实践系列-GaussDB(DWS)不下推语句总结
爱加班的叶凡 发表于 2020/11/26 15:14:23 2020/11/26
【摘要】 MPPDB不支持下推的用法总结
说明:
文中customer表定义如下:
CREATE TABLE CUSTOMER
(C_CUSTKEY     BIGINT NOT NULL
, C_NAME        VARCHAR(25) NOT NULL
, C_ADDRESS     VARCHAR(40) NOT NULL
, C_NATIONKEY   INT NOT NULL
, C_PHONE       CHAR(15) NOT NULL
, C_ACCTBAL     DECIMAL(15,2)   NOT NULL
, C_MKTSEGMENT  CHAR(10) NOT NULL
, C_COMMENT     VARCHAR(117) NOT NULL
)     distribute by hash(C_CUSTKEY);
1      语法上不支持下推的查询:
1.1      Distinct不支持下推的场景
1)  如果count(distinct expr)中的字段不支持重分布,则不支持下推
示例:
create table test_stream(a int,b float); //float不支持重分布
postgres=# explain select count(distinct b) from test_stream;
                                           QUERY PLAN
 Aggregate  (cost=2.50..2.51 rows=1 width=8)
   ->  Data Node Scan on test_stream "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=8)
         Node/s: All datanodes
(3 rows)
1.2      Count(distinct) + group by 如果group by的字段不支持重分布,则不支持下推
示例:
postgres=#  explain select count(distinct(a)) from test_stream group by b order by b;
                                               QUERY PLAN
 GroupAggregate  (cost=49.83..57.43 rows=10 width=12)
   Group By Key: test_stream.b
   ->  Sort  (cost=49.83..52.33 rows=1000 width=12)
         Sort Key: test_stream.b
         ->  Data Node Scan on test_stream "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=12)
(6 rows)
IsTypeDistributable:不支持的重分布类型
1.3      不支持distinct on用法下推:
示例:
postgres=# explain select distinct on (c_custkey) c_custkey from customer;
                                             QUERY PLAN
 Unique  (cost=49.83..54.83 rows=10 width=8)
   ->  Sort  (cost=49.83..52.33 rows=1000 width=8)
         Sort Key: customer.c_custkey
         ->  Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=8)
(5 rows)
1.4      不支持聚集函数中使用order by语句的下推:
示例:
postgres=#  explain select count(c_custkey order by c_custkey) from customer;
                                          QUERY PLAN
 Aggregate  (cost=2.50..2.51 rows=1 width=4)
   ->  Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=4)
(3 rows)
1.5      不支持范围表查询的下推,即使用 WITH RECURSIVE
示例:
postgres=# explain WITH RECURSIVE customer_recursive(c_name, c_nationkey) AS (
SELECT 1, c_nationkey FROM customer WHERE c_custkey = 1)
SELECT *  FROM customer_recursive;
                                           QUERY PLAN
 CTE Scan on customer_recursive  (cost=0.00..20.00 rows=1000 width=8)
   CTE customer_recursive
           Node/s: datanode1
(4 rows)
1.6      不支持returning语句下推:
示例:
postgres=# explain update customer set c_name = 'a' returning c_name;
                                           QUERY PLAN
 Update on customer  (cost=0.00..0.00 rows=1000 width=498)
   Node expr: c_custkey
   ->  Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=498)
(5 rows)
1.7      无from list也不支持下推
示例:
select cd_education_status, min(cd_gender), cd_dep_employed_count,grouping(cd_dep_employed_count)
from customer_demographics
group by 1 ,cube(1,3),cd_dep_employed_count >all (select distinct length(cd_demo_sk)
where cd_purchase_estimate = 500 and cd_education_status like '%da%')
having(case when length(trim(both 'e'
from cd_education_status)) > 8 then 'YES' when length(trim(both 'e'
from cd_education_status)) < 8 then 'NO' end) = 'YES'
and cd_dep_employed_count not in (2,4,5)
order by 1, 2, 3,4;
1.8      with recursive不下推场景
(1)       enable_stream_recursive为off,with recursive语法不下推
(2)       With-Recursive中涉及的基表在多nodegroup中不下推
(3)       with recursive语法其他不支持下推的场景
