MySQL基础之字符类型学习笔记
yd_273762914 发表于 2020/12/02 22:22:55 2020/12/02
【摘要】 文章目录 一、字符集和字符编码1.1、字符集1.2、字符编码 二、字符集排序规则2.1、排序规则定义2.2 、排序规则特征 三、CHAR和VARCHAR3.1、CHAR类型3.2、VARCHAR类型 四、BINARY和VARBINARY4.1、特性对比4.2、例子实践 五、BLOB和TEXT5.1、text类型5.2、blob类型5.3、排序问题5.4、索引问题...
一、字符集和字符编码
1.1、字符集
  • 字符集:字符集就是字符的集合,例如GB2312是中国国家标准的简体中文字符集,GB2312收录简化汉字(6763个)及一般符号、序号、数字、拉丁字母、日文假名、希腊字母、俄文字母、汉语拼音符号、汉语注音字母,共 7445 个图形字符。
字符集查询sql:
# 方法一:直接show charset
SHOW CHARSET;
 #方法二:查询information_schema实例的character_sets
SELECT * FROM information_schema.character_sets;
我本地是5.7.22版本,支持的字符集就有如下:
Charset Description Default collation Maxlen
big5 Big5 Traditional Chinese big5_chinese_ci 2
dec8 DEC West European dec8_swedish_ci 1
cp850 DOS West European cp850_general_ci 1
hp8 HP West European hp8_english_ci 1
koi8r KOI8-R Relcom Russian koi8r_general_ci 1
latin1 cp1252 West European latin1_swedish_ci 1
latin2 ISO 8859-2 Central European latin2_general_ci 1
swe7 7bit Swedish swe7_swedish_ci 1
ascii US ASCII ascii_general_ci 1
ujis EUC-JP Japanese ujis_japanese_ci 3
sjis Shift-JIS Japanese sjis_japanese_ci 2
hebrew ISO 8859-8 Hebrew hebrew_general_ci 1
tis620 TIS620 Thai tis620_thai_ci 1
euckr EUC-KR Korean euckr_korean_ci 2
koi8u KOI8-U Ukrainian koi8u_general_ci 1
gb2312 GB2312 Simplified Chinese gb2312_chinese_ci 2
greek ISO 8859-7 Greek greek_general_ci 1
cp1250 Windows Central European cp1250_general_ci 1
gbk GBK Simplified Chinese gbk_chinese_ci 2
latin5 ISO 8859-9 Turkish latin5_turkish_ci 1
armscii8 ARMSCII-8 Armenian armscii8_general_ci 1
utf8 UTF-8 Unicode utf8_general_ci 3
ucs2 UCS-2 Unicode ucs2_general_ci 2
cp866 DOS Russian cp866_general_ci 1
keybcs2 DOS Kamenicky Czech-Slovak keybcs2_general_ci 1
macce Mac Central European macce_general_ci 1
macroman Mac West European macroman_general_ci 1
cp852 DOS Central European cp852_general_ci 1
latin7 ISO 8859-13 Baltic latin7_general_ci 1
utf8mb4 UTF-8 Unicode utf8mb4_general_ci 4
cp1251 Windows Cyrillic cp1251_general_ci 1
utf16 UTF-16 Unicode utf16_general_ci 4
utf16le UTF-16LE Unicode utf16le_general_ci 4
cp1256 Windows Arabic cp1256_general_ci 1
cp1257 Windows Baltic cp1257_general_ci 1
utf32 UTF-32 Unicode utf32_general_ci 4
binary Binary pseudo charset binary 1
geostd8 GEOSTD8 Georgian geostd8_general_ci 1
cp932 SJIS for Windows Japanese cp932_japanese_ci 2
eucjpms UJIS for Windows Japanese eucjpms_japanese_ci 3
gb18030 China National Standard GB18030 gb18030_chinese_ci 4
1.2、字符编码
  • 字符编码:字符编码是将字符映射为特定的字节或者字节序列,不过一般是特定的字符集采用特定的编码方式
字符编码查询sql:
#方法一:直接show collation
SHOW COLLATION;
#方法二:查询information_schema的collations
SELECT * FROM information_schema.collations;
查询一下字符编码,如下是5.7.22版本的,有222条记录:
注意:MySQL的字符集设置不进可以设置整一张表,也可以细到具体的每个字段上,用法是在建表或者修改字段时候加上charset [字符集名称]
二、字符集排序规则
2.1、排序规则定义
排序规则(Collation):排序规则是指对字符集下字符的比较规则。
2.2 、排序规则特征
排序规则特征:
  • 每个字符集都有一个默认的排序规则
  • 一个字符集对应一个排序规则,两个不同字符集不能有相同的排序规则
