Huawei 5G Mobile WiFi Router (E6878-870) Review
ltemodem 发表于 2020/11/12 14:21:41 2020/11/12
【摘要】 Huawei 5G Mobile WiFi Router (E6878-870) Review
Huawei 5G Mobile WiFi (E6878-870) is one of the first 5G portable routers on the market to support the innovative 5G mobile internet standard.
Support European and Asian 5G networks
In addition to the n78 and n79 networks, the Huawei E6878 model supports the n41 and n77 5G bands, as well as all popular 4G Internet standards. At the same time, it is possible to work both in full-fledged 5G networks (SA mode) and in the NSA transition mode, which operators will use in the first stages of creating 5G networks.
Download speed up to 1.65 Gbps
To ensure maximum performance when working with large amounts of data, Huawei has used its own powerful Balong 5000 chipset.
The maximum data download speed in 5G networks is 1.65 Gbps. Such high values, unattainable for cellular networks of previous generations, are now possible due to the use of wide bandwidth in new bands, as well as the use of assistive technologies. When working in 4G networks, the maximum download speed of information will be 300 Mbps.
The built-in WiFi module allows you to create a local wireless network at 2.4 and 5 GHz frequencies. The high-speed 802.11ac standard enables data transfer rates of up to 867 Mbps between connected devices. The Huawei 5G pocket WiFi router supports up to 20 simultaneous connections.
Manage and configure Huawei E6878
On the body of the device there is a monochrome LCD screen (1.45 ″), with the help of which you can get basic information about the operation of the device (battery charge, signal level, number of connected devices, etc.). Access to deep user settings, allowing you to administer the WiFi network and configure the parameters of the mobile connection, is carried out through the proprietary mobile application or the web interface of the router.
The USB Type-C port is for charging the battery and connecting the router to a computer. The Nano-SIM slot for installing an operator card is located behind a protective shutter. The 5G WiFi router has no restrictions on the operator used and can be used with SIM cards from any service provider.
Built-in 4000mAh battery
The Huawei E6878-870 router is equipped with a built-in 4000 mAh battery, which allows the device to work in a completely autonomous mode and provide Internet access for many subscriber devices connected via WiFi. According to the manufacturer, the battery capacity is sufficient for 20 days in standby mode. It also supports 18W fast charging (Quick Charge).
Huawei E6878-870 is a device at the cutting edge of modernity and high technology. The design of the router is attractive and detailed. The 5G router from Huawei is compact and lightweight and lightweight, easy to take with you on your business trip or vacation. The acquisition of the E6878-870 is an investment in the future, since it is in the development of 5G networks that operators will invest the main efforts.
Huawei 5G Mobile WiFi (E6878-870) Specifications
Frequency ranges LTE FDD: Band 1/3/5/7/8/20/28/32 (2100/1800/850/2600/900/800/700/1500 MHz)
LTE TDD: Band 34/38/39/40/41 / 42
(2000/2600/1900/2300/3500 MHz)
5G TDD: Band n41 / n77 / n78 / n79 (2500/3700/3500/4700 MHz)
Supported 5G Modes SA / NSA
Maximum speed of mobile connection LTE: Receive up to 300 Mbps, transmit up to 75 Mbps
5G: Receive up to 1.65 Gbps, transmit up to 250 Mbps
SIM format Nano-SIM
WiFi frequency bands 2.4 GHz, 5 GHz
WiFi standards 802.11a / b / g / n / ac
WiFi Max Speed up to 300 Mbps in the 2.4 GHz frequency range
up to 867 Mbps in the 5 GHz frequency range
Maximum number of WiFi client devices 20
Chipset Balong 5000
Connectors 1 x USB Type-C
1 x Nano-SIM
LCD screen 1.45 inch monochrome
Battery 4000 mAh, non-removable
Battery standby time up to 20 days
Nutrition fast charging 18W (Quick Charge)
Operating temperature from 0 ° С to + 35 ° С
Storage temperature from -20 ° С to + 60 ° С
Permissible humidity 5% to 95% (non-condensing)
The size 148 x 72 x 12 mm
The weight 172 g
Equipment router, power adapter, USB - USB Type-C cable, manual
Huawei 5G Mobile WiFi Router (E6878-870): https://www.4gltemall.com/huawei-5g-mobile-wifi-e6878-870.html
