Android项目的.gitgnore文件的作用及配置
yd_221104950 发表于 2020/12/03 01:10:11 2020/12/03
【摘要】 在使用Git版本管理工具的项目里都会有一个隐藏文件叫 .gitgnore,它的作用是忽略指定的文件,这样Git就不会去跟踪这些文件的修改,它们也不会被提交到版本库。典型的android studio IDE的android项目的.gitgnore配置: # Built application files *.apk *.ap_ *.aab # Files for t...
*.apk
*.ap_
*.aab
# Files for the ART/Dalvik VM
*.dex
# Java class files
*.class
# Generated files
bin/
gen/
out/
#  Uncomment the following line in case you need and you don't have the release build type files in your app
# release/
# Gradle files
.gradle/
build/
# Local configuration file (sdk path, etc)
local.properties
# Proguard folder generated by Eclipse
proguard/
# Log Files
*.log
# Android Studio Navigation editor temp files
.navigation/
# Android Studio captures folder
captures/
# IntelliJ
*.iml
.idea/workspace.xml
.idea/tasks.xml
.idea/gradle.xml
.idea/assetWizardSettings.xml
.idea/dictionaries
.idea/libraries
# Android Studio 3 in .gitignore file.
.idea/caches
.idea/modules.xml
# Comment next line if keeping position of elements in Navigation Editor is relevant for you
.idea/navEditor.xml
# Keystore files
# Uncomment the following lines if you do not want to check your keystore files in.
#*.jks
#*.keystore
# External native build folder generated in Android Studio 2.2 and later
.externalNativeBuild
# Google Services (e.g. APIs or Firebase)
# google-services.json
# Freeline
freeline.py
freeline/
freeline_project_description.json
# fastlane
fastlane/report.xml
fastlane/Preview.html
fastlane/screenshots
fastlane/test_output
fastlane/readme.md
# Version control
vcs.xml
# lint
lint/intermediates/
lint/generated/
lint/outputs/
lint/tmp/
# lint/reports/
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
谢谢阅读
文章来源: blog.csdn.net,作者:WongKyunban,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_40763897/article/details/102851193
