3.rabbitmq Work Queues
Nick Qiu 发表于 2020/10/25 21:22:19 2020/10/25
【摘要】 3.rabbitmq Work Queues同步滚动:开前言本文介绍java客户端如何实现工作队列,入下图所示,生产者P生产消息,消息传送到队列,C1,C2轮流消费消息。代码build.gradleplugins { id 'java'}group 'com.nick'version '1.0-SNAPSHOT'sourceCompatibility = 1.8repositories...
同步滚动:开
前言
代码
  • build.gradle
plugins {
    id 'java'}
repositories {
    mavenCentral()
dependencies {
    testCompile group: 'junit', name: 'junit', version: '4.12'
    compile group: 'com.rabbitmq', name: 'amqp-client', version: '5.2.0'
    compile group: 'org.slf4j', name: 'slf4j-api', version: '1.7.25'
    compile group: 'org.slf4j', name: 'slf4j-simple', version: '1.7.25'
    compile group: 'org.projectlombok', name: 'lombok', version: '1.18.0'}
  • send.java
package com.nick.workQueues;import com.rabbitmq.client.Channel;import com.rabbitmq.client.Connection;import com.rabbitmq.client.ConnectionFactory;import com.rabbitmq.client.MessageProperties;import java.util.concurrent.TimeoutException;public class Send {    private static final String TASK_QUEUE_NAME = "task_queue";    public static void main(String[] argv)
            throws java.io.IOException, TimeoutException {
        ConnectionFactory factory = new ConnectionFactory();
        factory.setHost("192.168.5.136");
        Connection connection = factory.newConnection();
        Channel channel = connection.createChannel();
        channel.queueDeclare(TASK_QUEUE_NAME, true, false, false, null);
        String message = "hello work queues";
        channel.basicPublish( "", TASK_QUEUE_NAME,
                MessageProperties.PERSISTENT_TEXT_PLAIN,
                message.getBytes());
        System.out.println(" [x] Sent '" + message + "'");
        channel.close();
        connection.close();
  • Rev1.java
package com.nick.workQueues;import com.rabbitmq.client.*;import java.io.IOException;public class Rev1 {    private static final String TASK_QUEUE_NAME = "task_queue";    public static void main(String[] argv) throws Exception {
        factory.setHost("192.168.5.136");        final Connection connection = factory.newConnection();        final Channel channel = connection.createChannel();
        System.out.println(" [*] Waiting for messages. To exit press CTRL+C");
        channel.basicQos(1);        final Consumer consumer = new DefaultConsumer(channel) {            @Override
            public void handleDelivery(String consumerTag, Envelope envelope, AMQP.BasicProperties properties, byte[] body) throws IOException {
                String message = new String(body, "UTF-8");
                System.out.println(" 1.Received:[x]  '" + message + "'");                try {
                    doWork(message);
                } finally {
                    System.out.println(" [x] Done");
                    channel.basicAck(envelope.getDeliveryTag(), false);
        };        boolean autoAck = false;
        channel.basicConsume(TASK_QUEUE_NAME, autoAck, consumer);
    }    private static void doWork(String task) {        for (char ch : task.toCharArray()) {            if (ch == '.') {                try {
                    Thread.sleep(1000);
                } catch (InterruptedException _ignored) {
                    Thread.currentThread().interrupt();
  • Rev2
package com.nick.workQueues;import com.rabbitmq.client.*;import java.io.IOException;public class Rev2 {    private static final String TASK_QUEUE_NAME = "task_queue";    public static void main(String[] argv) throws Exception {
                System.out.println(" 2.Received:[x]  '" + message + "'");                try {
                    doWork(message);
                } finally {
                    Thread.sleep(1000);
测试
  • 执行Rev1.java
  • 执行Rev2.java
  • 多次执行执行Send.java,可以看到控制台对应的输出,可以看到接收窗口2个接收进程轮流接收数据;
详细代码见
https://github.com/qiujiahong/rabbitmq_study