序号
场景
不下推原因
1
WITH recursive t_result AS (
  SELECT concat(test_rec.dm,test_rec.sj_dm),*
  FROM test_rec
  WHERE dm = '3'
  UNION ALL
  SELECT
concat(t1.dm,t1.sj_dm),t2.*
  FROM t_result t1
  JOIN test_rec t2 ON t2.dm = t1.sj_dm
  SELECT * FROM t_result;
带有不下推函数
2
explain (costs off, nodes off) with recursive rq as
    select id, name from  chinamap where id = 11
    union
    select origin.id, rq.name || ' > ' ||   origin.name
    from rq join chinamap origin on   origin.pid = rq.id
select id, name from rq order   by 1;
                              QUERY PLAN
 Sort
   Sort Key: rq.id
   CTE rq
     ->    Recursive Union
           ->  Data Node Scan on chinamap   "_REMOTE_TABLE_QUERY_"
           ->  Hash Join
                 Hash Cond: (origin.pid =   rq.id)
                 ->  Hash
                       ->  WorkTable Scan on rq
   ->    CTE Scan on rq
(11 rows)
With-Recursive不包含ALL
2
with recursive all_path(id, neighbor, path) as (
    SELECT
      id, neighbor,
ARRAY[id]
    FROM graph WHERE id = 'A'
      union all
    SELECT
      all_path.id,
      graph.neighbor,
ARRAY[graph.id]
    FROM graph
    JOIN all_path
    ON all_path.neighbor = graph.id
  select * from all_path;
数组操作
3
with recursive cte as
  (select area_code, area_code as chain, 1 as level /*chain
为路径,例如>101>201>203;level为层级,从1开始*/
  from gcms.gcm_mag_area_h
  where area_code='100000'
  union all
  select h.area_code,cast(cte.chain||'>'||h.area_code as   varchar2(30)),cte.level+1
  from cte
  join gcms.gcm_mag_area_h h
  on h.belong_area_code=cte.area_code and cte.level <3 and h.area_code
not in (select   regexp_split_to_table(cte.chain,'>') )/*如果是循环的结构,可以用chain来退出循环;此处cte.level<6表示到第6层停止*/
  select * from cte;
1.subquery里面包含不带fromlist
  2.
包含相关子查询
4
select
  dm,
  select distinct f.dm, f.sj_dm, f.name from test_rec_1 f where   f.sj_dm=t1.sj_dm
  union all
  select distinct f.dm, f.sj_dm, f.name from test_rec_1 f join cte on
  f.dm=cte.sj_dm
  select distinct dm from cte where sj_dm=7
  ) dm_2
  sj_dm, name
  from test_rec t1;
相关子查询
5
  SELECT dm,sj_dm,name,1 as level
  FROM test_rec_part
  WHERE sj_dm < 10
  UNION all
  SELECT t2.dm,t2.sj_dm,t2.name||' > '||t1.name,t1.level+1
  FROM t_result t1
  JOIN test_rec_part t2 ON
1=2
  SELECT *
  FROM t_result t;
join条件恒不成立
6
  select * from(
  FROM test_rec_part
  WHERE sj_dm < 10
limit 6 offset 2)
  UNION all
  FROM t_result t1
  JOIN test_rec_part t2 ON t2.sj_dm = t1.dm
  SELECT *
  FROM t_result t;
non recursive term包含limit offset
7
  FROM test_rec_part
  WHERE sj_dm < 10
  UNION all
  FROM t_result t1
  JOIN test_rec_part t2 ON t2.sj_dm = t1.dm and t1.sj_dm>t2.dm
  SELECT *
  FROM
t_result t where dm < 5
  union all
  SELECT *
  FROM
t_result t where dm > 5;
output阶段多次调用cte
8
with recursive t_result1 as (
    select id,pid,name as name,1 as level from test_date where   pid='2018-12-31 23:59:54'
      union all
    select t2.id,t2.pid,t2.name||' > '||t1.name, t1.level+1 from   t_result1 t1 join test_date t2 on t1.id=t2.pid
t_result2 as (
    select id,pid,name,1 as level from test_date where id='2018-12-31   23:59:54'
      union all
    select t2.id,t2.pid,t1.name||' > '||t2.name, t1.level+1 from   t_result2 t1 join
t_result1 t2 on t1.pid=t2.id
  select * from t_result1 join t_result2 on t_result1.id<t_result2.id;
并列多个递归cte,并且有相互引用(即:存在CTE嵌套)
9
  SELECT
max(dm) as dm,max(sj_dm) as sj_dm,max(name) as name
  FROM test_rec
  WHERE dm = '3'
  UNION ALL
  FROM t_result t1
t2.dm = t1.sj_dm