注意:排序规则常用的命名规范有:以_ci结尾的表示大小写不敏感(case insensitive),以_cs结尾的表示大小写敏感(case sensitive),以_bin结尾的表示二进制的比较(binary)
如图,选择一下collation,5.7.22版本的,大部分都是以ci结尾的,也就是大小写不敏感
例子:
# 建表,字符编码默认是utf8_general_ci
 CREATE TABLE t (
a VARCHAR(10)
 )CHARSET = utf8;
 # 写入两条数据
 INSERT INTO t SELECT 'a';
 INSERT INTO t SELECT 'A';
 # 查出两条数据,说明大小写不敏感
SELECT * FROM t WHERE a='a';
# 唯一索引也是不可以建的
ALTER TABLE t ADD UNIQUE KEY (a);
# 修改一下字符编码
ALTER TABLE t MODIFY COLUMN a VARCHAR(10) COLLATE utf8_bin;
# 查出一条数据,说明大小写敏感
SELECT * FROM t WHERE a = 'a';
# 这种情况 唯一索引是可以建的
三、CHAR和VARCHAR
char和varchar是两种最常见的字符串类型,其语法分别是char(N)和varchar(N),注意其中N在MySQL4.1版本后都表示字符的长度,而非字节长度,在MySQL4.1之前版本才表示字节的长度
3.1、CHAR类型
对于CHAR(N),N的范围为0~255
CHAR(N)是来保存固定长度的字符串,也是根据设置的值N,假如N设置为10,不管你传什么范围内的字符串,都是固定长度为10的,因为数据库为存储列的右边进行填充(Right padded),而在读取时候数据库又会自动将填充的字符删除.除非设置SQL_MODE属性PAD_CHAR_TO_FULL_LENGTH,才可以正常显示
例子实践:
# 建表实践
CREATE TABLE t (a CHAR(10));
# 写入数据
INSERT INTO t SELECT 'abcd';
# 查询
SELECT a, HEX(a), LENGTH(a), CHAR_LENGTH(a) FROM t;
# 查询全局SQL_MODE
SELECT @@global.sql_mode;
# 查询会话SQL_MODE
SELECT @@session.sql_mode;
# 设置SQL_MODE属性
SET SQL_MODE = 'PAD_CHAR_TO_FULL_LENGTH';
# 再次查询
3.2、VARCHAR类型
对于varchar类型是存储可变长字符串的,意思就是varchar(10)的列,我写字符串“abcd“,该列存储的4个字符,而char(10)的列才会存储10个字符
四、BINARY和VARBINARY
4.1、特性对比
BINARY(N)和VARBINARY(N)与前面介绍的CHAR(N)和VARCHAR(N)类型有点类似,BINARY可类比CHAR,VARBINARY可以类比VARCHAR类型。
对比:
  • 不同的是BINARY和VARBINARY存储的都是二进制类型的字符串,CHAR和VARCHAR存储的才是字符类型的字符串
  • BINARY和VARBINARY没有字符集的概念,CHAR和VARCHAR这些才有字符集的概念
  • BINARY(N)和VARBINARY(N)中的N表示的字节的长度,从前面我们知道CHAR(N)和VARCHAR(N)中的N自从MySQL4.1之后,就表示字符的长度
  • CHAR和VARCHAR进行字符比较时,是比较本身存储的字符,忽略填充的字符的,而BINARY和VARBINARY是不忽略的,比较的是二进制值的
4.2、例子实践
SELECT HEX('a'),
  HEX('a '),
  'a' = 'a ',
  BINARY('a') = BINARY('a ') ;
五、BLOB和TEXT
可以将blob类型的列视为足够大的varbinary类型的列,也可以将text类型的列视为足够大的varchar类型的列
5.1、text类型
TEXT 是用来存储字符大数据类型的,TEXT类型和blob类型一样,可以细分为:
  • tinytext(2^8)
  • text(2^16)
  • mediumtext(2^24)
  • longtext(2^32)
5.2、blob类型
BLOB(Binary Large Object)是用来存储二进制大数据类型的。根据存储长度的不同,blob类型可以细分为:
  • tinyblob(2^8)
  • blob(2^16)
  • mediumblob(2^24)
  • longblob(2^32)
5.3、排序问题
blob和text排序问题:
注意: BLOB和TEXT排序时只使用列的前max_sort_length个字节
SET GLOBAL max_sort_length =1024;
SELECT @@global.max_sort_length;
5.4、索引问题
blob和text加索引问题:
blob和text类型的列加索引时候,需要注意一些细节
  • 1、对于列不能有默认值
  • 2、加索引时需要指定索引前缀长度
CREATE INDEX indexName ON tablename(columnTest(1000));
六、ENUM和SET类型
6.1、集合类型简介
enum和set类型都是集合类型,不同是enum最多枚举65536个元素,而set类型最多枚举64个元素
6.2、集合类型例子
# 创建表验证问题
CREATE TABLE t (username VARCHAR(20),sex ENUM('male','female'))ENGINE=INNODB;
# 正常写数据
INSERT INTO t SELECT 'David','male';
INSERT INTO t SELECT 'john','female';
# 写数据,因为没有对应枚举类型,不过还是可以写入,不是警告而已
INSERT INTO t SELECT 'mariah','security';
# 查询出来,发现sex字段没值
select * from t ;
# 设置严格模式的
SET SQL_MODE = 'strict_trans_tables';
# 再次写数据,发现不可以写
# 再次查询没有写成功
SELECT * FROM t;
文章来源: smilenicky.blog.csdn.net,作者:smileNicky,版权归原作者所有,如需转载,请联系作者。
原文链接:smilenicky.blog.csdn.net/article/details/102716351
