Cocos2dx之Actions
yd_221104950 发表于 2020/12/03 00:35:22 2020/12/03
【摘要】 创建Scene场景和添加Sprite对象到场景中只是游戏开发的一部分。对于一个游戏而言,我们要让游戏中的东西能够移动。Action(动作)对象是每一个游戏中不可或缺的部分。 Actions(动作)允许Node对象在时空中转换。想从一个点移动Sprite对象到另一个点,并在完成时,调用回调,怎样可以实现呢?我们在一个Node节点上创建一个Action动作序列。这些可以是改...
创建Scene场景和添加Sprite对象到场景中只是游戏开发的一部分。对于一个游戏而言,我们要让游戏中的东西能够移动。Action(动作)对象是每一个游戏中不可或缺的部分。 Actions(动作)允许Node对象在时空中转换。想从一个点移动Sprite对象到另一个点,并在完成时,调用回调,怎样可以实现呢?我们在一个Node节点上创建一个Action动作序列。这些可以是改变Node对象的position(位置), rotation(旋转)和 scale(缩放)的动作,如MoveBy, Rotate, Scale。
创建Action对象:
1、Move:MoveBy与MoveTo
auto mySprite = Sprite::create("Blue_Front1.png");
// Move a sprite 50 pixels to the right, and 10 pixels to the top over 2 seconds.
auto moveBy = MoveBy::create(2, Vec2(50,10));
mySprite->runAction(moveBy);
// Move a sprite to a specific location over 2 seconds.
auto moveTo = MoveTo::create(2, Vec2(50,10));
mySprite->runAction(moveTo);
例子:
auto mySprite = Sprite::create("mysprite.png");
mySprite->setPosition(Vec2(200, 256));
// MoveBy - lets move the sprite by 500 on the x axis over 2 seconds
// MoveBy is relative - since x = 200 + 500 move = x is now 700 after the move
auto moveBy = MoveBy::create(2, Vec2(500, mySprite->getPositionY()));
// MoveTo - lets move the new sprite to 300 x 256 over 2 seconds
// MoveTo is absolute - The sprite gets moved to 300 x 256 regardless of
// where it is located now.
auto moveTo = MoveTo::create(2, Vec2(300, mySprite->getPositionY()));
// Delay - create a small delay
auto delay = DelayTime::create(1);
auto seq = Sequence::create(moveBy, delay, moveTo, nullptr);
mySprite->runAction(seq);
MoveBy是相对原来的位置进行移动,而MoveTo则是绝对地移动。
2、Rotate:RotateBy与RotateTo
// Rotates a Node to the specific angle over 2 seconds
auto rotateTo = RotateTo::create(2.0f, 40.0f);
mySprite->runAction(rotateTo);
// Rotates a Node clockwise by 40 degree over 2 seconds
auto rotateBy = RotateBy::create(2.0f, 40.0f);
mySprite->runAction(rotateBy);
3、Scale:ScaleBy与ScaleTo
// Scale uniformly by 3x over 2 seconds
auto scaleBy = ScaleBy::create(2.0f, 3.0f);
mySprite->runAction(scaleBy);
// Scale X by 5 and Y by 3x over 2 seconds
auto scaleBy = ScaleBy::create(2.0f, 3.0f, 3.0f);
// Scale to uniformly to 3x over 2 seconds
auto scaleTo = ScaleTo::create(2.0f, 3.0f);
mySprite->runAction(scaleTo);
// Scale X to 5 and Y to 3x over 2 seconds
auto scaleTo = ScaleTo::create(2.0f, 3.0f, 3.0f);
4、Fade:FadeIn与FadeOut
透明度的值变化范围为0 到 255。
// fades in the sprite in 1 seconds
auto fadeIn = FadeIn::create(1.0f);
mySprite->runAction(fadeIn);
// fades out the sprite in 2 seconds
auto fadeOut = FadeOut::create(2.0f);
mySprite->runAction(fadeOut);
5、Tint(色调):TintBy与TintTo
给一个实现了NodeRGB协议的Node(节点)着色,从当前色调到自定义色调。
// Tints a node to the specified RGB values
auto tintTo = TintTo::create(2.0f, 120.0f, 232.0f, 254.0f);
mySprite->runAction(tintTo);
// Tints a node BY the delta of the specified RGB values.
auto tintBy = TintBy::create(2.0f, 120.0f, 232.0f, 254.0f);
mySprite->runAction(tintBy);
6、Animate(动画)
使用Animate很容易实现Spritec对象的翻页动画。
// now lets animate the sprite we moved
Vector<SpriteFrame*> animFrames;
animFrames.reserve(12);
animFrames.pushBack(SpriteFrame::create("Blue_Front1.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Front2.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Front3.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Left1.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Left2.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Left3.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Back1.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Back2.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Back3.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Right1.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Right2.png", Rect(0,0,65,81)));
animFrames.pushBack(SpriteFrame::create("Blue_Right3.png", Rect(0,0,65,81)));
// create the animation out of the frames
Animation* animation = Animation::createWithSpriteFrames(animFrames, 0.1f);
Animate* animate = Animate::create(animation);
// run it and repeat it forever
mySprite->runAction(RepeatForever::create(animate));
7、Easing (缓冲)
Easing是通过指定加速让动画变得平滑的动画制作。
Cocos2d-x支持绝大部分缓冲功能。
例子:
// create a sprite
// create a MoveBy Action to where we want the sprite to drop from.
