2.rabbitmq 简单生产消费
Nick Qiu 发表于 2020/10/25 21:18:34 2020/10/25
【摘要】 前言本文简要介绍如何使用java客户端,连接rabbitmq server。本文开始之前,需要安装好mq服务器,如果不知道怎么安装,可参考rabbitmq安装使用架构使用gradle java项目代码build.gradleplugins { id 'java'}group 'com.nick'version '1.0-SNAPSHOT'sourceCompatibility = 1....
前言
  • 使用架构
  • 使用gradle java项目
代码
  • build.gradle
plugins {
    id 'java'}
group 'com.nick'version '1.0-SNAPSHOT'sourceCompatibility = 1.8
repositories {
    mavenCentral()
dependencies {
    testCompile group: 'junit', name: 'junit', version: '4.12'
    compile group: 'com.rabbitmq', name: 'amqp-client', version: '5.2.0'
    compile group: 'org.slf4j', name: 'slf4j-api', version: '1.7.25'
    compile group: 'org.slf4j', name: 'slf4j-simple', version: '1.7.25'
    compile group: 'org.projectlombok', name: 'lombok', version: '1.18.0'}
  • send 生产者(p)
package com.nick.simpleTest;import com.rabbitmq.client.Channel;import com.rabbitmq.client.Connection;import com.rabbitmq.client.ConnectionFactory;import org.slf4j.Logger;import org.slf4j.LoggerFactory;import java.util.concurrent.TimeoutException;public class Send {    private final static String QUEUE_NAME = "hello";    public  static Logger logger =  LoggerFactory.getLogger(Send.class);    public static void main(String[] argv)
            throws java.io.IOException, TimeoutException {
        ConnectionFactory factory = new ConnectionFactory();
        factory.setHost("192.168.1.249");
        Connection connection = factory.newConnection();
        Channel channel = connection.createChannel();
        channel.queueDeclare(QUEUE_NAME, false, false, false, null);
        String message = "Hello World!";
        channel.basicPublish("", QUEUE_NAME, null, message.getBytes());
        logger.info(" [x] Sent '{}'" ,message );
        channel.close();
        connection.close();
  • receive 消费者(c)
package com.nick.simpleTest;import com.rabbitmq.client.*;import org.slf4j.Logger;import org.slf4j.LoggerFactory;import java.io.IOException;import java.util.concurrent.TimeoutException;public class Recv {    private final static String QUEUE_NAME = "hello";    public static Logger logger = LoggerFactory.getLogger(Recv.class);    public static void main(String[] argv)
        logger.info(" [*] Waiting for messages. To exit press CTRL+C");
        Consumer consumer = new DefaultConsumer(channel) {            @Override
            public void handleDelivery(String consumerTag, Envelope envelope,
                                       AMQP.BasicProperties properties, byte[] body)
                    throws IOException {
                String message = new String(body, "UTF-8");
                logger.info(" [x] Received '" + message + "'");
        channel.basicConsume(QUEUE_NAME, true, consumer);
测试
  • 先运行消费者,再运行生产者,效果截图如下:
完整代码
完整代码可以在github上下载到。
