MySQL基础之自连接用法简介
yd_273762914 发表于 2020/12/03 00:56:24 2020/12/03
【摘要】 MySQL系列之自连接简介,MySQL自连接操作,没有特定的关键字,所谓自连接指的是同一个表不同实例之间的join操作 引用https://www.w3resource.com的图示: 特征: 自连接是同一个表不同实例的连接操作自连接必须指定别名(aliasName)区分不同实例 自连接操作一般应用与有层级关系的表,最经典的就是员工/经理例子 ok,下面举例...
特征:
  • 自连接是同一个表不同实例的连接操作
  • 自连接必须指定别名(aliasName)区分不同实例
ok,下面举例说明
创建部门dept表
/*Table structure for table `dept` */
DROP TABLE IF EXISTS `dept`;
CREATE TABLE `dept` (
  `DEPTNO` int(2) NOT NULL,
  `DNAME` varchar(14) DEFAULT NULL,
  `LOC` varchar(13) DEFAULT NULL,
  PRIMARY KEY (`DEPTNO`)
) ENGINE=InnoDB DEFAULT CHARSET=utf8;
/*Data for the table `dept` */
# 往dept表写数据
insert  into `dept`(`DEPTNO`,`DNAME`,`LOC`) values (10,'ACCOUNTING','NEW YORK'),(20,'RESEARCH','DALLAS'),(30,'SALES','CHICAGO'),(40,'OPERATIONS','BOSTON');
创建员工emp表
DROP TABLE IF EXISTS `emp`;
CREATE TABLE `emp` (
  `EMPNO` int(4) NOT NULL,
  `ENAME` varchar(10) DEFAULT NULL,
  `JOB` varchar(9) DEFAULT NULL,
  `MGR` int(4) DEFAULT NULL,
  `HIREDATE` date DEFAULT NULL,
  `SAL` int(7) DEFAULT NULL,
  `COMM` int(7) DEFAULT NULL,
  `DEPTNO` int(2) DEFAULT NULL,
  PRIMARY KEY (`EMPNO`),
  KEY `FK_DEPTNO` (`DEPTNO`),
  CONSTRAINT `FK_DEPTNO` FOREIGN KEY (`DEPTNO`) REFERENCES `dept` (`DEPTNO`)
/*Data for the table `emp` */
# 往员工emp表写数据
insert  into `emp`(`EMPNO`,`ENAME`,`JOB`,`MGR`,`HIREDATE`,`SAL`,`COMM`,`DEPTNO`) values (7369,'SMITH','CLERK',7902,'1980-12-17',800,NULL,20),(7499,'ALLEN','SALESMAN',7698,'1981-02-20',1600,300,30),(7521,'WARD','SALESMAN',7698,'1981-02-22',1250,500,30),(7566,'JONES','MANAGER',7839,'1981-04-02',2975,NULL,20),(7654,'MARTIN','SALESMAN',7698,'1981-09-28',1250,1400,30),(7698,'BLAKE','MANAGER',7839,'1981-05-01',2850,NULL,30),(7782,'CLARK','MANAGER',7839,'1981-06-09',2450,NULL,10),(7788,'SCOTT','ANALYST',7566,'1987-04-19',3000,NULL,20),(7839,'KING','PRESIDENT',NULL,'1981-11-17',5000,NULL,10),(7844,'TURNER','SALESMAN',7698,'1981-09-08',1500,0,30),(7876,'ADAMS','CLERK',7788,'1987-05-23',1100,NULL,20),(7900,'JAMES','CLERK',7698,'1981-12-03',950,NULL,30),(7902,'FORD','ANALYST',7566,'1981-12-03',3000,NULL,20),(7934,'MILLER','CLERK',7782,'1982-01-23',1300,NULL,10);
这里使用左连接比较合适,因为顶级员工,也就是公司的总裁,是没有最上级的,用inner join的话,是不能获取数据的
SELECT a.ename AS empName,
  b.ename AS managerName
FROM
  emp a LEFT JOIN emp b ON a.mgr = b.empno
ORDER BY managerName ;
ok,根据sql,可以画出员工关系的图例,king是公司总裁
文章来源: smilenicky.blog.csdn.net,作者:smileNicky,版权归原作者所有,如需转载,请联系作者。
原文链接:smilenicky.blog.csdn.net/article/details/102931347
