K8s使用命令发布nginx
Nick Qiu 发表于 2020/10/25 21:44:42 2020/10/25
【摘要】 命令发布deploymentskubectl run webserver --image=nginx:alpine 查看当前主机的deployments[root@node1 ~]# kubectl get deployments NAME DESIRED CURRENT UP-TO-DATE AVAILABLE AGEwebserver 1 ...
  • 命令发布deployments
  • 查看当前主机的deployments
webserver   1         1         1            1           2m
[root@node1 ~]# kubectl get pods
NAME                         READY     STATUS    RESTARTS   AGE
webserver-86dfd744b7-hs4n8   1/1       Running   0          2m
  • 删除对应的pod,然后再查看pod,我们会看到系统重新启动了一个不同的nginx pod
[root@node1 ~]# kubectl delete pod webserver-86dfd744b7-hs4n8
pod "webserver-86dfd744b7-45vh6" deleted
webserver-86dfd744b7-c54bk   1/1       Running   0          4s
  • 发布服务
[root@node1 ~]# kubectl expose deployment webserver --type=LoadBalancer --port=80
service/webserver exposed
  • 获取service 状态,32378 对应开放的主机ip
[root@node1 ~]# kubectl get services
NAME         TYPE           CLUSTER-IP     EXTERNAL-IP   PORT(S)        AGE
kubernetes   ClusterIP      10.68.0.1      <none>        443/TCP        13d
webserver    LoadBalancer   10.68.169.12   <pending>     80:32378/TCP   34s
  • 获取pod所在的node ip
[root@node1 ~]# kubectl get pod -o wide
NAME                         READY     STATUS    RESTARTS   AGE       IP            NODE           NOMINATED NODE
webserver-86dfd744b7-c54bk   1/1       Running   0          7m        172.20.2.12   192.168.3.93   <none>
  • 访问 nginix
curl http://192.168.3.93:32378
  • 清理删除创建资源
[root@node1 ~]# kubectl delete service webserver
service "webserver" deleted
[root@node1 ~]# kubectl delete deployment webserver
deployment.extensions "webserver" deleted
