SpringMVC系列之原理简介和入门教程
yd_273762914 发表于 2020/12/03 00:51:21 2020/12/03
【摘要】 先看SpringMVC的图解 新建项目,新建一个config资源文件夹,配置文件 web.xml:   <?xml version="1.0" encoding="UTF-8"?><web-app version="2.5" xmlns="http://java.sun.com/xml/ns/javaee" xmlns:xsi="http://www.w3.o...
先看SpringMVC的图解
web.xml:
  1. <?xml version="1.0" encoding="UTF-8"?>
  2. <web-app version="2.5"
  3. xmlns="http://java.sun.com/xml/ns/javaee"
  4. xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  5. xsi:schemaLocation="http://java.sun.com/xml/ns/javaee
  6. http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd">
  7. <display-name></display-name>
  8. <welcome-file-list>
  9. <welcome-file>index.jsp</welcome-file>
  10. </welcome-file-list>
  11. <servlet>
  12. <!-- 搭建前端控制器Dispatcher -->
  13. <servlet-name>SpringMVC</servlet-name>
  14. <servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
  15. <!-- 设置SpringMVC配置文件的路径 -->
  16. <init-param>
  17. <param-name>contextConfigLocation</param-name>
  18. <param-value>classpath:applicationContext-mvc.xml</param-value>
  19. </init-param>
  20. </servlet>
  21. <servlet-mapping>
  22. <servlet-name>SpringMVC</servlet-name>
  23. <!-- 请求链接以.action结尾有DispatcherServlet进行解析 -->
  24. <url-pattern>*.action</url-pattern>
  25. </servlet-mapping>
  26. </web-app>
application-mvc.xml,这个是配置处理器映射、处理器适配器、视图解析器、Handler
  2. <beans xmlns="http://www.springframework.org/schema/beans"
  3. xmlns:aop="http://www.springframework.org/schema/aop"
  5. xmlns:context="http://www.springframework.org/schema/context"
  6. xmlns:mvc="http://www.springframework.org/schema/mvc"
  7. xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-4.0.xsd
  8. http://www.springframework.org/schema/aop http://www.springframework.org/schema/aop/spring-aop-4.0.xsd
  9. http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context-4.0.xsd
  10. http://www.springframework.org/schema/mvc http://www.springframework.org/schema/mvc/spring-mvc-4.0.xsd">
  11. <!-- 使用组件扫描 -->
  12. <!-- 将action扫描出来,在spring容器中进行注册,自动对action在spring容器中进行配置 -->
  13. <context:component-scan base-package="com.mvc" />
  14. <!-- 项目的Handler -->
  15. <bean name="/hello.action" class="com.mvc.action.HelloAction"></bean>
  16. <!-- 处理器映射器HandlerMapping -->
  17. <bean class="org.springframework.web.servlet.handler.BeanNameUrlHandlerMapping" />
  18. <!-- 处理器设配器HandlerAdapter -->
  19. <bean class="org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter" />
  20. <!-- 视图解析器ViewResolver -->
  21. <!-- 解析jsp,默认支持jstl -->
  22. <bean class="org.springframework.web.servlet.view.InternalResourceViewResolver">
  23. <property name="viewClass" value="org.springframework.web.servlet.view.JstlView"></property>
  24. <property name="prefix" value="/WEB-INF/jsp/" />
  25. <property name="suffix" value=".jsp" />
  26. </bean>
  27. <!-- 在实际开发中通常都需配置 mvc:annotation-driven标签,这个标签是开启注解 -->
  28. <mvc:annotation-driven></mvc:annotation-driven>
  29. </beans>
aopalliance.jar:这个包是AOP联盟的API包,里面包含了针对面向切面的接口。通常Spring等其它具备动态织入功能的框架依赖这个jar
spring-core.jar:这个jar 文件包含Spring 框架基本的核心工具类。Spring 其它组件要都要使用到这个包里的类,是其它组件的基本核心
,当然你也可以在自己的应用系统中使用这些工具类。
外部依赖Commons Logging, (Log4J)。
spring-beans.jar:这个jar 文件是所有应用都要用到的,它包含访问配置文件、创建和管理bean 以及进行Inversion of Control /
Dependency Injection(IoC/DI)操作相关的所有类。如果应用只需基本的IoC/DI 支持,引入spring-core.jar 及spring-beans.jar 文件
就可以了。
spring-aop.jar:这个jar 文件包含在应用中使用Spring 的AOP 特性时所需的类和源码级元数据支持。使用基于AOP 的Spring特性,如声明
型事务管理(Declarative Transaction Management),也要在应用里包含这个jar包。
外部依赖spring-core, (spring-beans,AOP Alliance, CGLIB,Commons Attributes)。
spring-context.jar:这个jar 文件为Spring 核心提供了大量扩展。可以找到使用Spring ApplicationContext特性时所需的全部类,JDNI
所需的全部类,instrumentation组件以及校验Validation 方面的相关类。
外部依赖spring-beans, (spring-aop)。
spring-context-support:Spring-context的扩展支持,用于MVC方面
spring-web.jar
这个jar 文件包含Web 应用开发时,用到Spring 框架时所需的核心类,包括自动载入Web Application Context 特性的类、Struts 与JSF
