如何读取超大XML文件-Asp.Net Core?
Jet Ding 发表于 2020/09/30 17:39:24 2020/09/30
【摘要】 本文旨在为读取超大XML文件提供一种解决方案。测试环境: .Net Core 3.1测试文件:73G代码: var file = Path.Combine("D:/data/stackoverflow/stackoverflow.com-Posts", "", "", "Posts.xml"); using (Xml...
测试环境: .Net Core 3.1
测试文件:73G
代码:
            using (XmlReader reader = XmlReader.Create(file))
                while (reader.Read())
                    switch (reader.NodeType)
                        case XmlNodeType.Element:
                            if (reader.HasAttributes)
                                Console.WriteLine("Attributes of <" + reader.Name + ">");
                                while (reader.MoveToNextAttribute())
                                    Console.WriteLine(" {0}={1}", reader.Name, reader.Value);
                                // Move the reader back to the element node.
                                reader.MoveToElement();
                            break;
                        case XmlNodeType.Text:
                            Console.Write(reader.Value);
                            break;
                        case XmlNodeType.CDATA:
                            Console.Write("<![CDATA[{0}]]>", reader.Value);
                            break;
                        case XmlNodeType.ProcessingInstruction:
                            Console.Write("<?{0} {1}?>", reader.Name, reader.Value);
                            break;
                        case XmlNodeType.Comment:
                            Console.Write("<!--{0}-->", reader.Value);
                            break;
                        case XmlNodeType.XmlDeclaration:
                            Console.Write("<?xml version='1.0'?>");
                            break;
                        case XmlNodeType.Document:
                            break;
                        case XmlNodeType.DocumentType:
                            Console.Write("<!DOCTYPE {0} [{1}]", reader.Name, reader.Value);
                            break;
                        case XmlNodeType.EntityReference:
                            Console.Write(reader.Name);
                            break;
                        case XmlNodeType.EndElement:
                            Console.Write("</{0}>", reader.Name);
                            break;
读取结果
