Huawei 5G Mobile WiFi Pro (E6878-370) Review
ltemodem 发表于 2020/11/05 10:49:33 2020/11/05
【摘要】 Huawei 5G Mobile WiFi Pro (E6878-370) Review
Huawei 5G Mobile WiFi Pro (E6878-370) is one of the most powerful and versatile 5G pocket WiFi routers on the market. The Huawei 5G pocket WiFi is equipped with a fast WiFi module, a high-capacity battery, a wired and wireless power bank function, and at the same time easily fits in a jacket or briefcase pocket. Huawei E6878-370 can work not only in 5G networks, but also in 4G standards, which allows mobile users to stay ahead of their time and prepare in advance for the arrival of 5G in large cities.
Huawei's all-in-one portable 5G solution
Huawei E6878-370 supports multiple 5G bands, including the promising n78 and n79 standards. The capabilities of the router provide for work in both transient networks (NSA) and full-fledged autonomous 5G networks (SA). In the absence of 5G coverage, the router automatically switches to 4G / LTE mode.
Huawei 5G Mobile WiFi Pro delivers 4G download speeds up to 300Mbps. When 5G networks are launched, the data acquisition speed increases to 1.65 Gbps - an indicator unattainable for networks of previous generations. Record performance is driven by the wide bandwidth available in the new 5G bands, as well as assistive technologies.
The Huawei 5G WiFi router can be used with any telecom operator. The SIM-slot of the Nano-SIM format is installed under a plastic shutter that protects the device from dust and moisture getting into the case, as well as protects against accidental removal of the card.
Fast WiFi module and easy setup
The connection of subscriber devices (smartphones, tablets, laptops, game consoles and various peripherals) to the router is carried out via a WiFi network. The wireless module installed in Huawei E6878-370 supports 2.4 and 5 GHz modes and covers any WiFi devices. When operating in the 801.11ac standard, the router provides the ability to transfer data at speeds up to 867 Mbps.
The monochrome LCD on the front of the router displays basic information about the current operating mode, mobile signal strength, number of wireless connections, and battery charge status. Some basic settings can be changed by the user using the control keys and OSD. Access to advanced network parameters is carried out through the web interface or the proprietary Huawei application.
Huawei 5G Mobile WiFi Pro is equipped with a miniature USB Type-C connector, which is used to charge the battery, as well as to connect the router to a laptop or computer. Supports fast charging of the router using SuperCharge technology (40 W).
5G router and powerbank with wireless charging in one case
The Huawei E6878-370 model is equipped with an 8000 mAh battery, which allows you to operate the router in standalone mode and maintain a WiFi network for many user devices.
Another unique feature of the router is the ability to use it as a wireless or wired power bank! Huawei 5G Mobile WiFi Pro supports FastCharge (15W) wireless charging. Wired charging is performed via a full-size USB Type-A port using SuperCharge technology (22.5W).
Huawei 5G Mobile WiFi Pro (E6878-370) router is an innovative and practical gadget that combines stylish design, convenience and high technology. Ahead of its time, the Huawei router invites you to look into the mobile world of tomorrow. Light weight and dimensions, utmost ergonomics and user-friendliness - all this Huawei 5G Mobile WiFi Pro!
What's the difference between Huawei E6878-370 and Huawei E6878-870?
Huawei E6878-370 is a more "advanced" version of the Huawei E6878-870 router. Unlike its similar counterpart, the E6878-370 has a larger battery (8000 mAh versus 4000 mAh), supports 40W fast charging (versus 18W) and can be used as a full-fledged wired or wireless power bank. Due to the use of a high-capacity battery, the Huawei E6878-370 has a slightly larger size. If you want to know more about the difference, click here: https://www.4gltemall.com/blog/difference-between-huawei-5g-mobile-wifi-pro-e6878-370-and-e6878-870/
Advantages of Huawei 5G Mobile WiFi Pro (E6878-370):
  • Support for promising 5G standards n78 and n79;
  • Download speed up to 1.65 Gbps in 5G networks and up to 300 Mbps in 4G networks;
  • Suitable for use in Asia, Middle East and Europe;
  • High capacity 8000 mAh battery with fast charging function (40 W);
  • Wireless SuperCharge function (15 W);
  • SuperCharge wired power bank function (22.5 W);
  • LCD display and OSD;
  • Modern stylish design.
Huawei 5G Mobile WiFi Pro E6878-370 Specifications
Frequency ranges LTE FDD: Band 1/3/5/7/8/20/28/32 (2100/1800/850/2600/900/800700/1500 MHz)
LTE TDD: Band 34/38/39/40/41/42 (2000/26001900/2300/3500 MHz)
5G TDD: Band n41 / n77 / n78 / n79 (2500/3700/3500/4700 MHz)
Supported 5G Modes SA / NSA
Maximum speed of mobile connection LTE: Receive up to 300 Mbps, transmit up to 75 Mbps
5G: Receive up to 1.65 Gbps, transmit up to 250 Mbps
SIM format Nano-SIM
WiFi frequency bands 2.4 GHz, 5 GHz
WiFi standards 802.11a / b / g / n / ac
WiFi Max Speed         up to 300 Mbps in the 2.4 GHz frequency range
up to 867 Mbps in the 5 GHz frequency range
Maximum number of WiFi client devices 20
Chipset Balong 5000
Connectors 1 x USB Type-C
1 x USB Type-A
1 x Nano-SIM
LCD screen 1.45 inch monochrome
Battery 8000 mAh, non-removable
Power (charging) SuperCharge 10V, 4A
SuperCharge 4.5V, 5A
SuperCharge 5V, 4.5A
FastCharge 9V, 2A
Power supply of other devices (power bank) wired charging (USB Type-A):
FastCharge 9V, 2A;wired charging (USB Type-C):
FastCharge 9V, 2A
FastCharge 5V, 3A
wireless charging:
FastCharge 15W (only for Huawei smartphones);
Supports wireless charging of devices from other manufacturers that are compatible with the Qi standard
Operating temperature from 0 ° С to + 35 ° С
Storage temperature from -20 ° С to + 60 ° С
Permissible humidity 5% to 95% (non-condensing)
The size 148 x 72 x 18 mm
The weight 280 g
Equipment router, power adapter, USB - USB Type-C cable, manual
Check more about Huawei 5G Mobile WiFi Pro (E6878-370)here: https://www.4gltemall.com/huawei-5g-mobile-wifi-pro.html