集成类、文件上传的支持类、Filter 类和大量工具辅助类。
外部依赖spring-context, Servlet API, (JSP API, JSTL, Commons FileUpload, COS)。
spring-webmvc.jar
这个jar 文件包含Spring MVC 框架相关的所有类。包括框架的Servlets,Web MVC框架,控制器和视图支持。当然,如果你的应用使用了独
立的MVC 框架,则无需这个JAR 文件里的任何类。
外部依赖spring-web, (spring-support,Tiles,iText,POI)。
spring-aspects.jar
提供对AspectJ的支持,以便可以方便的将面向方面的功能集成进IDE中,比如Eclipse AJDT。
外部依赖。
spring-jdbc.jar
这个jar 文件包含对Spring 对JDBC 数据访问进行封装的所有类。
外部依赖spring-beans,spring-dao。
spring-test.jar
对Junit等测试框架的简单封装
spring-tx.jar
Spring的tx事务处理的jar
spring-expression.jar
Spring表达式语言
Spring包依赖说明:
     1) spring-core.jar需commons-collections.jar,spring-core.jar是以下其它各个的基本。
     2) spring-beans.jar需spring-core.jar,cglib-nodep-2.1_3.jar
     3) spring-aop.jar需spring-core.jar,spring-beans.jar,cglib-nodep-2.1_3.jar,aopalliance.jar
     4) spring-context.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,commons-collections.jar,aopalliance.jar
     5) spring-dao.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,spring-context.jar
     6) spring-jdbc.jar需spring-core.jar,spring-beans.jar,spring-dao.jar
     7) spring-web.jar需spring-core.jar,spring-beans.jar,spring-context.jar
     8) spring-webmvc.jar需spring-core.jar/spring-beans.jar/spring-context.jar/spring-web.jar
     9) spring-hibernate.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,spring-dao.jar,spring-jdbc.jar,spring-
orm.jar,spring-web.jar,
        spring-webmvc.jar
     10) spring-orm.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,spring-dao.jar,spring-jdbc.jar,spring-web.jar
,spring-webmvc.jar
     11) spring-remoting.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,spring-dao.jar,spring-context.jar,
spring-web.jar,spring-webmvc.jar
     12) spring-support.jar需spring-core.jar,spring-beans.jar,spring-aop.jar,spring-dao.jar,spring-context.jar,
spring-jdbc.jar
     13) spring-mock.jar需spring-core.jar,spring-beans.jar,spring-dao.jar,spring-context.jar,spring-jdbc.jar
控制类HelloAction:
  1. package com.mvc.action;
  2. import javax.servlet.http.HttpServletRequest;
  3. import javax.servlet.http.HttpServletResponse;
  4. import org.springframework.web.servlet.ModelAndView;
  5. //@Controller:标记这个类是一个Handler处理器
  6. public class HelloAction implements org.springframework.web.servlet.mvc.Controller{
  7. public ModelAndView handleRequest(HttpServletRequest request,
  8. HttpServletResponse response) throws Exception {
  9. //在页面上提示一行信息
  10. String message = "hello world!";
  11. //通过request对象将信息在页面上展示
  12. //request.setAttribute("message", message);
  13. ModelAndView modelAndView = new ModelAndView();
  14. // 相当于request.setAttribute(), 将数据传到页面展示
  15. //model数据
  16. modelAndView.addObject("message", message);
  17. //设置视图
  18. modelAndView.setViewName("hello");
  19. return modelAndView;
  20. }
  21. }
hello.jsp:
  1. <%@ page language="java" import="java.util.*" pageEncoding="ISO-8859-1"%>
  2. <%
  3. String path = request.getContextPath();
  4. String basePath = request.getScheme()+"://"+request.getServerName()+":"+request.getServerPort()+path+"/";
  5. %>
  6. <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
  7. <html>
  8. <head>
  9. <base href="<%=basePath%>">
  10. <title>My JSP 'hello.jsp' starting page</title>
  11. <meta http-equiv="pragma" content="no-cache">
  12. <meta http-equiv="cache-control" content="no-cache">
  13. <meta http-equiv="expires" content="0">
  14. <meta http-equiv="keywords" content="keyword1,keyword2,keyword3">
  15. <meta http-equiv="description" content="This is my page">
  16. <!--
  17. <link rel="stylesheet" type="text/css" href="styles.css">
  18. -->
  19. </head>
  20. <body>
  21. ${message}
  22. </body>
  23. </html>
然后输入http://localhost:8080/SpringMVCDemo/hello.action就可以显示
文章来源: smilenicky.blog.csdn.net,作者:smileNicky,版权归原作者所有,如需转载,请联系作者。
原文链接:smilenicky.blog.csdn.net/article/details/51162206
