用javascript在nodejs环境下读取超大的Stackoverflow XML文件
Jet Ding 发表于 2020/09/30 16:55:53 2020/09/30
【摘要】 本文旨在为nodejs环境下读取超大XML文件提供一种解决方案。编程语言: javascript平台:nodejs测试文件大小: 73G程序包: "node-xml-stream": "^1.0.2"代码示例:const loadXml = () => { try { let Parser = require("node-xml-stream"); let fs =...
编程语言: javascript
平台:nodejs
测试文件大小: 73G
程序包:
代码示例:
  try {
    let fs = require("fs");
    let parser = new Parser();
    // <tag attr="hello">
    parser.on("opentag", (name, attrs) => {
      // name = 'tag'
      // attrs = { attr: 'hello' }
      console.log(name, attrs);
    // </tag>
    parser.on("closetag", name => {
      // name = 'tag'
    // <tag>TEXT</tag>
    parser.on("text", text => {
      // text = 'TEXT'
    // <[[CDATA['data']]>
    parser.on("cdata", cdata => {
      // cdata = 'data'
    // <?xml version="1.0"?>
    parser.on("instruction", (name, attrs) => {
      // name = 'xml'
      // attrs = { version: '1.0' }
    // Only stream-errors are emitted.
    parser.on("error", err => {
      // Handle a parsing error
    parser.on("finish", () => {
      // Stream is completed
    // Write data to the stream.
    parser.write("<root>TEXT</root>");
    // Pipe a stream to the parser
    let stream = fs.createReadStream("D:/data/stackoverflow/stackoverflow.com-Posts/PostsCopy.xml");
    stream.pipe(parser);
  } catch (e) {
    console.log(e);
运行结果片段:
row {
PostTypeId: '2',
ParentId: '371',
CreationDate: '2008-08-02T13:45:57.197',
Score: '13',
Body: '&lt;p&gt;Yahoo uses a method called Sender ID, which can be configured at &lt;a',
href: '&quot;http://old.openspf.org/wizard.html?mydomain',
rel: '&quot;nofollow noreferrer&quot;&gt;The SPF Setup Wizard&lt;/a&gt; and entered in to your DNS. Also one of the important ones for Exchange, Hotmail, AOL, Yahoo, and others is to have a Reverse DNS for your domain. Those will knock out most of the issues.
However you can never prevent a person intentionally blocking your or custom rules.&lt;/p&gt;&#xA;',
OwnerUserId: '17',
LastEditorUserId: '246246',
LastEditDate: '2017-04-20T16:17:40.470',
LastActivityDate: '2017-04-20T16:17:40.470',
CommentCount: '1 /'
row {
PostTypeId: '2',
ParentId: '17',
CreationDate: '2008-08-02T14:57:13.043',
Score: '22',
Body: '&lt;p&gt;While you havent said what youre storing, and you may have a great reason for doing so, often the answer is as a filesystem reference and the actual data is on the filesystem somewhere.&lt;/p&gt;&#xA;&#xA;&lt;p&gt;&lt;a',
href: '&quot;http://www.onlamp.com/pub/a/onlamp/2002/07/11/MySQLtips.html&quot;',
rel: '&quot;noreferrer&quot;&gt;http://www.onlamp.com/pub/a/onlamp/2002/07/11/MySQLtips.html&lt;/a&gt;&lt;/p&gt;&#xA;',
OwnerUserId: '144',
LastActivityDate: '2008-08-02T14:57:13.043',
CommentCount: '0 /'
