Oracle应用之批量递增更新数据脚本
yd_273762914 发表于 2020/12/03 00:39:26 2020/12/03
【摘要】 需求:更新用户表的工号,格式为“GD1,GD2,…”的格式,如果有数据取最大值再递增 E1:先查询出是否有数据,有数据取最大值再递增,使用nvl函数 /* 查询max值*/ select nvl(max(to_number(replace(t.user_num, 'GD', ''))), 0) from t_user t where t.user_num li...
/* 查询max值*/
  from t_user t
 where t.user_num like 'GD%';
E2:创建Oracle序列,start with改为max值
/* Create sequence,start with改为max值 */
create sequence user_num_t_user
minvalue 1
maxvalue 999999999999999999999999999
start with 200
increment by 1
cache 20;
commit;
/* drop sequence */
drop sequence user_num_t_user;
E3:批量更新
/* batch update*/
 update t_user set user_num = 'GD' || user_num_t_user.nextval
  where user_num is null and IS_OUTNET_REG = 0;
E4:如果下次使用序列,记得更改start with的值,因为每次使用都会更新这个值的
上面方法是使用Oracle序列的方法,如果用Oracle的rownum,也是可以实现需求的,脚本如:
update t_user set user_num = 'GD' || (rownum + (select nvl(max(to_number(replace(t.user_num, 'GD', ''))), 0) from base_user t where t.user_num like 'GD%'))
 where user_num is null;
文章来源: smilenicky.blog.csdn.net,作者:smileNicky,版权归原作者所有,如需转载,请联系作者。
原文链接:smilenicky.blog.csdn.net/article/details/106146239