auto move = MoveBy::create(2, Vec2(200, dirs->getVisibleSize().height -
 newSprite2->getContentSize().height));
// create a BounceIn Ease Action
auto move_ease_in = EaseBounceIn::create(move->clone());
auto move_ease_in_back = move_ease_in->reverse();
// create a delay that is run in between sequence events
auto delay = DelayTime::create(0.25f);
// create the sequence of actions, in the order we want to run them
auto seq1 = Sequence::create(move_ease_in, delay, move_ease_in_back, delay->clone(), nullptr);
// run the sequence and repeat forever.
mySprite->runAction(RepeatForever::create(seq1));
Sequences序列
Sequences就是一系列的Action对象被有顺序地执行。序列中可以是任意数量的Action对象、函数甚至其他Sequence(序列)。Cocos2d-x 有CallFunc对象,它允许你创建 function()然后传递到Sequence对象中去执行。
// create a few actions.
auto jump = JumpBy::create(0.5, Vec2(0, 0), 100, 1);
auto rotate = RotateTo::create(2.0f, 10);
// create a few callbacks
auto callbackJump = CallFunc::create([](){ log("Jumped!");
auto callbackRotate = CallFunc::create([](){ log("Rotated!");
// create a sequence with the actions and callbacks
auto seq = Sequence::create(jump, callbackJump, rotate, callbackRotate, nullptr);
// run it
上面的代码中的动作的执行顺序:
Jump -> callbackJump() -> Rotate -> callbackRotate()
Delays in Sequences
当你想Sequence中的Action之间有一定的延迟,可以使用CallFunc来实现:
// use a sequence incorporating delays between items
cocos2d::CallFunc* A = cocos2d::CallFunc::create([=]() { // do something
cocos2d::CallFunc* B = cocos2d::CallFunc::create([=]() { // do something
cocos2d::CallFunc* C = cocos2d::CallFunc::create([=]() { // do something
cocos2d::DelayTime* delay = cocos2d::DelayTime::create(1);
runAction(cocos2d::Sequence::create(A, delay, B, delay, C, NULL));
Spawn
Spawn与Sequence相似,但Spawn的动作是同时执行的。Spawn产生的结果与连续执行多个runAction()语句的结果是一样的。Spawn的好处是你可以将它放入Sequence中去执行,可以获得特定的效果。
// create 2 actions and run a Spawn on a Sprite
auto moveBy = MoveBy::create(10, Vec2(400,100));
auto fadeTo = FadeTo::create(2.0f, 120.0f);
方式一:
// running the above Actions with Spawn.
auto mySpawn = Spawn::createWithTwoActions(moveBy, fadeTo);
mySprite->runAction(mySpawn);
方式二:
// running the above Actions with consecutive runAction() statements.
mySprite->runAction(fadeTo);
方式一与方式二是等价的。
在Sequence中使用Spawn
// create a Sprite
// create a few Actions
// create a Spawn to use
auto mySpawn = Spawn::createWithTwoActions(scaleBy, fadeTo);
// tie everything together in a sequence
auto seq = Sequence::create(moveBy, mySpawn, moveBy, nullptr);
// run it
Cloned克隆
如果我们有一个Action对象,那么我们可以调用clone()函数,将其应用到多个Node(节点)对象上。为什么要用克隆呢? Action对象都有一个内部状态(internal state)。当它们运行时,它们是真正去改变Node(节点)对象的属性。如果不使用clone(),你无法真正拥有一个唯一的Action对象来应用到Node(节点)对象上。那就将会导致一些不是我们所期望的结果。
// create our Sprites
auto heroSprite = Sprite::create("herosprite.png");
auto enemySprite = Sprite::create("enemysprite.png");
// create an Action
// run it on our hero
heroSprite->runAction(moveBy);
// run it on our enemy
enemySprite->runAction(moveBy->clone()); // correct! This will be unique
Reverse逆序
如果我们有一系列Action对象,我们可以调用reverse()逆序执行它们。调用reverse(),实际是逆顺序处理Sequence或Spawn的原始属性。
// reverse a sequence, spawn or action
mySprite->runAction(mySpawn->reverse());
大多数的 Action和Sequence对象都系可以逆序的。
例子:
// create a Sprite
mySprite->setPosition(50, 56);
auto moveBy = MoveBy::create(2.0f, Vec2(500,0));
auto scaleBy = ScaleBy::create(2.0f, 2.0f);
auto delay = DelayTime::create(2.0f);
auto delaySequence = Sequence::create(delay, delay->clone(), delay->clone(),
auto sequence = Sequence::create(moveBy, delay, scaleBy, delaySequence, nullptr);
// run it
newSprite2->runAction(sequence);
// reverse it
newSprite2->runAction(sequence->reverse());
文章来源: blog.csdn.net,作者:WongKyunban,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_40763897/article/details/104385829
评论(0
