DWS gsql快捷指令
瘸子那条好腿 发表于 2020/10/13 14:53:09 2020/10/13
【摘要】 gsql快捷指令
快捷命令:
 \d[S+] list tables, views, and sequences
 \d[S+] NAME describe table, view, sequence, or index
 \db[+] [PATTERN] list tablespaces
 \dg[+] [PATTERN] list roles
 \di[S+] [PATTERN] list indexes
 \dn[S+] [PATTERN] list schemas
 \do[S] [PATTERN] list operators
 \dO[S+] [PATTERN] list collations
 \dp [PATTERN] list table, view, and sequence access privileges
 \drds [PATRN1 [PATRN2]] list per-database role settings
 \ds[S+] [PATTERN] list sequences
 \dt[S+] [PATTERN] list tables
 \dT[S+] [PATTERN] list data types
 \du[+] [PATTERN] list roles
 \dv[S+] [PATTERN] list views
 \dE[S+] [PATTERN] list foreign tables
 \dx[+] [PATTERN] list extensions
 \l[+] list all databases
 \sf[+] FUNCNAME show a function's definition
 \z [PATTERN] same as \dp
 \dd[S] [PATTERN] show object descriptions not displayed elsewhere
 \ddp [PATTERN] list default privileges
 \dD[S+] [PATTERN] list domains
 \ded[+] [PATTERN] list data sources
 \det[+] [PATTERN] list foreign tables
 \des[+] [PATTERN] list foreign servers
 \deu[+] [PATTERN] list user mappings
 \dew[+] [PATTERN] list foreign-data wrappers
 \df[antw][S+] [PATRN] list [only agg/normal/trigger/window] functions
 \dF[+] [PATTERN] list text search configurations
 \dFd[+] [PATTERN] list text search dictionaries
 \dFp[+] [PATTERN] list text search parsers
 \dFt[+] [PATTERN] list text search templates
 \dl list large objects, same as \lo_list
 \dL[S+] [PATTERN] list procedural languages
