Spring boot jpa (一) entity
Nick Qiu 发表于 2020/10/25 21:37:33 2020/10/25
【摘要】 前言本文介绍如何使用spring boot jpa entity。开发环境如下:项目说明jdk1.8idea2017-03(已经安装lombok插件)mysql 5.6推荐使用dockernavicatmysql 客户端操作步骤新建spring boot项目使用navicat新建数据库db_example修改配置文件./src/main/resources/application.prope...
前言
开发环境如下:
项目 说明
jdk 1.8
idea 2017-03(已经安装lombok插件)
mysql 5.6 推荐使用docker
navicat mysql 客户端
操作步骤
  • 新建spring boot项目
  • 使用navicat新建数据库db_example
  • 修改配置文件./src/main/resources/application.properties
spring.jpa.hibernate.ddl-auto=create
spring.datasource.url=jdbc:mysql://localhost:3306/db_examplespring.datasource.username=root
spring.datasource.password=123456
  • 添加实体类book
package org.nick.bootstart.model;/*
 * @Author      : Nick
 * @Description :
 * @Date        : Create in 12:18 2018/4/30
 **/import lombok.AllArgsConstructor;import lombok.Data;import lombok.Generated;import lombok.NoArgsConstructor;import javax.persistence.*;import java.util.HashSet;import java.util.Objects;import java.util.Set;@Data@NoArgsConstructor@AllArgsConstructor@Entitypublic class Book {    @Id
    @GeneratedValue(strategy = GenerationType.AUTO)    private long id;    private String title;    private String isbn;    public String publisher;    @ManyToMany
    @JoinTable(name = "author_book", joinColumns = @JoinColumn(name = "book_id"), inverseJoinColumns = @JoinColumn(name = "author_id"))    public Set<Author> authors = new HashSet<>();    @Override
    public boolean equals(Object o) {        if (this == o) return true;        if (o == null || getClass() != o.getClass()) return false;
        Book book = (Book) o;        return id == book.id &&
                Objects.equals(title, book.title) &&
                Objects.equals(isbn, book.isbn) &&
                Objects.equals(publisher, book.publisher);
    }    @Override
    public int hashCode() {        return Objects.hash(id);
    }    @Override
    public String toString() {        return "Book{" +                "id=" + id +                ", title='" + title + '\'' +                ", isbn='" + isbn + '\'' +                ", publisher='" + publisher + '\'' +                '}';
  • 添加Author
 * @Author      : Nick
 * @Description :
 * @Date        : Create in 12:36 2018/4/30
 **/import lombok.AllArgsConstructor;import lombok.Data;import lombok.NoArgsConstructor;import javax.persistence.*;import java.util.HashSet;import java.util.Set;@Data@NoArgsConstructor@AllArgsConstructor@Entitypublic class Author {    @Id
    @GeneratedValue(strategy = GenerationType.AUTO)    private long id;    private String firstName;    private String lastName;    @ManyToMany(mappedBy = "authors")    private Set<Book> books = new HashSet<>();
  • 执行程序
  • 打开navicat 查看数据库,发现已经初始化了相关表;
这里spring.jpa.hibernate.ddl-auto可以是none,update,create,create-drop。具体含义如下:
  • none 不改变表结构
  • update 通过entity结构改变数据库结构
  • create 每次都打开的时候新建数据库,关闭的时候删除数据库
  • create-drop 创建数据库,然后在SessionFactory关闭的时候删除数据库;
