spark streaming 整合flume ,kafka 打造通用流处理
小米粒-biubiubiu 发表于 2020/12/02 23:53:24 2020/12/02
【摘要】 一、编写LoggerGenerator.java文件用于生成日志信息 添加依赖 <dependency> <groupId>org.apache.flume.flume-ng-clients</groupId> <artifactId>flume-ng-log4jappender</artifactId> &l...
添加依赖
  1. <dependency>
  2. <groupId>org.apache.flume.flume-ng-clients</groupId>
  3. <artifactId>flume-ng-log4jappender</artifactId>
  4. <version>1.6.0</version>
  5. </dependency>
编写  日志产生类 LoggerGenerator.java
  1. public class LoggerGenerator {
  2. private static Logger logger = Logger.getLogger(LoggerGenerator.class.getName());
  3. public static void main(String[] args) throws InterruptedException {
  4. int index = 0;
  5. while (true) {
  6. Thread.sleep(1000);
  7. logger.info("current value is " + index++);
  8. }
  9. }
  10. }
编写 log4j.properties 配置文件
  1. log4j.rootLogger=INFO,stdout,flume
  2. log4j.appender.stdout = org.apache.log4j.ConsoleAppender
  3. log4j.appender.stdout.Target = System.out
  4. log4j.appender.stdout.layout = org.apache.log4j.PatternLayout
  5. log4j.appender.stdout.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss,SSS} [%t] [%c] [%p] - %m%n
  6. #日志输出到flume
  7. log4j.appender.flume=org.apache.flume.clients.log4jappender.Log4jAppender
  8. log4j.appender.flume.Hostname=192.168.42.85
  9. log4j.appender.flume.Port=41414
  10. log4j.appender.flume.UnsafeMode=true
二、使用flume 采集 log4j产生的日志
cd  $FLUME_HOME/conf  ,编写 streaming.conf
  1. agent1.sources=avro-source
  2. agent1.channels=logger-channel
  3. agent1.sinks=log-sink
  4. agent1.sources.avro-source.type=avro
  5. agent1.sources.avro-source.bind=0.0.0.0
  6. agent1.sources.avro-source.port=41414
  7. agent1.channels.logger-channel.type=memory
  8. agent1.sinks.log-sink.type=logger
  9. agent1.sources.avro-source.channels=logger-channel
  10. agent1.sinks.log-sink.channel=logger-channel
启动 flume ,运行 日志产生的java 文件,可以看到 控制台上面有 采集到的log4j 日志输出
flume-ng agent \
--conf $FLUME_HOME/conf \
--conf-file $FLUME_HOME/conf/streaming.conf \
--name agent1 -Dflume.root.logger=INFO,console
三、将flume 收集到的数据输出到kafka
启动 zookeeper
./kafka-server-start.sh -daemon  $KAFKA_HOME/config/server.properties
jps
查看 topic
./kafka-topics.sh --list --zookeeper hadoop000:2181
创建一个 streamingtopic 主题
./kafka-topics.sh  --create --zookeeper hadoop000:2181  --replication-factor 1 --partitions  1  --topic  "streamingtopic"
cd   $FLUME_HOME/conf   ,编写  streaming2.conf
  3. agent1.sinks=kafka-sink
  8. agent1.sinks.kafka-sink.type=org.apache.flume.sink.kafka.KafkaSink
  9. agent1.sinks.kafka-sink.topic= streamingtopic
  10. agent1.sinks.kafka-sink.brokerList = hadoop000:9092
  11. agent1.sinks.kafka-sink.requiredAcks= 1
  12. agent1.sinks.kafka-sink.batchSize = 20
  13. agent1.sources.avro-source.channels=logger-channel
  14. agent1.sinks.kafka-sink.channel=logger-channel
启动 flume
flume-ng  agent  --name agent1  \
--conf-file $FLUME_HOME/conf/streaming2.conf  \
-Dflume.root.logger= INFO,console
启动 kafka
./kafka-console-consumer.sh --zookeeper hadoop000:2181 --topic  streamingtopic
 编写  KafkaReceiverWordCount.java  文件
  1. package com.dzx.scala.dzxbootscala.spark
  2. import kafka.serializer.{StringDecoder, StringEncoder}
  3. import org.apache.spark.SparkConf
  4. import org.apache.spark.streaming.kafka.KafkaUtils
  5. import org.apache.spark.streaming.{Seconds, StreamingContext}
  6. /**
  7. * @author DuanZhaoXu
  8. * @ClassName:
  9. * @Description:
  10. * @date 2019年01月03日 16:29:19
  11. */
  12. class KafkaReceiverWordCount {
  13. //args : hadoop000:2181 test streamingtopic 1
  14. def main(args: Array[String]): Unit = {
  15. if(args.length!=4){
  16. System.err.print("必须为四个参数")
  17. System.exit(1)
  18. }
  19. val Array(zkQuorum,group,topics,numThreads) =args
  20. val sparkConf = new SparkConf().setAppName("KafkaReceiverWordCount").setMaster("local[2]")
  21. val ssc = new StreamingContext(sparkConf, Seconds(5))
  22. //todo spark streaming 对接kafka
  23. val topicMap = topics.split(",").map((_,numThreads.toInt)).toMap
  24. val messages = KafkaUtils.createStream(ssc,zkQuorum,group,topicMap)
  25. // todo 测试为什么要取第二个
  26. messages.map(_._2).count.print()
  27. ssc.start()
  28. ssc.awaitTermination()
  29. }
  30. }
 运行LoggerGenerator.java ,确保 flume ,kafka 都启动好了之后,运行  KafkaReceiverWordCount .java  文件 , flume 每采集到 20条 日志, KafkaReceiverWordCount.java 文件的控制台就会 输出 一个 数字20.
现在是在本地 用 idea 运行 日志产生类,然后使用flume ,kafka ,spark streaming 进行 处理操作的,在生产上面我们需要打成一个jar 包
  • 将 日志产生类 打成 一个jar 包
  • 启动 flume 和 kafka、
  • spark  streaming 也是需要打成 jar包的,然后使用spark-submit的 方式进行 提交到环境上 执行
使用哪种方式,可以根据实际情况进行选择模式 : local/yarn/ standlone /mesos
 在生产上 整个 流处理的流程 是一样的,不同的是我们的业务逻辑的复杂性。
文章来源: blog.csdn.net,作者:血煞风雨城2018,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/qq_31905135/article/details/86158082