  SELECT *
  FROM t_result;
agg结果做递归条件
10
WITH RECURSIVE migora_cte AS(
  --non recursive term
  with b as (
  select * FROM dams_branch b
  WHERE b.stru_sname LIKE '%' || 'a' || '%'
  AND b.stru_state IN ('1', '2')
  AND b.stru_sign <> '7')
  SELECT
  stru_id ,stru_sname ,stru_lv ,stru_sort  ,b.stru_id::text AS   MIG_ROW_ALIAS1 ,b.sort AS MIG_ROW_ALIAS2
  FROM dams_branch b
  WHERE b.stru_id = 100
  AND b.stru_state IN ( '1' ,'2' )
  UNION ALL
  --recursive term
  SELECT b.stru_id ,b.stru_sname ,b.stru_lv ,b.stru_sort   ,mig_ora_cte_tab_alias.MIG_ROW_ALIAS1 || '*' || b.stru_id AS MIG_ROW_ALIAS1   ,b.sort AS MIG_ROW_ALIAS2
  FROM migora_cte mig_ora_cte_tab_alias INNER JOIN dams_branch b ON   mig_ora_cte_tab_alias.stru_id = b.sup_stru AND b.stru_state IN ( '1' ,'2' )
  SELECT stru_id ,stru_sname
  FROM migora_cte b
  ORDER BY
  sign( instr( b.MIG_ROW_ALIAS1 ,'a' ) ) DESC ,b.stru_lv ,b.stru_sort DESC   NULLS LAST ,MIG_ROW_ALIAS2 DESC ,
nlssort(stru_sname,   'NLS_SORT=SCHINESE_PINYIN_M') ;
order by nlssort
1.9      表在目标列中不支持下推
postgres=# explain select customer from customer;
                                       QUERY PLAN
 Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=40 width=580)
(2 rows)
2      表对象不支持下推:
Roundrobin、modulo
2.1                     对于普通表,不支持RROBIN 、MODULO两种分布的查询下推
示例:
postgres=# create by table test(a int) distribute roundrobin;
CREATE TABLE
postgres=# explain select * from test;
                                     QUERY PLAN
 Data Node Scan on test "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1000 width=4)
(2 rows)
postgres=# create table test(a int) distribute by  modulo(a);
CREATE TABLE
                                     QUERY PLAN
3      函数不支持下推:
3.1      不支持下推的聚集函数:
array_agg、string_agg、xmlagg、every、curval、setval、lastval、nextval、pg_backend_pid、pg_stat_get_backend_pid
3.2      不支持下推的普通函数:
注:查询函数属于那种类型使用:select provolatile from pg_proc where proname='funcname';
示例:
postgres=# select provolatile from pg_proc where proname='lastval';
 provolatile
 v
(1 row)
其中:v 代表易变的,即VOLATILE;s代表稳定的,即stable;i代表不变的,即IMMUTABLE
3.2.1        对于IMMUTABLE的函数,都是支持下推的,除了every  函数
示例:
postgres=#  select provolatile from pg_proc where proname='int8um';
 provolatile
 i
(1 row)
postgres=# explain select int8um(C_CUSTKEY)  from CUSTOMER;
                           QUERY PLAN
 Streaming (type: GATHER)  (cost=0.00..40.50 rows=40 width=8)
   ->  Seq Scan on customer  (cost=0.00..10.12 rows=10 width=8)
(3 rows)
3.2.2        对于易变的(VOLATILE)函数,都是不支持下推的,函数的返回值为RECORD类型的不支持下推
示例:
CREATE OR REPLACE FUNCTION test_proc( i integer,j out integer)
RETURN record
AS
    result int;
    BEGIN
        RETURN NULL;
    END;
postgres=# explain select test_proc(1) from customer;
                                        QUERY PLAN
 Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..250.00 rows=1000 width=0)
(2 rows)
易变函数不支持下推:
示例:
postgres=# select  provolatile from pg_proc where proname='random';
 provolatile
 v
(1 row)
postgres=# explain select random() from CUSTOMER;
                                       QUERY PLAN
 Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..2.50 rows=1000 width=0)
(2 rows)
3.2.3        对于稳定的(stable)的函数,只有部分是支持下推的;
支持的函数列表如下:
       to_date(两个参数)
       to_date(一个参数)
       pg_column_size
       abstimein,
       abstimeout
       reltimein,
       reltimeout,
       tintervalin,
       tintervalout,
       cash_in,
       cash_out,
       numeric(cash),
       money(numeric),
       money(int2),
