 SFF Workstation serial: 6CR324WLCN
Mobo: Hewlett-Packard model: 1791 serial: 6CR324WLCN
Bios: Hewlett-Packard v: K51 v01.58 date: 02/07/2013
CPU: Quad core Intel Core i5-3470 (-MCP-) cache: 6144 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 25541
Clock Speeds: 1: 3595 MHz 2: 3565 MHz 3: 3440 MHz 4: 3496 MHz
Graphics: Card: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
Display Server: N/A driver: N/A tty size: 224x62 Advanced Data: N/A for root out of X
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
Network: Card-1: Emulex OneConnect NIC (Skyhawk) driver: be2net v: 10.2u port: Root bus-ID: 01:00.0
IF: eth1 state: up speed: 40000 Mbps duplex: full mac: 00:90:fa:70:80:dc
Card-2: Intel 82579LM Gigabit Network Connection driver: e1000e v: 2.3.2-k port: f080 bus-ID: 00:19.0
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 88:51:fb:6f:c0:bc
Drives: HDD Total Size: 128.0GB (4.8% used) ID-1: /dev/sda model: LITEONIT_LCS size: 128.0GB temp: 0C
Partition: ID-1: / size: 113G used: 1.1G (1%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 5.23GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 68.0C mobo: 27.8C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 131 Uptime: 5:25 Memory: 141.7/7877.9MB Init: systemd runlevel: 5 Gcc sys: N/A
Client: Shell (bash 4.3.301) inxi: 2.1.28
方法2
root@debian:/home/andy# lshw -short
H/W path Device Class Description
system Computer
/0 bus Motherboard
/0/0 memory 7877MiB System memory
/0/1 processor Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
/0/100 bridge Xeon E3-1200 v2/3rd Gen Core processor DRAM Controller
/0/100/1 bridge Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port
/0/100/1/0 eth1 network OneConnect NIC (Skyhawk)
/0/100/1/0.1 bus OneConnect FCoE Initiator (Skyhawk)
/0/100/2 display Xeon E3-1200 v2/3rd Gen Core processor Graphics Controller
/0/100/14 bus 7 Series/C210 Series Chipset Family USB xHCI Host Controller
/0/100/14/0 usb4 bus xHCI Host Controller
/0/100/14/1 usb3 bus xHCI Host Controller
/0/100/16 communication 7 Series/C210 Series Chipset Family MEI Controller #1
/0/100/16.3 communication 7 Series/C210 Series Chipset Family KT Controller
/0/100/19 eth0 network 82579LM Gigabit Network Connection
/0/100/1a bus 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2
/0/100/1a/1 usb1 bus EHCI Host Controller
/0/100/1a/1/1 bus Integrated Rate Matching Hub
/0/100/1b multimedia 7 Series/C210 Series Chipset Family High Definition Audio Controller
/0/100/1d bus 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1
/0/100/1d/1 usb2 bus EHCI Host Controller
/0/100/1d/1/1 bus Integrated Rate Matching Hub
/0/100/1e bridge 82801 PCI Bridge
/0/100/1f bridge C216 Series Chipset LPC Controller
/0/100/1f.2 storage 82801 SATA Controller [RAID mode]
/0/100/1f.3 bus 7 Series/C210 Series Chipset Family SMBus Controller
/0/2 scsi1 storage
/0/2/0.0.0 /dev/sda disk 128GB LITEONIT LCS-128
/0/2/0.0.0/1 /dev/sda1 volume 114GiB EXT4 volume
/0/2/0.0.0/2 /dev/sda2 volume 4986MiB Extended partition
/0/2/0.0.0/2/5 /dev/sda5 volume 4986MiB Linux swap / Solaris partition
安装完以上的基础环境后:
Step1:apt-get update 更新一下基础系统
Step2:两个服务器堵安装iperf3(版本iperf 3.1.3),安装办法如下:
sudo apt-get remove iperf3 libiperf0
wget https://iperf.fr/download/ubuntu/libiperf0_3.1.3-1_amd64.deb
wget https://iperf.fr/download/ubuntu/iperf3_3.1.3-1_amd64.deb
sudo dpkg -i libiperf0_3.1.3-1_amd64.deb iperf3_3.1.3-1_amd64.deb
rm libiperf0_3.1.3-1_amd64.deb iperf3_3.1.3-1_amd64.deb
