nginx配置https转http&wss转ws
Nick Qiu 发表于 2020/10/25 21:12:18 2020/10/25
【摘要】 前言安装软件下载yum -y install gcc pcre pcre-devel zlib zlib-devel openssl openssl-develwget http://nginx.org/download/nginx-1.17.5.tar.gztar -xzvf nginx-1.17.5.tar.gzcd nginx-1.17.5配置nginx./configure --pr...
前言
安装软件
  • 下载
  • 配置nginx
./configure --prefix=/usr/local/nginx --sbin-path=/usr/bin/nginx --with-http_ssl_module --with-http_realip_module --with-http_sub_module --with-stream --with-http_stub_status_module
./configure --help 可以查看配置项说明
完成之后的配置文件见:/usr/local/nginx/conf/nginx.conf,参数配置说明:https://nginx.org/en/docs/configure.html
  • 编译
make && make install
  • 修改配置文件
#user  nobody;worker_processes  1;#error_log  logs/error.log;#error_log  logs/error.log  notice;#error_log  logs/error.log  info;#pid        logs/nginx.pid;events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server{
        listen 80;
        server_name domain.com;        #告诉浏览器有效期内只准用 https 访问
        add_header Strict-Transport-Security max-age=15768000;        #永久重定向到 https 站点
        return 301 https://$server_name$request_uri;
    server {
        listen       443 ssl;
        server_name  domain.com;        # 需要准备好证书
        ssl_certificate /usr/local/nginx/conf/cr/server.pem;
        ssl_certificate_key /usr/local/nginx/conf/cr/server.key;
        #ssl_session_cache    shared:SSL:1m;
        ssl_session_timeout  5m;        #协议配置
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
        ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE;         # 转发到http
        location / {
           proxy_pass http://domain.com;
    }   # wss -> ws
    server {
        listen       82 ssl;
        ssl_certificate_key /usr/local/nginx/conf/cr/server.key;        #ssl_session_cache    shared:SSL:1m;
        # ssl_session_timeout  5m;
        #协议配置
        # ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
        ssl_protocols SSLv3 SSLv2 TLSv1 TLSv1.1 TLSv1.2;
        ssl_session_timeout  10m;
        ssl_prefer_server_ciphers on;        # ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:HIGH:!aNULL:!MD5:!RC4:!DHE;
         # 转发到http
        location / {           # 转发ws地址
           proxy_pass http://10.1.1.23:82;
           proxy_http_version 1.1;
           proxy_set_header Upgrade $http_upgrade;           #由于服务器端源码(建议大家做好大小写匹配)只匹配了"Upgrade"字符串,所以如果这里填"upgrade"服务器端会将这条http请求当成普通的请求,导致websocket握手失败
           proxy_set_header Connection "Upgrade";
           proxy_set_header Remote_addr $remote_addr;
           proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
           proxy_read_timeout 600s;
  • 重启生效
nginx -s reload
