C语言——创建文件
yd_221104950 发表于 2020/12/01 00:14:15 2020/12/01
【摘要】 创建文件 #include <stdio.h> int main(int argc,char *argv[]){ if(argc != 2){ printf("param error"); return 1; }else{ FILE *fd = fopen(*(argv+1),"w+"); if(fd != NULL){ printf("%s is cr...
创建文件
#include <stdio.h>
 }else{ FILE *fd = fopen(*(argv+1),"w+"); if(fd != NULL){ printf("%s is created.\n",*(argv+1)); }
  return 0;
编译运行:
~/Desktop/Mc$ gcc create.c -o create
~/Desktop/Mc$ ./create hello.txt
hello.txt is created.
wong@wong-computer:~/Desktop/Mc$ ls
hello.txt
谢谢阅读。
文章来源: blog.csdn.net,作者:WongKyunban,版权归原作者所有,如需转载,请联系作者。
原文链接:blog.csdn.net/weixin_40763897/article/details/87897660
