个人博客项目之editormd实现文章详情页面预览
yd_273762914 发表于 2020/12/03 00:49:42 2020/12/03
【摘要】 继之前博客写了editmd.js(国内开源的一款前端Markdown框架)实现的写文章功能之后,本博客介绍使用editormd实现文章预览功能,之前博客链接:https://blog.csdn.net/u014427391/article/details/86378811 要从上篇博客介绍的将Markdown语法的语句存储在数据库之后,读取出来,然后调用editorm...
要从上篇博客介绍的将Markdown语法的语句存储在数据库之后,读取出来,然后调用editormd的一些js脚本就可以实现
主要参考editormd提供的examples文件夹下面的html-preview-markdown-to-html.html
后台实现:
采用jpa实现
package net.myblog.repository;
import java.util.Date;
import java.util.List;
import net.myblog.entity.Article;
import org.springframework.data.domain.Page;
import org.springframework.data.domain.PageRequest;
import org.springframework.data.domain.Pageable;
import org.springframework.data.jpa.repository.Query;
import org.springframework.data.repository.PagingAndSortingRepository;
import org.springframework.data.repository.query.Param;
public interface ArticleRepository extends PagingAndSortingRepository<Article,Integer>{
	 * 获取文章详情信息
	 * @param articleId
	 * @return
	@Query("from Article a where a.articleId=:articleId")
	public Article getArticleInfo(@Param("articleId")int articleId);
  • 26
Service类:
	 * 获取文章详情信息
	 * @param articleId
	 * @return
	public Article getArticleInfo(int articleId) {
		return articleRepository.getArticleInfo(articleId);
Controller类
/** * 博客详情页面 * @return */ @RequestMapping(value = "/details") public ModelAndView details(@RequestParam("articleId")String articleId) { ModelAndView mv = this.getModelAndView(); Article article = articleService.getArticleInfo(Integer.parseInt(articleId)); mv.addObject("article",article); mv.setViewName("myblog/article/article_details"); return mv; }
jsp页面:
实现主要依赖于editormd.js提供的第三方库脚本:
<script src="plugins/editormd/lib/marked.min.js"></script>
<script src="plugins/editormd/lib/prettify.min.js"></script>
<script src="plugins/editormd/lib/raphael.min.js"></script>
<script src="plugins/editormd/lib/underscore.min.js"></script>
<script src="plugins/editormd/lib/sequence-diagram.min.js"></script>
<script src="plugins/editormd/lib/flowchart.min.js"></script>
<script src="plugins/editormd/lib/jquery.flowchart.min.js"></script>
<script src="plugins/editormd/editormd.js"></script>
前端的jsp页面:
<%@ page language="java" contentType="text/html; charset=UTF-8" pageEncoding="UTF-8"%>
<%@ taglib prefix="c" uri="http://java.sun.com/jsp/jstl/core"%>
<%@ taglib prefix="fmt" uri="http://java.sun.com/jsp/jstl/fmt"%>
	String path = request.getContextPath();
	String basePath = request.getScheme()+"://"+request.getServerName()+":"+request.getServerPort()+path+"/";
<!DOCTYPE html>
<html lang="zh">
<head>
	<base href="<%=basePath %>">
	<title>Nicky's blog</title>
	<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
	<meta name="Keywords" content="" >
	<meta name="Description" content="" >
	<meta name="keywords" content="" />
	<meta name="description" content="" />
	<link href="static/blog/css/blog.css" rel="stylesheet" />
	<link rel="stylesheet" href="plugins/editormd/css/editormd.preview.css" />
	<link href='http://fonts.googleapis.com/css?family=Arizonia' rel='stylesheet' type='text/css' />
	<style>
		.editormd-html-preview { width: 90%; margin: 0 auto;
	</style>
</head>
<body>
<%@ include file="../frame/top.jsp" %>
<div class="blank"></div>
<div class="article">
	<div class="content" id="layer">
		<div id="test-editormd-view"> <h2>${article.articleName}</h2> <textarea id="append-test" style="display:none;">${article.articleContent}</textarea>
		</div>
	</div>
</div>
<script src="static/js/jquery-1.8.3.js"></script>
<script type="text/javascript"> $(function() { var testEditormdView; /*$.get("test.md", function(markdown) { testEditormdView = editormd.markdownToHTML("test-editormd-view", { markdown : markdown ,//+ "\r\n" + $("#append-test").text(), //htmlDecode : true, // 开启 HTML 标签解析,为了安全性,默认不开启 htmlDecode : "style,script,iframe",  // you can filter tags decode //toc : false, tocm : true, // Using [TOCM] //tocContainer : "#custom-toc-container", // 自定义 ToC 容器层 //gfm : false, //tocDropdown : true, // markdownSourceCode : true, // 是否保留 Markdown 源码,即是否删除保存源码的 Textarea 标签 emoji : true, taskList : true, tex : true,  // 默认不解析 flowChart : true,  // 默认不解析 sequenceDiagram : true,  // 默认不解析 }); //console.log("返回一个 jQuery 实例 =>", testEditormdView); // 获取Markdown源码 //console.log(testEditormdView.getMarkdown()); //alert(testEditormdView.getMarkdown()); });*/ testEditormdView = editormd.markdownToHTML("test-editormd-view", { htmlDecode : "style,script,iframe",  // you can filter tags decode emoji : true, taskList : true, tex : true,  // 默认不解析 flowChart : true,  // 默认不解析 sequenceDiagram : true,  // 默认不解析 }); });
</script>
<%@ include file="../frame/footer.jsp" %>
</body>
</html>
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
文章来源: smilenicky.blog.csdn.net,作者:smileNicky,版权归原作者所有,如需转载,请联系作者。
原文链接:smilenicky.blog.csdn.net/article/details/86815407
