在Flutter中用dio发起HTTP网络请求
yd_221104950 发表于 2020/12/03 01:15:54 2020/12/03
【摘要】 用dart io中的HttpClient发起的请求,但HttpClient本身功能较弱,很多常用功能都不支持。所以推荐大家使用dio 来发起网络请求,它是一个强大易用的dart http请求库,支持Restful API、FormData、拦截器、请求取消、Cookie管理、文件上传/下载。github dio 1.添加依赖 在pubspec.yaml加入以下依赖:...
1.添加依赖
dependencies:
  dio: ^3.0.10 #latest version
2.下载依赖
在项目根目录下执行flutter pub get:
~/AndroidStudioProjects/ME/startup_namer$ flutter pub get
3.网络请求
3.1.GET
Response response;
Dio dio = new Dio();
response = await dio.get("/test?id=12&name=wendu");
print(response.data.toString());
// Optionally the request above could also be done as
response = await dio.get("/test", queryParameters: {"id": 12, "name": "wendu"});
3.2.POST
response = await dio.post("/test", data: {"id": 12, "name": "wendu"});
3.3.并发网络请求
response = await Future.wait([dio.post("/info"), dio.get("/token")]);
3.4.下载文件
response = await dio.download("https://www.google.com/", "./xx.html");
3.5.响应流
获得流数据。
Response<ResponseBody> rs = await Dio().get<ResponseBody>(url,
 options: Options(responseType: ResponseType.stream), // set responseType to `stream`
print(rs.data.stream); //response stream
3.6.用字节响应
获得字节数据。
Response<List<int>> rs = await Dio().get<List<int>>(url,
 options: Options(responseType: ResponseType.bytes), // // set responseType to `bytes`
print(rs.data); // List<int>
3.7.发送表单数据
FormData formData = new FormData.fromMap({ "name": "wendux", "age": 25,
response = await dio.post("/info", data: formData);
3.8.用表单上传多个文件
FormData.fromMap({ "name": "wendux", "age": 25, "file": await MultipartFile.fromFile("./text.txt",filename: "upload.txt"), "files": [ await MultipartFile.fromFile("./text1.txt", filename: "text1.txt"), await MultipartFile.fromFile("./text2.txt", filename: "text2.txt"), ]
3.9.监听上传进度
  "http://www.dtworkroom.com/doris/1/2.0.0/test",
  data: {"aa": "bb" * 22},
  onSendProgress: (int sent, int total) { print("$sent $total");
3.10.通过流发送二进制数据
// Binary data
List<int> postData = <int>[...];
await dio.post(
  url,
  data: Stream.fromIterable(postData.map((e) => [e])), //create a Stream<List<int>>
  options: Options( headers: { Headers.contentLengthHeader: postData.length, // set content-length },
3.11.创建Dio实例,并配置它
Dio dio = new Dio(); // with default Options
// Set default configs
dio.options.baseUrl = "https://www.xx.com/api";
dio.options.connectTimeout = 5000; //5s
dio.options.receiveTimeout = 3000;
// or new Dio with a BaseOptions instance.
BaseOptions options = new BaseOptions( baseUrl: "https://www.xx.com/api", connectTimeout: 5000, receiveTimeout: 3000,
Dio dio = new Dio(options);
可以通过Options配置各种请求的信息,如Header。
文章来源: blog.csdn.net,作者:WongKyunban,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_40763897/article/details/108113973
