flutter的ListView例子
yd_221104950 发表于 2020/12/03 01:00:26 2020/12/03
【摘要】 import 'package:flutter/material.dart'; import 'package:english_words/english_words.dart'; void main() => runApp(new MyApp()); class MyApp extends StatelessWidget { @override Widge...
  @override
  Widget build(BuildContext context) {
// final wordPair = new WordPair.random(); return new MaterialApp( title: "Welcome to Flutter", theme: new ThemeData(primaryColor: Colors.white),
// home: new Scaffold(
// appBar: new AppBar(
// title: new Text("Welcome to Flutter"),
// body: new Center(
 child: new Text("Hello World!52"),
 child: new Text(wordPair.asPascalCase),
// child: new RandomWords(),
// ), home: new RandomWords(), );
class RandomWords extends StatefulWidget {
  @override
  createState() => new RandomWordsState();
class RandomWordsState extends State<RandomWords> {
  final _suggestions = <WordPair>[];
  final _saved = new Set<WordPair>();
  final _biggerFont = const TextStyle(fontSize: 18.0); @override
// return new Text(wordPair.asPascalCase) return new Scaffold( appBar: new AppBar( title: new Text("Startup Name Generator"), actions: <Widget>[ new IconButton(icon: new Icon(Icons.list), onPressed: _pushSaved) ], ), body: _buildSuggestions(), );
  } Widget _buildSuggestions() { return new ListView.builder( padding: const EdgeInsets.all(16.0), // 对每个建议的单词对都会调用一次itemBuilder,然后将单词对添加到ListTile中 // 在偶数行,为单词添加一个ListTile row // 在单数行,添加一个分割线Widget itemBuilder: (context, i) { if (i.isOdd) return new Divider(); // 语法 'i ~/ 2'表示i除以2,但返回值是整形(向下取整),如i,1,2,3,4,5,时 // 结果为0,1,1,2,2,这可以计算出ListView中减去分割线后的实际单词对数量 final index = i ~/ 2; if (index >= _suggestions.length) { // 如果是建议列表中最后一个单词对,则接着再生成10个单词对,然后加到建议列表中 _suggestions.addAll(generateWordPairs().take(10)); } return _buildRow(_suggestions[index]); }, );
  } Widget _buildRow(WordPair pair) { final alreadySaved = _saved.contains(pair); return new ListTile( title: new Text( pair.asPascalCase, style: _biggerFont, ), trailing: new Icon( alreadySaved ? Icons.favorite : Icons.favorite_border, color: alreadySaved ? Colors.red : null, ), onTap: () { setState(() { if (alreadySaved) { _saved.remove(pair); } else { _saved.add(pair); } }); }, );
  } void _pushSaved() { Navigator.of(context).push( new MaterialPageRoute( builder: (context) { final tiles = _saved.map((pair) { return new ListTile( title: new Text( pair.asPascalCase, style: _biggerFont, ), ); }); final divided = ListTile.divideTiles(context: context, tiles: tiles).toList(); return new Scaffold( appBar: new AppBar( title: new Text("Saved Suggestions") ), body: new ListView( children: divided, ), ); }, ), );
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
文章来源: blog.csdn.net,作者:WongKyunban,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_40763897/article/details/108203265