Step 3:两个服务器安装一下ethtool_2.6.33.orig.tar.gz 安装办法如下:
tar -xvzf ethtool_2.6.33.orig.tar.gz
cd ethtool-2.6.33
./configure
make
make install
make clean
Step 4:优化rwnd 办法如下:能起到一定的cpu优化作用,但是影响不大,所以这个最好不做,应该是debian比较新的版本是有做了rwind的自动伸缩的了。
nano /etc/sysctl.conf
添加红色部分:
##############################################################3
# Functions previously found in netbase
net.ipv4.tcp_syn_retries = 1
net.ipv4.tcp_synack_retries = 1
net.ipv4.tcp_keepalive_time = 600
net.ipv4.tcp_keepalive_probes = 3
net.ipv4.tcp_keepalive_intvl =15
net.ipv4.tcp_retries2 = 5
net.ipv4.tcp_fin_timeout = 2
net.ipv4.tcp_max_tw_buckets = 36000
net.ipv4.tcp_tw_recycle = 1
net.ipv4.tcp_tw_reuse = 1
net.ipv4.tcp_max_orphans = 32768
net.ipv4.tcp_syncookies = 1
net.ipv4.tcp_max_syn_backlog = 16384
net.ipv4.tcp_wmem = 8192 131072 16777216
net.ipv4.tcp_rmem = 327680 1310720 16777216000
net.ipv4.tcp_mem = 786432 1048576 1572864
net.ipv4.ip_local_port_range = 1024 65000
net.ipv4.ip_conntrack_max = 65536
net.ipv4.netfilter.ip_conntrack_max=65536
net.ipv4.netfilter.ip_conntrack_tcp_timeout_established=180
net.core.somaxconn = 16384
net.core.netdev_max_backlog = 16384
net.ipv4.tcp_sack = 0
net.ipv4.tcp_moderate_rcvbuf = 1
(net.ipv4.tcp_fin_timeout = 15)
# Uncomment the next two lines to enable Spoof protection (reverse-path filter)
# Turn on Source Address Verification in all interfaces to
# prevent some spoofing attacks
#net.ipv4.conf.default.rp_filter=1
#net.ipv4.conf.all.rp_filter=1
然后让这些起到效果:sysctl -p
Step4:优化 cwnd----修改这个没有什么意义,甚至可能有反作用。
shell> ip route | while read r; do
ip route change $r initcwnd 10;
done
Step 5:修过两个网卡的mtu值-修过这个可以让流量放大 效果最明显的其中的一个因素,
办法如下: ifconfig eth1 mtu 90000
Step 5:两个服务器同时,优化interface接收包的能力
ethtool -K eth1 tx on
ethtool -K eth1 rx on
Step6:再做一下简单的优化 详细可以参考 http://blog.csdn.net/an_zhenwei/article/details/18732081
ethtool -K eth1 sg on
ethtool -K eth1 tso on
ethtool -K eth1 gso on
可以看一下修改的情况:
root@debian:/home/andy# ethtool -k eth0
Features for eth0:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: off [fixed]
tx-checksum-ip-generic: on
tx-checksum-ipv6: off [fixed]
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: off [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: off [fixed]
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: off [fixed]
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: off [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off
rx-all: off
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: off [fixed]
Step 7:内核优化
sysctl -w net.core.rmem_max=16777216
Step 8:关闭timesstamps 可以节省cpu开销
Sysctl -w net.ipv4.tcp_timestamps=0
Step 8:基本上做上面的优化
Udp测试
服务器 5.5.5.1 运行iperf -s
客户端 5.5.5.1 运行 iperf3 -c 5.5.5.1 -t 30000 -P 6 -M 8900 -u -b 60000m
会有以下的输出结果
以上的结构是基本达标的,谢谢。
二次测试验证情况:
(外网ip172.31.1.182)服务器A--5.5.5.1----------5.5.5.2-------服务器B(外网ip172.31.1.228)
Step 1:基于这样的情况下
硬件还是不变的,两边都安装玩debian8.6后
apt-get update
apt-get upgrade
Step 2:还是按照上面的办法安装好iperf3
再安装apt-get install ethtool 这个主要是看那个网卡是40g网卡用
apt-get install nload 看网卡流量用的
Step 3:没有修改任何东西的情况下
服务器A iperf3 -s
服务器B iperf3 -c 5.5.5.1 -t 30000 -P 6 -M 8900 -u -b 60000m
这样流量可以到达大约 15G
Step 4: 我修改了两个服务器40g网卡的mtu 修改到9000
Ifconfig eth1 mtu 9000
重复step3 然后竟然发现流量也可以达到 38g
Nload 看也有 36g
但是服务器b就是客户端服务器cpu有点高:
服务器a感觉还好
Step 5:对debian进行系统优化:
做了截图上的优化后,服务器b 明显滴从接近100%到 80% 只是优化了服务器b
同样去优化服务器a的时候:cpu也稍有降低一些了 78%---73%
结论:就是安装好debian8.6后,各自升级到最新,安装好要用的测试软件 iperf3 ethtool nload
接着就是修改MTU测试就好,在debian环境下,tcp窗口可以自动伸缩,其他窗口也尽量不用动。只是这样情况下cpu有点高。
修改cpu有效的办法如下就好:-其实就是上面的二次测试情况流程
cloudbbs@huaweicloud.com
