华为海思 hikey970开发板n介绍
一颗小树x 发表于 2020/11/08 11:23:17 2020/11/08
【摘要】 之前申请到了华为的开发板:hikey970 用来做项目的。板子是这样的:下面是在网中收集到的信息总结:基于麒麟970的AI智慧算力,HiKey 970除了支持CPU和GPU的AI运算外,还支持基于NPU的神经网络计算硬件加速。公开资料显示,麒麟970每分钟识别2005张图片; 而在没有NPU的情况下,同样时间识别的图片只有97张。可见NPU在AI运算中的惊人实力。在麒麟970的加持下,Hi...
板子是这样的:
下面是在网中收集到的信息总结:
公开资料显示,麒麟970每分钟识别2005张图片; 而在没有NPU的情况下,同样时间识别的图片只有97张。可见NPU在AI运算中的惊人实力。在麒麟970的加持下,HiKey 970的AI性能得到全面提升,AI算力强大、支持硬件加速、性能强劲。与CPU处理相同的AI运算相比,HiKey 970拥有约50倍能效和25倍性能优势。
规格表
  Component
  Description
  Processor Series
  Kirin
  SoC
  Hisilicon Kirin 970
  CPU
  4 ARM Cortex-A73 + 4 ARM  Cortex-A53
  GPU
  ARM Mali-G72 MP12
  AI
  Dedicated Neural-network  Processing Unit (NPU)
  Memory
  6GB LPDDR4 SDRAM
  Storage
  64GB UFS flash storage
  Micro SD card slot
  PCIE Gen2 on M.2 M Key connector
  Wireless
  WiFi(2.4 -and 5-GHz dual band with two antennas)
  Bluetooth   4.1
  GPS, Glonass
  USB
  2 x USB 3.0 type A(host only)
  1 x USB 2.0 type C(OTG)
  1 x USB 2.0 (host only)
  Display
  1 x  HDMI1.4 (Type A -full)
  1 x  4L - MIPI DSI
  HDMI  outout up to FHD 1080P
  Video
  MPEG2@80Mbps, MPEG4@50Mbps, H264@240Mbps,  H265@160Mpbs,
  VP8@100Mbps, VP9@120Mbps
  Audio
  HDMI output
  Camera
  1 x 4-lane MIPI CSI
  1 x 2-lane MIPI CSI
  Expansion                    Interface
  40  pin low speed expansion connector:+1.8V, +5V, DC power, GND, 2UART, 2I2C,SPI,I2S,12*GPIO
  60  pin high speed expansion connector:4L-MIPI DSI, I2C X2, SPI(48M),USB 2.0,
  2L +4LMIPI CSI
  CAN
  Implements  CAN V2.0B at 1Mb/s: 0-8 byter length in the data field; Standard and
  extended  data and remote frames
  Receive buffers, masks  and filters:Two receive buffers with prioritized message
  storage;  Six 29-bit filters; Two 29-bit masks
  Ethernet
  gigabit ethernet
  LED
  1 x WiFi activity LED
  1 x BT activity LED
  4 x User LEDs
  Button
  Power  Button : Button Power on /off & Reset the system
  Power Source
  Recommend a 12V@2A adaptor with a DC pulg which has a 4.75mm
  outer   diameter and 1.7mm center pin with standard center -positive(EIAJ-3
  Compliant)
  OS Support
  AOSP/LINUX
  Appearance characteristic
  100mm x 85mm x 10mm
简介
HiKey 970 是华为第三代开发板,具有更强的计算能力、更丰富的硬件接口,支持主流操作系统和人工智能栈 (AI stack)。HiKey 970 集成了华为创新设计的 HiAI 框架,以及其他主流的神经网络框架,不但支持 CPU、GPU AI 运算,还支持基于NPU 的神经网络计算硬件加速,能效和性能分别可达 CPU 运算的 50 倍、25 倍。
应用场景
深度学习, 机器人, 自动驾驶, 智慧城市
背面图:
而针对为什么一定要让AI跑在端侧,华为无线终端芯片产品市场总监周晨也表示,端侧AI解决的两个核心问题是实时和隐私。整个通信行业都对低时延有着执着的追求,具体到AI应用领域来说,加入用摄像头做一个实时的应用,如果将所有数据上传到云端,在云端处理完再传回来,这种处理时长带来的用户体验几乎是不可接受的。
另一个问题就是隐私。大家是否愿意把所有东西都传到云端去?手机现在就是一个内容生产工具,每天都会产生大量的隐私信息,这些数据与其放在别人那里,不如放在自己口袋里,这也是端侧AI非常重要的一点。
作为第三代开发板,HiKey 970不仅性能强悍,还在前两代开发板的基础上吸收了大量开发者对于软件和硬件设计的意见,满足开发者的需要,整体计算能力更强,硬件接口也更丰富,还支持主流操作系统以及AI栈,是一款十分适合AI应用开发的平台,也因为强悍的性能和良好的开发者友好性,备受业界好评。
构建AI生态,助力开发者创造AI应用价值
HiKey 970支持HiAI移动计算架构,具有全球领先的AI性能,为AI应用开发者带来一剂“强心针”。HiAI移动计算平台是一个开放的AI生态,能够基于开发者的需求将麒麟970的AI能力“赋予”第三方的应用。
现在的开发者在做开发的时候非常关注开发成本、收益和IP保护3个方面,而HiAI正好能够完美解决开发者的痛点。HiKey 970提供了完善的多应用模式与机器学习框架的支持,可为开发者提供更加完善的文档、更丰富高效的API以及更快速上手的源码,让开发者们能够更直接地感受到AI在端侧的巨大潜力,创造出AI的应用价值。
此外,HiAI移动计算平台还能支持丰富的前端主流Framework、提供丰富的上层功能业务API,可在移动设备高效运行、提供模型的加密方案,保护开发者知识产权并且支持异构资源灵活调度,满足开发者加速神经网络模型计算和算子计算。
要想推动AI的发展,不仅需要性能强大的AI硬件,更需要搭建AI生态。AI生态搭建离不开全行业的共同创新,更离不开千万开发者的努力与亿万用户的体验和反馈,而华为作为其中的一员,也在积极完善AI生态布局。
基于HiKey 970完善的开发环境、配套SDK及丰富的算子,开发者能够在HiAI平台上发挥各种关于AI应用的想象,并在华为的终端设备上将想象变成现实。未来,HiKey 970也将助力开发者进行深度学习算法、智能机器人以及智慧城市领域的开发,助力AI应用的生态搭建,让智慧生活从想象成为现实。
开发文档:https://www.96boards.org/documentation/consumer/hikey/hikey970/
希望对你有帮助。
