【GaussDB(DWS)】导入导出之copy使用详解
wzhyalfa 发表于 2020/11/30 23:36:13 2020/11/30
【摘要】 数据导入导出之copy使用方式,【数仓实践】GaussDB(DWS)导入导出之copy使用详解
收集了四种copy使用方式
 1. gsql元命令\copy
1
2
3
4
5
\copy { table [ ( column_list ) ] | ( query ) }
      { from | to } { filename | stdin | stdout | pstdin | pstdout } [ with ] [ binary ] [ oids ]
      [ delimiter [ as ] 'character' ] [ null [ as ] 'string' ] [ csv [ header ]
      [ quote [ as ] 'character' ] [ escape [ as ] 'character' ]
      [ force quote column_list | * ] [ force not null column_list ] ]
举例
 2. Sql语法的copy指令
1
2
3
4
5
6
7
8
9
10
11
12
13
COPY table_name [ ( column_name [, ...] ) ]
    FROM { 'filename' | STDIN }
    [ [ USING ] DELIMITERS 'delimiters' ]
    [ WITHOUT ESCAPING ]
    [ LOG ERRORS ]
    [ LOG ERRORS data ]
    [ REJECT LIMIT 'limit' ]
    [ [ WITH ] ( option [, ...] ) ]
    | copy_option
    | FIXED FORMATTER ( { column_name( offset, length ) } [, ...] ) [ ( option [, ...] ) | copy_option [  ...] ]
可选参数option子句语法有:
FORMAT 'format_name'| OIDS [ boolean ]| DELIMITER 'delimiter_character'| NULL 'null_string'| HEADER [ boolean ]| FILEHEADER 'header_file_string'| FREEZE [ boolean ]| QUOTE 'quote_character'| ESCAPE 'escape_character'| EOL 'newline_character'| NOESCAPING [ boolean ]| FORCE_QUOTE { ( column_name [, ...] ) | * }| FORCE_NOT_NULL ( column_name [, ...] )| ENCODING 'encoding_name'| IGNORE_EXTRA_DATA [ boolean ]| FILL_MISSING_FIELDS [ boolean ]| COMPATIBLE_ILLEGAL_CHARS [ boolean ]| DATE_FORMAT 'date_format_string'| TIME_FORMAT 'time_format_string'| TIMESTAMP_FORMAT 'timestamp_format_string'| SMALLDATETIME_FORMAT 'smalldatetime_format_string'
> LOG ERRORS  参数是一旦copy from存在非法记录时,记录到public.pgxc_copy_error_log错误表中,该表通过"SELECT copy_error_log_create() "创建错误日志表
> LOG ERRORS DATA与LOG ERRORS差别在于是否登记错误行数据信息(rawrecord)
> REJECT LIMIT 'limit',其中'limit'取值在1-INTMAX,若不限制该值则填写'unlimited'
> 未指定LOG ERRORS时,一旦存在出错行记录,直接报错
 3. java的CopyManager接口
> 执行时需要加载GaussDB(DWS) JDBC驱动
> 其实际使用是的copy xxx from/to STDIN/STDOUT标准输入或标准输出进行文件的加载、导出
 4. python psycopg2的copy_from/copy_to方法(有限使用)
1
2
3
4
5
6
7
8
9
10
#!/usr/bin/python
import psycopg2
with open('dat.txt', 'r') as f:
  cur.copy_from(f, 'wzy1',sep=',')
  sql="SELECT * from wzy1"
  cur.execute(sql)
  print(cur.fetchall())
  #[(1, 'a'), (2, 'b'),(3, 'c')]
差异点说明
  1.  使用元命令“\copy”或python psycopg2“copy_from/copy_to”,只需要普通用户即可执行,但错误处理能力有限,只能整体成功或整体失败,且加载的是客户端文件;
  2. 指定服务器文件的SQL的copy语法:
    > 一旦指定服务器的文件,该copy命令只允许拥有sysadmin权限执行,不论是否存在LOG ERRORS
  3. 通过标准输入进行数据加载的SQL的copy语法:
    > 普通用户也可以使用copy from STDIN命令
    > 若希望使用错误日志表,则需提前在public创建日志表,且给对应普通用户赋权,然后就可以正常使用
    管理员:select copy_error_log_create();  grant insert,select on public.pgxc_copy_error_log to wzy;
    普通用户:copy wzy.wzy1 from STDIN log errors reject limit 'unlimited' with (delimiter ',') ;
    即实现: gsql -d postgres -p 25308 -ar -U wzy -W xxx  -c "copy wzy1 from STDIN log errors reject limit 'unlimited' with (delimiter ',')" < dat.txt