       money(int8),
       date_in,
       date_out,
       time_in,
       time_out,
       timestamp_in,
       timestamp_out,
       smalldatetime_in,
       timestamp_out,
       timestamptz_out,
       smalldatetime_out,
       interval_in,
       date_part(text,timestamptz),
       timestamptz(date),
       timestamptz(date,time),
       date(timestamptz),
       date(abstime),
       timestamptz_pl_interval,
       timestamptz_mi_interval,
       date_trunc(text,timestamptz),
       timetz_in,
       time(abstime),
       date_part(text,abstime),
       date_part(text,reltime),
       timetz(timestamptz),
       to_timestamp(text,text),
       time(timestamptz),
       timestamp(abstime),
       timestamp(timestamptz),
       timestamptz(timestamp),
       abstime(timestamp),
       timetz(time),
       date_lt_timestamptz,
       date_le_timestamptz,
       date_eq_timestamptz,
       date_gt_timestamptz,
       date_ge_timestamptz,
       date_ne_timestamptz,
       date_cmp_timestamptz,
       timestamptz_lt_date,
       timestamptz_le_date,
       timestamptz_eq_date,
       timestamptz_gt_date,
       timestamptz_ge_date,
       timestamptz_ne_date,
       timestamptz_cmp_date,
       timestamp_lt_timestamptz,
       timestamp_le_timestamptz,
       timestamp_eq_timestamptz,
       timestamp_gt_timestamptz,
       timestamp_ge_timestamptz,
       timestamp_ne_timestamptz,
       timestamp_cmp_timestamptz,
       timestamptz_lt_timestamp,
       timestamptz_le_timestamp,
       timestamptz_eq_timestamp,
       timestamptz_gt_timestamp,
       timestamptz_ge_timestamp,
       timestamptz_ne_timestamp,
       timestamptz_cmp_timestamp,
       interval_pl_timestamptz
3.3      not shippable关键字不下推
CREATE FUNCTION shipping_func_time_02() RETURNS timestamptz
    AS 'select clock_timestamp();'
    LANGUAGE SQL
    stable not shippable
RETURNS NULL ON NULL INPUT;
explain (costs off)  select shipping_func_time_02(),t5.c from t4, t5 where t4.b=t5.a order by 1 limit 3;
                          QUERY PLAN
 Limit
   ->  Hash Join
         Hash Cond: (t4.b = t5.a)
         ->  Data Node Scan on t4 "_REMOTE_TABLE_QUERY_"
         ->  Hash
               ->  Data Node Scan on t5 "_REMOTE_TABLE_QUERY_"
(8 rows)
/* 修改函数为下推函数 */
alter function shipping_func_time_02() shippable;
/* 查看函数定义是否下推 */
select proname,proshippable from pg_proc where proname='shipping_func_time_02' or proname='shipping_func_time_01' or proname='shipping_func_time_03' order by 1;
3.4      current_user / user不下推
postgres=# explain select * from customer where c_name=current_user;
                                      QUERY PLAN
 Data Node Scan on customer "_REMOTE_TABLE_QUERY_"  (cost=0.00..0.00 rows=1 width=556)
(2 rows)
SQL语句中存在current_user或user写法时不能下推,需要替换为可下推语法。方法如下:
在库中创建如下函数current_user_select(),并将业务中使用的current_user替换为current_user_select即可实现下推。
CREATE   OR REPLACE FUNCTION public.current_user_select()
RETURNS   name
LANGUAGE   internal
immutable   STRICT
AS   $function$current_user$function$;
示例如下:
原语句
select current_user from emp;
原语句
select current_user_select() from emp;
3.5      sysdate / current_date / SYSTIMESTAMP不下推
SQL语句中存在sysdate或current_date写法时不能下推,同时,mpp不支持SYSTIMESTAMP,需要使用current_timetamp(0)替换。方法如下:
原语句
select sysdate from emp;
新语句
select current_timestamp(0) from emp;
原语句
select current_date from emp;
新语句
原语句
select SYSTIMESTAMP from emp;
新语句
注:必须带有参数才能下推,即使用current_timestamp(0)。current_timestamp带有时间及时区信息,如果不需要,可以使用substr函数截取。
