5.Rabbitmq Routing
Nick Qiu 发表于 2020/10/25 21:24:26 2020/10/25
【摘要】 前言Routing模式通过routingKey,决定发送和接收路径架构如下:代码build.gradleplugins { id 'java'}group 'com.nick'version '1.0-SNAPSHOT'sourceCompatibility = 1.8repositories { mavenCentral()}dependencies { testComp...
前言
代码
  • build.gradle
plugins {
    id 'java'}
repositories {
    mavenCentral()
dependencies {
    testCompile group: 'junit', name: 'junit', version: '4.12'
    compile group: 'com.rabbitmq', name: 'amqp-client', version: '5.2.0'
    compile group: 'org.slf4j', name: 'slf4j-api', version: '1.7.25'
    compile group: 'org.slf4j', name: 'slf4j-simple', version: '1.7.25'
    compile group: 'org.projectlombok', name: 'lombok', version: '1.18.0'}
  • ReceiveLogsDirect.java
package com.nick.Routing;import com.rabbitmq.client.*;import java.io.IOException;public class ReceiveLogsDirect {    private static final String EXCHANGE_NAME = "direct_logs";    public static void main(String[] argv) throws Exception {
        ConnectionFactory factory = new ConnectionFactory();
        factory.setHost("192.168.5.136");
        Connection connection = factory.newConnection();
        Channel channel = connection.createChannel();
        channel.exchangeDeclare(EXCHANGE_NAME, "direct");
        String queueName = channel.queueDeclare().getQueue();
        channel.queueBind(queueName, EXCHANGE_NAME, "ERROR");
        channel.queueBind(queueName, EXCHANGE_NAME, "INFO");
        System.out.println(" [*] Waiting for messages. To exit press CTRL+C");
        Consumer consumer = new DefaultConsumer(channel) {            @Override
            public void handleDelivery(String consumerTag, Envelope envelope,
                                       AMQP.BasicProperties properties, byte[] body) throws IOException {
                String message = new String(body, "UTF-8");
                System.out.println(" [x] Received '" + envelope.getRoutingKey() + "':'" + message + "'");
        channel.basicConsume(queueName, true, consumer);
  • EmitDebugLogDirect.java
package com.nick.Routing;import com.rabbitmq.client.Channel;import com.rabbitmq.client.Connection;import com.rabbitmq.client.ConnectionFactory;import java.util.concurrent.TimeoutException;public class EmitDebugLogDirect {    private static final String EXCHANGE_NAME = "direct_logs";    public static void main(String[] argv)
            throws java.io.IOException, TimeoutException {
        String severity = "DEBUG";
        String message = "debug message";
        channel.basicPublish(EXCHANGE_NAME, severity, null, message.getBytes());
        System.out.println(" [x] Sent '" + severity + "':'" + message + "'");
        channel.close();
        connection.close();
  • EmitErrorLogDirect.java
package com.nick.Routing;import com.rabbitmq.client.Channel;import com.rabbitmq.client.Connection;import com.rabbitmq.client.ConnectionFactory;import java.util.concurrent.TimeoutException;public class EmitErrorLogDirect {    private static final String EXCHANGE_NAME = "direct_logs";    public static void main(String[] argv)
        String severity = "ERROR";
        String message = "error message";
        channel.close();
        connection.close();
测试
  • 先执行接收;
  • 分别执行发送debug和error;
  • 在接收窗口上可以看到error消息有收到,debug接收不到;
完整代码
https://github.com/qiujiahong/rabbitmq_study
